I just uploaded my lipsync script to mohoscripts
strider2000
Post by strider2000 »
Hi everyone,
I just uploaded my lip sync script to mohoscripts.com (love that site :))
Here's a video description (it's linked on the sight too)
This is not a new script, but I still use it all the time. It's just that with mohoscipts.com, I've finally had a chance to upload it.
Here's a thread on it.
http://www.lostmarble.com/forum/viewtop ... 12&t=28346
You can get it here
https://mohoscripts.com/script/msLipSync
I hope it's helpful to others.
teotoon
Re: I just uploaded my lipsync script to mohoscripts
Post by teotoon »
Hey Strider,
This is just a wonderful script. I've been using it since its inception. I'm happy to see that you make it available for Moho 13.5. Just a brilliant work.
Thank you for your effort and generosity,
Cheers and happy animating,
LG
strider2000
Thanks teotoon. I'm glad it's been helpful. I know it makes it easier for me to do lipsync :)
That's a very clever strider2000! I'm impressed that you made your system flexible enough to work with many different mouth control setups.
Hi Strider2000,
From the script description at Moho Scripts: "The msLipSyncReadme.txt gives detailed information about the script and how to use it."
I was checking out the script and noticed that this file is missing from the .zip package. Just letting you know.
Thanks for sharing this script!
strider2000
Greenlaw wrote: Sat Jan 29, 2022 9:59 am That's a very clever strider2000! I'm impressed that you made your system flexible enough to work with many different mouth control setups.
Thanks Greenlaw.
Sorry everyone for the issues :( When I uploaded, I dragged several files to be uploaded, but it seems there were 2 issues.
  • The site seems to want one lua file per upload.
  • The site seems to no allow .txt files
Not saying there's anything wrong with the site. I may just not understand.
So to fix it I've done the following:
  • I uploaded the msPhonemes.lua file separately and linked to it. It downloads now.
  • Instead of uploading the readme file, I added it to the description.
  • Since I don't know how to upload a text file, so it can be put in the utility directory, I just added it to the description and added some notes. Unfortunately people will need to just cut and paste the text into a file called "lipSync.txt" in the scripts/utility directory. It's needed for characters with bone controlled mouths. If you're lip synching a character with switch layers, it will work if that files not there, but you'll see an error message :( You'd just have to close it.
msDialog.lua should have been downloaded in the zip. Make sure it's copied to the scripts/utility directory.
I hope that helps everyone.
alanthebox
Post by alanthebox »
oh boy, this has become a favorite script after just a few minutes of use. thanks!
house10 wrote: Sat Jan 29, 2022 11:26 pm did everything change the bone name to close/open on moho 12.5 scrub n all bone move wont move.
on 13.5 ones i change the bone name to close/open the bone does stay out it moves around like it being controlled by a layer :cry:
You might not be ready to use more complicated scripts, bud.
strider2000
alanthebox wrote: Sat Jan 29, 2022 10:20 pm oh boy, this has become a favorite script after just a few minutes of use. thanks!
Glad it's helpful!
Hoptoad
Post by Hoptoad »
Wow, this script appeared just as I was about to do a whole bunch of lip sync.
I'm having a little trouble getting it to work. I scrub with the tool, like in the tutorial video. But I'm getting this lua error:
/msPhonemes.lua:110: 'for' limit must be a number
I'm on a Mac. I only use switches for mouth shapes, and every mouth-phoneme is in a folder (because of masks). This is the text file I made for the utility folder. Is it correct? I hope I can get this script working; it'll be a huge time-saver.
Tony
AI
E
L
etc
FV
MBP
O
U
WQ
rest
end
strider2000
The text file you describe will not work. It must be named lipSync.txt, it must be in the utility folder, but the more important point is that it's not for switch layers (even though it must exist). It's for bone controlled characters and it must follow the format specified in the description. Since you're not currently using bones to control the mouth, I advise that you copy the text, starting with Scarlett 2, exactly as shown in the description, under the installation section.
Hoptoad
Post by Hoptoad »
Thanks! It works now.
Also, I had forgotten to enter the words in the text box. Oops.
Awesome script!
strider2000
Hoptoad wrote: Sun Jan 30, 2022 11:07 am Thanks! It works now.
That's great! Enjoy :)
tiatridis
Post by tiatridis »
Hi guys,
I've installed the script mentioned here for lip syncing and the tool shows up and the scrub works, but.. I get an error message as such:
msPhonemes.lua:110 'for' limit must be a number
Working on a Mac
was wondering if Strider or anyone else on the forum had an idea of how to fix this, seems like it would be a great script to run.
Thanks
