MR Tween Machine 3
SimplSam
Re: MR Tween Machine 1.5
Post by SimplSam »
Cool update. Looking forward to the new tools too.
Lukas
Post by Lukas »
Nice! Those inspector panels look super useful too! Thanks for all your hard work on these fantastic scripts :)
KuzKuz
Post by KuzKuz »
Thank you all for the positive feedback! While the Inspector is still in development, are there any specific parameters you would most like to monitor?
KuzKuz
Re: MR Tween Machine 2.0
Post by KuzKuz »
Hello! Updated the script to version 2.0.
Added an additional slider for more control. Hope you like it.
Download link: https://mohoscripts.com/script/mr_tween_machine
Love it! now i can finally tweak the latest keyframe. Thanks!
mohgirl
Post by mohgirl »
amazing!
KuzKuz
Re: MR Tween Machine 2.1
Post by KuzKuz »
Hello! Quick update. I've added the ability to customize the size of sliders in version 2.1.
mohgirl
Post by mohgirl »
thank you
mohgirl
Post by mohgirl »
When I open the floating panel and swipe left and right to select a value, a pop-up window will appear
KuzKuz
Post by KuzKuz »
mohgirl wrote: Tue Dec 05, 2023 5:36 pm When I open the floating panel and swipe left and right to select a value, a pop-up window will appear
Thank you, I have updated the script on the website, it should work now.
KuzKuz
Post by KuzKuz »
Version 2.1.2 - Fixed a bug due to which the script took incorrect values if the layer had a timing offset.
mohgirl
Post by mohgirl »
thanks
KuzKuz
Re: MR Tween Machine 2.2
Post by KuzKuz »
Version 2.2 New Features:
1. Added an option that allows blocking the script on even or odd frames. This is convenient if you work in twos, so as not to create keys outside the interval.
2. A settings menu has been added to the floating panel.
How timely! I'm about to experiment with animating at higher intervals in Moho. Can't wait to start working with this version.
Thank you for updating your tool, Eugene!
Panha
Post by Panha »
KuzKuz wrote: Thu Feb 01, 2024 9:43 am Version 2.2 New Features:
Thank you for your amazing script. I have your previous version of the script install in Moho. Should I uninstall the previous version first then install the new one later, or can I install the later version and the script will be replaced by new one. Removing script from content folder is not too simple for me, since some scripts has the same script file name in utility folder, and it is hard to decide which file should be removed from the utility folder. If installing on top the previous version, is there going to be any error of the code? ❤️
