Hello, I'm very new to Moho and I am trying to make my first rig however I noticed that the smooth interpolation seems to have easing. The bigger circle is keyframed but the smaller isn't. If there isn't any easing they should move at the same speed even if keyframed. Although easing is good since I'm trying to make an action I would prefer an interpolation without it to make it easier. Are there any interpolations without easing or any other way to get rid of it? I haven't delved into the motion graph yet but would that work to remove easing?
Any interpolation without easing?
Re: Any interpolation without easing?
Yeah you can choose between a few interpolation methods. Take a look at the page 338 (349 of the PDF), the "Choosing an Interpolation Method" section:
https://lostmarble.net/Manuals/Moho%20U ... ual_HQ.pdf
Thank you, it seems like what I want is linear and not smooth! Many thanks!
BTW, I noticed you have your Default set the Smooth. May I suggest setting it to Copy Previous Key? This way, whichever mode you use on a channel, Moho will continue to use that mode until you decide to change it.
For me, this is the most useful 'mode' because I almost always animate with Linear inside a Smart Bone Action and almost always with Smooth on the Mainline. Using this Copy Previous Key significantly reduces the amount of mode switching I need to do during rigging and animation. (IMO, this Copy Previous should be Moho's default mode out-of-the-box.)
That does seem useful! I'll be sure to turn that on from now on.
