*NEW* Stacked shape tools
- alanthebox
Re: *NEW* Stacked shape tools
So if I understand all this correctly, all the elements of this lamp exist on a single vector layer and the different shapes all share the same intersecting points, making any movement of those points apply more evenly to the combined shape?
I'm not sure why this is such a difficult concept for me to grasp! I often have overlapping shapes that I usually manipulate with the magnet tool (turning on the "selected points only" option when needed).
I appreciate the time everyone has taken to explain the application of this script!
Hi Wes,
I popped in here because I needed a refresher on how to use this tool, and I noticed the download link no longer works.
I have the script so no problem here but I thought you'd like to know.
D.
D.
Thanks for the heads up. I've updated the link.
Hi Wes. Sorry, I should have checked this sooner but the link is currently reporting a 404 error.
Effin' Google drive changed my permissions. Should be good now.
It's good!
Hi Wes,
I needed to use the Create Shape part of the Stacked Shape tools today in 14.1, and it still works great! Definitely saved me some time.
However, the Select Shape part seems to be broken. I'm seeing this error.
Luckily, I only needed the Create Shape part, but I thought I should mention the problem with Select Shape.
Here's an update for v14: https://drive.google.com/uc?export=down ... 1tSn9CoCUsGreenlaw wrote: ↑Tue Apr 09, 2024 4:28 pm Hi Wes,
BigBoiiiJones
Cant accesssynthsin75 wrote: ↑Tue Apr 09, 2024 5:38 pmHere's an update for v14: https://drive.google.com/uc?export=down ... 1tSn9CoCUsGreenlaw wrote: ↑Tue Apr 09, 2024 4:28 pm Hi Wes,
Should work now.
Thank you, Wes! It works perfectly now!
I've updated the v14 create shape tool to prompt the user to check for new features in the stock tool when Moho is updated.
Hopefully this helps avoid confusion when updating.
Cool! Thanks, Wes.
One more update for the same thing. https://drive.google.com/uc?export=down ... 1tSn9CoCUs
For scripters:
This time I've figured out a more robust and universal way to mod stock tool replacements so they warn you when an update may have a new version of the tool.
This is one code block that can be pasted on the first line of the IsEnabled fucntion, completely as-is... no editing script names or anything. Just paste this right below:
function XX_ExampleTool:IsEnabled(moho)
For scripters:
--syn\/
if (not self.initializedVersion) then
local name
for n, value in pairs(_G) do
if rawequal(value, self) then
name = n
break
end
end
-- inject save pref remotely
local origSavePrefs = self.SavePrefs
self.SavePrefs = function(self, prefs)
prefs:SetString(name..".MohoVer", self.MohoVer)
if origSavePrefs then return origSavePrefs(self, prefs) end
end
-- load pref manually
local path = moho:UserPrefsFile()
local key = "\""..name..".MohoVer".."\""
for line in io.lines(path) do
if (string.find(line, key, 1, true)) then
self.MohoVer = string.match(line, '"[^"]+"%s+"([^"]+)"')
break
end
end
self.initializedVersion = true
self.foundName = name
-- warn user of replacement tool when Moho updates
if (self.MohoVer == nil) or (self.MohoVer ~= moho:AppVersion()) then
local name = self.foundName
local button = LM.GUI.Alert(LM.GUI.ALERT_WARNING, name.."\n This installed tool is a third-party replacement of the stock tool.\n If you have recently updated Moho, please check if this stock tool has\n been updated, and decide if you want to remove this replacement tool.", "(If you have installed this replacement for the first time, you can ignore this message.)","", "OK", "Remind me later")
if (button == 0) then
self.MohoVer = moho:AppVersion()
end
else
end
end
--syn/\
