change parameters for multiple bones
- davoodice2
Hi
for example I have some bones with different setting. some of theme have bone angle limit and some other have target bone. now when I select all bones and activate independent angle, all bones settings change and my target bones and angle limit will be set for all or deactivate for all.
normally it must changes current parameter.
Re: change parameters for multiple bones
Yes it would be better if you could change just the individual parameters without all/most settings being applied to all selected bones.
The select bone tool could be modded to only change the attributes that change, but I have no need for that myself.
Oh wow, yes I have dreamed of a way to do this but for the life of me couldn't figure out how to implement this. The logic hurts my head.
How would the tool "know" which parameter to change on which bone if they are all different?
An example:
You select 10 bones. They all have different angle targets to different bones so you don't want to change those because they are all different.
As an example, let's say you only want to change the angle limit for the selected bones and ignore all the other settings.
The logic is tricky. You would have to make a list of all the bones parameters ALL OF THE PARAMETERS and compare all of each bones parameters to each other to see what is different. Then make another list to compare any changes made in the bone edit window and only apply what changed to each bone leaving the other parameters the same... yikes... head is spinning again.
An example:
p.s. Quite embarrassing, but I actually forgot that this was scripted !!!!synthsin75 wrote: ↑Wed Jul 07, 2021 6:51 pm The select bone tool could be modded to only change the attributes that change, but I have no need for that myself.
I don't think you need to do all that. At the moment the script uses a single change Message DLOG_CHANGE for all input property fields. Instead it could use individual Message & handler logic to set relevant properties.
One thing I am definitely going to change is the Wind enable switch (checkbox) - so that it can auto-enable Bone Dynamics - in a single click. I get irritated having to enable Dynamics and then enable Wind (Lazy me).
Oh wow, okay must look at that. So the bone dialog just sets everything to be updated and instead you could simply evaluate ONLY things THAT CHANGED. Cool beans, yes will look at that next chance I get.
p.s. I am just now getting the hang of the changes in the scripting interface since the last time I did any massive scripting. YIKES! OUCH! It HURTS!
Is there an updated reference? There use to be a text file with all the scripting references for the current version. It was a bare minimum, some sort of exported text didn't have explanations or anything just basic list of stuff. Couldn't find anything like that with 13.5.
Great idea. I just did that myself. Have to disable wind before I can disable dynamics, but that's a much rarer task.
ScriptName = "LM_SelectBone"
LM_SelectBone = {}
LM_SelectBone.BASE_STR = 2285
function LM_SelectBone:Name()
return "Select Bone"
end
function LM_SelectBone:Version()
return "6.0"
end
function LM_SelectBone:Description()
return MOHO.Localize("/Scripts/Tool/SelectBone/Description=Click to select a bone (hold <shift> or <ctrl/cmd> to select more than one bone)")
end
function LM_SelectBone:Creator()
return "Lost Marble LLC, modded by J.Wesley Fowler (synthsin75)"
end
function LM_SelectBone:UILabel()
return(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
end
function LM_SelectBone:LoadPrefs(prefs)
self.lassoMode = prefs:GetBool("LM_SelectBone.lassoMode", false)
end
function LM_SelectBone:SavePrefs(prefs)
prefs:SetBool("LM_SelectBone.lassoMode", self.lassoMode)
end
function LM_SelectBone:ResetPrefs()
self.lassoMode = false
end
-- Recurring values
LM_SelectBone.selBoneID = -1
LM_SelectBone.selRect = LM.Rect:new_local()
LM_SelectBone.previousX = 0
LM_SelectBone.previousY = 0
LM_SelectBone.isMouseDragging = false
-- The guts of this script
function LM_SelectBone:ShouldUseParentSkeleton(moho)
if (not moho.layer:IsBoneType()) then
return true
end
return false
end
function LM_SelectBone:IsEnabled(moho)
local skel = moho:Skeleton()
if (skel == nil) then
if (self:ShouldUseParentSkeleton(moho)) then
skel = moho:ParentSkeleton()
end
return false
end
end
return true
end
function LM_SelectBone:IsRelevant(moho)
end
return false
end
end
return true
end
function LM_SelectBone:OnMouseDown(moho, mouseEvent)
self.isMouseDragging = true
self.selRect.left = -10
self.selRect.top = -10
self.selRect.right = -5
self.selRect.bottom = -5
-- Try to select a bone by clicking on it
self:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey)
-- If no bone was selected, start dragging out a marquee selection
local lassoMode = false
self.ctrlKeySelection = false
if (self.lassoMode) then
if (not(mouseEvent.ctrlKey)) then
lassoMode = true
else
self.ctrlKeySelection = true
end
else
if (mouseEvent.ctrlKey) then
lassoMode = true
end
end
mouseEvent.view:DrawMe()
if (self.selBoneID == -1) then
if (lassoMode) then
self.lassoList = { { mouseEvent.startPt.x, mouseEvent.startPt.y } }
self.previousX = mouseEvent.startPt.x
self.previousY = mouseEvent.startPt.y
else
self.selRect.left = mouseEvent.startPt.x
self.selRect.top = mouseEvent.startPt.y
self.selRect.right = mouseEvent.pt.x
self.selRect.bottom = mouseEvent.pt.y
mouseEvent.view:Graphics():SelectionRect(self.selRect)
end
end
end
function LM_SelectBone:OnMouseMoved(moho, mouseEvent)
--self:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey)
if (self.selBoneID >= 0) then
return
end
if (not(self.ctrlKeySelection)) then
lassoMode = true
end
else
if (self.ctrlKeySelection) then
lassoMode = true
end
end
if (lassoMode) then
local g = mouseEvent.view:Graphics()
g:SetSmoothing(true)
g:Push()
local m = g:CurrentTransform()
m:Invert()
g:ApplyMatrix(m)
g:SetColor(MOHO.MohoGlobals.SelCol)
g:MoveTo(self.previousX, self.previousY)
g:LineTo(mouseEvent.pt.x, mouseEvent.pt.y)
g:Pop()
g:SetSmoothing(false)
mouseEvent.view:RefreshView()
table.insert(self.lassoList, { mouseEvent.pt.x, mouseEvent.pt.y })
self.previousX = mouseEvent.pt.x
self.previousY = mouseEvent.pt.y
else
end
end
function LM_SelectBone:OnMouseUp(moho, mouseEvent)
return
end
self.isMouseDragging = false
lassoMode = true
end
else
lassoMode = true
end
end
if (lassoMode) then
-- draw the finalized lasso outline
g:Push()
m:Invert()
g:ApplyMatrix(m)
g:LineTo(mouseEvent.startPt.x, mouseEvent.startPt.y)
g:Pop()
LM.Snooze(100)
end
-- 1 - Draw the selection shape, either a lasso or a rectangle
local end1 = LM.Vector2:new_local()
local end2 = LM.Vector2:new_local()
g:Clear(0, 0, 0, 0)
g:Push()
m:Invert()
g:ApplyMatrix(m)
g:SetColor(255, 255, 255, 255)
g:BeginShape()
if (lassoMode) then
for i = 1, #self.lassoList - 1 do
end1:Set(self.lassoList[i][1], self.lassoList[i][2])
end2:Set(self.lassoList[i + 1][1], self.lassoList[i + 1][2])
g:AddLine(end1, end2)
end
end1:Set(self.lassoList[#self.lassoList][1], self.lassoList[#self.lassoList][2])
end2:Set(self.lassoList[1][1], self.lassoList[1][2])
else
end1:Set(mouseEvent.startPt.x, mouseEvent.startPt.y)
end2:Set(mouseEvent.pt.x, mouseEvent.startPt.y)
end1:Set(end2.x, end2.y)
end2:Set(mouseEvent.pt.x, mouseEvent.pt.y)
end2:Set(mouseEvent.startPt.x, mouseEvent.pt.y)
end2:Set(mouseEvent.startPt.x, mouseEvent.startPt.y)
end
g:EndShape()
g:Pop()
-- test code to view the lasso's shape
--mouseEvent.view:RefreshView()
--LM.Snooze(1000)
-- 2 - Do hit testing on the selection shape
local v = LM.Vector2:new_local()
local screenPt = LM.Point:new_local()
local m = LM.Matrix:new_local()
