MR Tween Machine 2.2
Re: MR Tween Machine 1.5
Cool update. Looking forward to the new tools too.
Nice! Those inspector panels look super useful too! Thanks for all your hard work on these fantastic scripts
Thank you all for the positive feedback! While the Inspector is still in development, are there any specific parameters you would most like to monitor?
Re: MR Tween Machine 2.0
Hello! Updated the script to version 2.0.
Added an additional slider for more control. Hope you like it.
Download link: https://mohoscripts.com/script/mr_tween_machine
Love it! now i can finally tweak the latest keyframe. Thanks!
amazing!
Re: MR Tween Machine 2.1
Hello! Quick update. I've added the ability to customize the size of sliders in version 2.1.
thank you
When I open the floating panel and swipe left and right to select a value, a pop-up window will appear
Version 2.1.2 - Fixed a bug due to which the script took incorrect values if the layer had a timing offset.
thanks
Re: MR Tween Machine 2.2
Version 2.2 New Features:
1. Added an option that allows blocking the script on even or odd frames. This is convenient if you work in twos, so as not to create keys outside the interval.
2. A settings menu has been added to the floating panel.
How timely! I'm about to experiment with animating at higher intervals in Moho. Can't wait to start working with this version.
Thank you for updating your tool, Eugene!
Thank you for your amazing script. I have your previous version of the script install in Moho. Should I uninstall the previous version first then install the new one later, or can I install the later version and the script will be replaced by new one. Removing script from content folder is not too simple for me, since some scripts has the same script file name in utility folder, and it is hard to decide which file should be removed from the utility folder. If installing on top the previous version, is there going to be any error of the code?KuzKuz wrote: ↑Thu Feb 01, 2024 9:43 am Version 2.2 New Features:
