*NEW* Stacked shape tools
alanthebox
Re: *NEW* Stacked shape tools
Post by alanthebox »
So if I understand all this correctly, all the elements of this lamp exist on a single vector layer and the different shapes all share the same intersecting points, making any movement of those points apply more evenly to the combined shape?
I'm not sure why this is such a difficult concept for me to grasp! I often have overlapping shapes that I usually manipulate with the magnet tool (turning on the "selected points only" option when needed).
I appreciate the time everyone has taken to explain the application of this script!
Hi Wes,
I popped in here because I needed a refresher on how to use this tool, and I noticed the download link no longer works.
I have the script so no problem here but I thought you'd like to know.
D.
Thanks for the heads up. I've updated the link.
Hi Wes. Sorry, I should have checked this sooner but the link is currently reporting a 404 error.
Effin' Google drive changed my permissions. Should be good now. :?:
It's good!
sang820
Post by sang820 »
:shock: I'm reposting here from another post and I just want to say: this plugin is great! Thanks, synthsin75 =) Moho is better because of you. :shock:
Hi Wes,
I needed to use the Create Shape part of the Stacked Shape tools today in 14.1, and it still works great! Definitely saved me some time.
However, the Select Shape part seems to be broken. I'm seeing this error.
Luckily, I only needed the Create Shape part, but I thought I should mention the problem with Select Shape.
Greenlaw wrote: Wed Apr 10, 2024 12:28 am Hi Wes,
Here's an update for v14: https://drive.google.com/uc?export=down ... 1tSn9CoCUs
BigBoiiiJones
Post by BigBoiiiJones »
synthsin75 wrote: Wed Apr 10, 2024 1:38 am
Cant access
Should work now.
synthsin75 wrote: Wed Apr 10, 2024 1:38 am Here's an update for v14...
Thank you, Wes! It works perfectly now! :D