local parentSkeleton = false
moho.layer:GetFullTransform(moho.frame, m, moho.document)
parentSkeleton = true
moho.layer:ControllingBoneLayer():GetFullTransform(moho.frame, m, moho.document)
end
end
if (skel ~= nil) then
for i = 0, skel:CountBones() - 1 do
local bone = skel:Bone(i)
if ((not bone.fHidden) and bone:IsGroupVisible()) then
local boneMatrix = bone.fMovedMatrix
if (moho.frame == 0) then
boneMatrix = bone.fRestMatrix
end
for j = 0, 10 do
v:Set(bone.fLength * j / 10.0, 0)
boneMatrix:Transform(v)
m:Transform(v)
g:WorldToScreen(v, screenPt)
if (g:IsFullWhite(screenPt)) then
if (mouseEvent.shiftKey) then
bone.fSelected = not bone.fSelected
else
bone.fSelected = true
end
break
end
end
end
end
end
self.lassoList = nil
moho:UpdateSelectedChannels()
end
function LM_SelectBone:Select(moho, mousePt, mouseVec, mouseView, shiftSelect, ctrlSelect)
self.selBoneID = -1
end
return
end
end
local id = -1
if (parentSkeleton) then
id = mouseView:PickBone(mousePt, mouseVec, moho.layer:ControllingBoneLayer(), true)
else
id = mouseView:PickBone(mousePt, mouseVec, moho.layer, true)
end
self.selBoneID = id
if (shiftSelect) then
if (id >= 0) then
skel:Bone(id).fSelected = true
end
elseif (ctrlSelect) then
if (id >= 0) then
skel:Bone(id).fSelected = not skel:Bone(id).fSelected
end
else
skel:Bone(i).fSelected = (i == id)
end
end
moho:UpdateBonePointSelection()
mouseView:DrawMe()
end
function LM_SelectBone:OnKeyDown(moho, keyEvent)
end
return
end
end
if (keyEvent.keyCode == LM.GUI.KEY_UP and not keyEvent.ctrlKey) then
if (skel:Bone(i).fSelected) then
local pID = skel:Bone(i).fParent
if (pID >= 0) then
skel:Bone(i).fSelected = false
skel:Bone(pID).fSelected = true
end
break
end
end
keyEvent.view:DrawMe()
elseif (keyEvent.keyCode == LM.GUI.KEY_DOWN and not keyEvent.ctrlKey) then
local childID = -1
if (skel:CountBoneChildren(i) == 1) then
childID = skel:GetFirstChildBone(i)
end
if (childID >= 0) then
skel:Bone(childID).fSelected = true
end
break
end
end
elseif ((keyEvent.keyCode == LM.GUI.KEY_DELETE) or (keyEvent.keyCode == LM.GUI.KEY_BACKSPACE)) then
if (moho.layer:IsBoneType() and (moho.layerFrame == 0 or not moho:DisableDrawingTools())) then
local boneLayer = moho:LayerAsGroup(moho.layer)
moho.document:PrepUndo(moho.layer, false)
moho.document:SetDirty()
keepTrying = true
while keepTrying do
keepTrying = false
for j = 0, boneLayer:CountLayers() - 1 do
boneLayer:Layer(j):DeleteParentBone(i)
end
skel:DeleteBone(i)
keepTrying = true
break
end
end
end
moho:SetCurFrame(moho.frame) -- trigger an update of all the bones in case they're undergoing a preview with the manipulate bones tool or something
end
end
end
function LM_SelectBone:DrawMe(moho, view)
if (self.isMouseDragging) then
local g = view:Graphics()
lassoMode = true
end
else
lassoMode = true
end
end
if (lassoMode and self.lassoList) then
g:Push()
m:Invert()
g:ApplyMatrix(m)
g:MoveTo(self.lassoList[1][1], self.lassoList[1][2])
for i = 2, #self.lassoList do
g:LineTo(self.lassoList[i][1], self.lassoList[i][2])
end
g:Pop()
else
g:SelectionRect(self.selRect)
end
end
end
-- Bone constraints dialog
local LM_SelectBoneDialog = {}
function LM_SelectBoneDialog:new()
local d = LM.GUI.SimpleDialog(MOHO.Localize("/Scripts/Tool/SelectBone/BoneConstraints=Bone Constraints"), LM_SelectBoneDialog)
local l = d:GetLayout()
l:PushV(LM.GUI.ALIGN_LEFT, 0)
d.angleConstraints = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/AngleConstraints=Angle constraints:"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.angleConstraints, LM.GUI.ALIGN_LEFT)
l:PushH()
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/MinMaxDegrees=Min/max (degrees)")))
d.minAngle = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
d.minAngle:SetWheelInc(5)
l:AddChild(d.minAngle)
d.maxAngle = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
