Greenlaw wrote: ↑Sat Jan 29, 2022 9:59 am
That's a very clever strider2000! I'm impressed that you made your system flexible enough to work with many different mouth control setups.
Thanks Greenlaw.
Sorry everyone for the issues
When I uploaded, I dragged several files to be uploaded, but it seems there were 2 issues.
- The site seems to want one lua file per upload.
- The site seems to no allow .txt files
Not saying there's anything wrong with the site. I may just not understand.
So to fix it I've done the following:
- I uploaded the msPhonemes.lua file separately and linked to it. It downloads now.
- Instead of uploading the readme file, I added it to the description.
- Since I don't know how to upload a text file, so it can be put in the utility directory, I just added it to the description and added some notes. Unfortunately people will need to just cut and paste the text into a file called "lipSync.txt" in the scripts/utility directory. It's needed for characters with bone controlled mouths. If you're lip synching a character with switch layers, it will work if that files not there, but you'll see an error message
You'd just have to close it.
msDialog.lua should have been downloaded in the zip. Make sure it's copied to the scripts/utility directory.
I hope that helps everyone.
