Moderators: Víctor Paredes , Belgarath , slowtiger
fiziwig
Posts: 197 Joined: Thu Jan 03, 2008 11:00 pm
Post
by fiziwig » Sat Jan 05, 2008 11:40 pm
OK, so it's not "Snow White", but hey, I only got Anime Studio yesterday. I rigged a simple stick figure character to learn how to work bones, and here is my very first animation.
http://fiziwig.com/anim/stickman.swf
I rendered it as an avi but it was over 10 MB even at half-size. When I tried to render as an MOV AS crashed. Did I do something wrong, or is this normal on a PC?
--gary
Posts: 6386 Joined: Thu Feb 16, 2006 9:53 am
Post
by slowtiger » Sun Jan 06, 2008 3:18 am
That's really good for a first try. Especially the shoulder shrug made me laugh.
Crashing shouldn't occur. How big are your project's dimensions? Something like this shouldn't be bigger than 200 k in a Quicktime MOV with MPEG-4.
fiziwig
Post
by fiziwig » Sun Jan 06, 2008 10:24 am
Thanks for those comments.
My project dimensions are 320 x 240, at 24 FPS.
You mentioned MPEG-4. I also have the problem that when I try to play any MP4 file from somebody else, it crashes QuickTime.
--gary
dueyftw
Posts: 2185 Joined: Thu Sep 14, 2006 2:32 am
Post
by dueyftw » Sun Jan 06, 2008 12:05 pm
Have you tried a different codec? Mpg format is variable quality codec, you can get very large files on the wrong settings.
Dale
fiziwig
Post
by fiziwig » Sun Jan 06, 2008 1:29 pm
dueyftw wrote: Have you tried a different codec? Mpg format is variable quality codec, you can get very large files on the wrong settings.
Dale
The problem is that when I export the MOV it brings up the codec picker dialog but then crashes immediately before letting me pick a codec.
--gary
Kadoogan
Posts: 117 Joined: Sat Jan 12, 2008 3:18 am
Post
by Kadoogan » Sat Jan 12, 2008 12:50 pm
I have had the same problem when trying to use Quicktime as the chosen method. Not sure why it happens. Just so you know you are not alone...
Aut viam inveniam aut faciam
fiziwig
Post
by fiziwig » Sat Jan 12, 2008 1:54 pm
I solved the problem by getting QuickTime Pro. Now I export in AVI and use QuickTime Pro to make an embeded MOV for my web site.
--gary