d.maxAngle:SetWheelInc(5)
l:AddChild(d.maxAngle)
l:Pop()
if (MOHO.IsMohoPro()) then
l:AddPadding()
d.fixedAngle = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/IndependentAngle=Independent angle"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.fixedAngle, LM.GUI.ALIGN_LEFT)
l:AddPadding()
l:PushH(LM.GUI.ALIGN_LEFT)
l:PushV(LM.GUI.ALIGN_LEFT)
d.squashScaling = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/SquashAndStretchScaling=Squash and stretch scaling"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.squashScaling, LM.GUI.ALIGN_LEFT)
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/MaximumIKStretching=Maximum IK stretching")), LM.GUI.ALIGN_LEFT)
l:Pop()
d.maxStretchScaling = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
d.maxStretchScaling:SetWheelInc(0.1)
l:AddChild(d.maxStretchScaling, LM.GUI.ALIGN_LEFT)
d.maxAutoScaling = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
d.maxAutoScaling:SetWheelInc(0.1)
l:AddChild(d.maxAutoScaling, LM.GUI.ALIGN_LEFT)
l:Pop()
l:Pop()
l:AddPadding()
d.arcSolver = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ArcIKSolver=Arc IK solver"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.arcSolver, LM.GUI.ALIGN_LEFT)
d.ignoredByIK = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/IgnoredByInverseKinematics=Ignored by inverse kinematics"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.ignoredByIK, LM.GUI.ALIGN_LEFT)
l:AddPadding()
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/Target=Target:")), LM.GUI.ALIGN_LEFT)
l:PushH()
d.targetMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
d.targetPopup = LM.GUI.PopupMenu(128, true)
d.targetPopup:SetMenu(d.targetMenu)
l:AddChild(d.targetPopup)
l:Pop()
end
l:AddPadding()
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/AngleControlBone=Angle control bone:")), LM.GUI.ALIGN_LEFT)
l:PushH()
d.acMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
d.acPopup = LM.GUI.PopupMenu(128, true)
d.acPopup:SetMenu(d.acMenu)
l:AddChild(d.acPopup)
d.angleControl = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
l:AddChild(d.angleControl)
l:Pop()
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/PositionControlBone=Position control bone:")), LM.GUI.ALIGN_LEFT)
l:PushH()
d.pcMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
d.pcPopup = LM.GUI.PopupMenu(128, true)
d.pcPopup:SetMenu(d.pcMenu)
l:AddChild(d.pcPopup)
d.posControlX = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
l:AddChild(d.posControlX)
d.posControlY = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
l:AddChild(d.posControlY)
l:Pop()
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/ScaleControlBone=Scale control bone:")), LM.GUI.ALIGN_LEFT)
l:PushH()
d.scMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
d.scPopup = LM.GUI.PopupMenu(128, true)
d.scPopup:SetMenu(d.scMenu)
l:AddChild(d.scPopup)
d.scaleControl = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
l:AddChild(d.scaleControl)
l:Pop()
d.boneDynamics = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/BoneDynamics=Bone dynamics:"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.boneDynamics, LM.GUI.ALIGN_LEFT)
l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/TorqueSpringDampingForce=Torque force / Spring force / Damping force")), LM.GUI.ALIGN_LEFT)
l:PushH()
d.torque = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
d.torque:SetWheelInc(0.1)
l:AddChild(d.torque)
d.spring = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
d.spring:SetWheelInc(0.1)
l:AddChild(d.spring)
d.damping = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
d.damping:SetWheelInc(0.1)
l:AddChild(d.damping)
d.windDynamics = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/Wind=Wind"), LM_SelectBone.DLOG_CHANGE)
l:AddChild(d.windDynamics)
l:Pop()
