Moho is a 2D software, however, its little 3D system is very helpful in most of my cases when I need to build 3D scenes. Though I don't use 3D options much but that one little tab help a lot when needed. Today, I just notice that some 3D functions that I used to see have been taken out for the new 14.3 versions. I was familiar with those options, though I don't used them much. Are they usedless options that needed to take out or are they just moved to an automatically selected by the software or moved to somewhere else?
Options I was talking about:
- Polygon orientation
- Warp using bones
Look at the image from Moho manual
https://manual.lostmarble.com/app/page/ ... gJw4U9flX3
Moho some old 3D functions loses
- hayasidist
Re: Moho some old 3D functions loses
they're still there -- but only visible if you have created a 3d layer and have it active.
I don't see there options in the 3D tab even when I have created a 3d layer and have it active.hayasidist wrote: ↑Mon Oct 06, 2025 11:08 pm they're still there -- but only visible if you have created a 3d layer and have it active.
- Warp using bones
- hayasidist
Ah! I see. I was on a 2d vector with 3d options most of the time. I used to import 3D layers, that's why I saw those options. Thank you very much for your information.hayasidist wrote: ↑Tue Oct 07, 2025 8:39 am have you created a 3d layer? You won't see them unless you're on a FULL 3D layer (IOW you won't see them in the 3d options on a 2d vector layer)
If the layer type icon is not a "cube" (see layer 2 in the layers panel) then you haven't got a 3d layer.
Years ago I made a tutorial on how to create 3D objects in Moho, file included, you can build some interesting 3D models and animate them in Moho, have a look!
I watched that video, it opened my eyes on how Moho can work more than I expected with 3D. Thank you for your great videos.
As shown in my video, you draw your profile on the default axis, then choose the 3D modifier you want to use, then you only move the entire layer, if you want several 3D objects to move together, you put them in a group, then you move the group, you never move the profile on its own, only the layer, or a group of layers!
