Can you freeze particles?
SuperSGL
Post by SuperSGL »
I'm using 13.5 and creating a starry night thought I could use particles to simulate this. Can't find away to freeze them though. I know there are tons of other ways I might even render out the first image and use the png for the background but was just curious if it could be done?
Norman McLaren
My Animations
Re: Can you freeze particles?
Yes, you just need to be sure the lifetime and any movement value are set to zero.
Here's an example and the Moho file:
https://www.dropbox.com/s/bbwbnw8zlc0rm ... moho?raw=1
SuperSGL
Post by SuperSGL »
Thanks! I didn't realize I had .5 in the Velocity setting :oops:
Norman McLaren
My Animations
Maestral
Post by Maestral »
Once I read the title, I had somewhat different freezing in mind - is it possible to freeze particles once they start motion? As in interrupting a cycle by adding a keyframe.
Some moons ago I resolved it with a rendered image sequence of just the Particle layer and the last frame as a separate image.
MrMiracle77
Post by MrMiracle77 »
If you wanted the particles to slow to a stop, ensure the 'acceleration' is directed in the opposite direction of the 'initial velocity' value, then swap to your screencap before they reverse direction.
- Dave
(As Your GM)
Maestral
Post by Maestral »
Thanks. That's a very neat approach.
Initially, I tried to mimic a "spill", as if some amount of particles were spilt and remained on the surface. Your approach seems more convincing.