l:PushH(LM.GUI.ALIGN_RIGHT, 0)
l:AddChild(LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectBone/Close=Close"), LM.GUI.MSG_CANCEL))
l:Pop()
l:Pop()
return d
end
function LM_SelectBoneDialog:UpdateWidgets(moho)
if (self.document and self.layer and self.skel and self.bone) then
self.angleConstraints:Enable(true)
self.targetPopup:Enable(true)
end
self.acPopup:Enable(true)
self.pcPopup:Enable(true)
self.scPopup:Enable(true)
self.boneDynamics:Enable(true)
self.angleConstraints:SetValue(self.bone.fConstraints)
self.minAngle:SetValue(math.deg(self.bone.fMinConstraint))
self.maxAngle:SetValue(math.deg(self.bone.fMaxConstraint))
self.minAngle:Enable(self.bone.fConstraints)
self.maxAngle:Enable(self.bone.fConstraints)
local id = self.skel:BoneID(self.bone)
self.fixedAngle:Enable(true)
self.fixedAngle:SetValue(self.bone.fFixedAngle)
self.squashScaling:Enable(true)
self.squashScaling:SetValue(self.bone.fScalingMode == 2)
self.maxStretchScaling:Enable(self.bone.fScalingMode == 2)
self.maxStretchScaling:SetValue(self.bone.fSquashStretchScaling)
self.maxAutoScaling:Enable(true)
self.maxAutoScaling:SetValue(self.bone.fMaxAutoScaling)
self.arcSolver:Enable(true)
self.arcSolver:SetValue(self.bone:IsArcSolverEnabled())
self.ignoredByIK:Enable(true)
self.ignoredByIK:SetValue(self.bone.fIgnoredByIK)
MOHO.BuildBoneChoiceMenu(self.targetMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
if (self.skel:TargetOfBone(id, self.layerFrame) < 0) then
self.targetMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
else
self.targetMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.skel:TargetOfBone(id, self.layerFrame), true)
end
self.targetPopup:Redraw()
end
MOHO.BuildBoneChoiceMenu(self.acMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
if (self.bone.fAngleControlParent < 0) then
self.acMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
else
self.acMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fAngleControlParent, true)
end
self.acPopup:Redraw()
MOHO.BuildBoneChoiceMenu(self.pcMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
if (self.bone.fPosControlParent < 0) then
self.pcMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
else
self.pcMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fPosControlParent, true)
end
self.pcPopup:Redraw()
MOHO.BuildBoneChoiceMenu(self.scMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
if (self.bone.fScaleControlParent < 0) then
self.scMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
else
self.scMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fScaleControlParent, true)
end
self.scPopup:Redraw()
self.angleControl:Enable(self.bone.fAngleControlParent >= 0)
self.posControlX:Enable(self.bone.fPosControlParent >= 0)
self.posControlY:Enable(self.bone.fPosControlParent >= 0)
self.scaleControl:Enable(self.bone.fScaleControlParent >= 0)
self.angleControl:SetValue(self.bone.fAngleControlScale)
self.posControlX:SetValue(self.bone.fPosControlScale.x)
self.posControlY:SetValue(self.bone.fPosControlScale.y)
self.scaleControl:SetValue(self.bone.fScaleControlScale)
self.boneDynamics:SetValue(self.bone.fBoneDynamics.value)
self.windDynamics:SetValue(self.bone.fWindDynamics)
self.torque:SetValue(self.bone.fTorqueForce)
self.spring:SetValue(self.bone.fSpringForce)
self.damping:SetValue(self.bone.fDampingForce)
--[syn] self.windDynamics:Enable(self.bone.fBoneDynamics.value)
--[[syn]] self.windDynamics:Enable(true)
self.torque:Enable(self.bone.fBoneDynamics.value)
self.spring:Enable(self.bone.fBoneDynamics.value)
self.damping:Enable(self.bone.fBoneDynamics.value)
else
self.angleConstraints:Enable(false)
self.minAngle:Enable(false)
self.maxAngle:Enable(false)
self.fixedAngle:Enable(false)
self.squashScaling:Enable(false)
self.maxStretchScaling:Enable(false)
self.maxAutoScaling:Enable(false)
self.arcSolver:Enable(false)
