Really lame Newbie's first animation
fiziwig
Post by fiziwig »
OK, so it's not "Snow White", but hey, I only got Anime Studio yesterday. I rigged a simple stick figure character to learn how to work bones, and here is my very first animation.
http://fiziwig.com/anim/stickman.swf
I rendered it as an avi but it was over 10 MB even at half-size. When I tried to render as an MOV AS crashed. Did I do something wrong, or is this normal on a PC?
--gary
That's really good for a first try. Especially the shoulder shrug made me laugh.
Crashing shouldn't occur. How big are your project's dimensions? Something like this shouldn't be bigger than 200 k in a Quicktime MOV with MPEG-4.
fiziwig
Post by fiziwig »
Thanks for those comments.
My project dimensions are 320 x 240, at 24 FPS.
You mentioned MPEG-4. I also have the problem that when I try to play any MP4 file from somebody else, it crashes QuickTime.
--gary
dueyftw
Post by dueyftw »
Have you tried a different codec? Mpg format is variable quality codec, you can get very large files on the wrong settings.
Dale
fiziwig
Post by fiziwig »
dueyftw wrote:Have you tried a different codec? Mpg format is variable quality codec, you can get very large files on the wrong settings.
Dale
The problem is that when I export the MOV it brings up the codec picker dialog but then crashes immediately before letting me pick a codec.
--gary
Kadoogan
Post by Kadoogan »
I have had the same problem when trying to use Quicktime as the chosen method. Not sure why it happens. Just so you know you are not alone...
Aut viam inveniam aut faciam
fiziwig
Post by fiziwig »
I solved the problem by getting QuickTime Pro. Now I export in AVI and use QuickTime Pro to make an embeded MOV for my web site.
--gary
