about 360 smart bones notworking
My character walks without any problems when creating 360-degree smart skeleton controllers, but it fails when creating 360-degree smart skeleton controllers from the side. What could be causing this problem?
https://www.dropbox.com/scl/fi/a83p0urb ... 18l6w&dl=0
Re: about 360 smart bones notworking
Looks like you just rotated the side 360 controller too far, especially for such a short range of frames.
Try not to use cycle, you can cycle on the controller on the main timeline when you animate.
I rotated the 360-degree rotating skeleton a quarter of the way, but the movements were still disordered and it wasn't working.synthsin75 wrote: ↑Sun Nov 16, 2025 7:30 pm Looks like you just rotated the side 360 controller too far, especially for such a short range of frames.
https://www.dropbox.com/scl/fi/bvv98999 ... ify37&dl=0
Hard to tell from just a video.
My side-walking technique, implemented using the official documentation, still failed. What could be the reason?
https://www.dropbox.com/scl/fi/08cv5p85 ... c0ddf&dl=0
Looks like there's some problem with the target bones. This sort of setup works here, so I don't know what the difference is.mohgirl wrote: ↑Mon Nov 17, 2025 1:10 am My side-walking technique, implemented using the official documentation, still failed. What could be the reason?
Inside of the action, the thighs and calves have rotation keyframes. That breaks the IK.
Go to the action, select the legs and calves' bones and remove the rotation keyframes from them.
Ah, that makes sense. The smart bone driving the leg bones is overriding the targets.
Yes, it worked after I removed the keyframes for bone rotation in the lower leg and thigh.Víctor Paredes wrote: ↑Mon Nov 17, 2025 9:58 am Inside of the action, the thighs and calves have rotation keyframes. That breaks the IK.