self.ignoredByIK:Enable(false)
self.targetPopup:Enable(false)
end
self.acPopup:Enable(false)
self.angleControl:Enable(false)
self.pcPopup:Enable(false)
self.posControlX:Enable(false)
self.posControlY:Enable(false)
self.scPopup:Enable(false)
self.scaleControl:Enable(false)
self.boneDynamics:Enable(false)
self.windDynamics:Enable(false)
self.torque:Enable(false)
self.spring:Enable(false)
self.damping:Enable(false)
end
end
function LM_SelectBoneDialog:OnOK()
self:HandleMessage(LM_SelectBone.DLOG_CHANGE) -- send this final message in case the user is in the middle of editing some value
end
function LM_SelectBoneDialog:HandleMessage(msg)
if (not (self.document and self.layer and self.skel and self.bone)) then
return
end
if (msg == LM_SelectBone.DLOG_CHANGE) then
self.document:PrepUndo(self.layer, true)
self.document:SetDirty()
for i = 0, self.skel:CountBones() - 1 do
local bone = self.skel:Bone(i)
if (bone.fSelected) then
bone.fConstraints = self.angleConstraints:Value()
bone.fMinConstraint = math.rad(self.minAngle:FloatValue())
bone.fMaxConstraint = math.rad(self.maxAngle:FloatValue())
if (self.minAngle:IsEnabled() ~= bone.fConstraints) then
self.minAngle:Enable(bone.fConstraints)
self.maxAngle:Enable(bone.fConstraints)
end
bone.fFixedAngle = self.fixedAngle:Value()
if (self.squashScaling:Value()) then
bone.fScalingMode = 2
else
bone.fScalingMode = 0
end
bone.fSquashStretchScaling = self.maxStretchScaling:FloatValue()
if (bone.fSquashStretchScaling < 0.01) then
bone.fSquashStretchScaling = 0.01
self.maxStretchScaling:SetValue(bone.fSquashStretchScaling)
end
if (bone.fSquashStretchScaling > 100.0) then
bone.fSquashStretchScaling = 100.0
end
bone.fMaxAutoScaling = self.maxAutoScaling:FloatValue()
if (bone.fMaxAutoScaling < 0.999999) then
bone.fMaxAutoScaling = 1.0
self.maxAutoScaling:SetValue(bone.fMaxAutoScaling)
end
bone:EnableArcSolver(self.arcSolver:Value())
bone.fIgnoredByIK = self.ignoredByIK:Value()
end
bone.fAngleControlScale = self.angleControl:FloatValue()
bone.fPosControlScale.x = self.posControlX:FloatValue()
bone.fPosControlScale.y = self.posControlY:FloatValue()
bone.fScaleControlScale = self.scaleControl:FloatValue()
--syn\/
if (self.windDynamics:Value()) then
self.boneDynamics:SetValue(true)
end
--syn/\
if (bone.fBoneDynamics.value ~= self.boneDynamics:Value()) then
bone.fBoneDynamics.value = self.boneDynamics:Value()
bone.fBoneDynamics:StoreValue()
self.layer:UpdateCurFrame(true)
MOHO.NewKeyframe(CHANNEL_BONE_DYNAMICS)
MOHO.NewKeyframe(CHANNEL_BONE_SEL_DYNAMICS)
end
if (bone.fWindDynamics ~= self.windDynamics:Value()) then
bone.fWindDynamics = self.windDynamics:Value()
local updateDynamicsValues = false
if (bone.fWindDynamics) then
if (math.abs(bone.fTorqueForce - 2.0) < 0.001 and math.abs(bone.fSpringForce - 2.0) < 0.001 and math.abs(bone.fDampingForce - 1.0) < 0.001) then
updateDynamicsValues = true
bone.fTorqueForce = 0.0
bone.fSpringForce = 1.0
bone.fDampingForce = 1.0
end
else
if (math.abs(bone.fTorqueForce - 0.0) < 0.001 and math.abs(bone.fSpringForce - 1.0) < 0.001 and math.abs(bone.fDampingForce - 1.0) < 0.001) then
bone.fTorqueForce = 2.0
bone.fSpringForce = 2.0
end
end
if (updateDynamicsValues) then
self.torque:SetValue(bone.fTorqueForce)
self.spring:SetValue(bone.fSpringForce)
self.damping:SetValue(bone.fDampingForce)
end
else
bone.fTorqueForce = self.torque:FloatValue()
bone.fSpringForce = self.spring:FloatValue()
bone.fDampingForce = self.damping:FloatValue()
end
if (self.torque:IsEnabled() ~= bone.fBoneDynamics.value) then
--[syn] self.windDynamics:Enable(bone.fBoneDynamics.value)
self.torque:Enable(bone.fBoneDynamics.value)
self.spring:Enable(bone.fBoneDynamics.value)
self.damping:Enable(bone.fBoneDynamics.value)
end
end
end
self.layer:UpdateCurFrame()
MOHO.Redraw()
elseif (msg >= LM_SelectBone.SELECTCONTROL and msg <= LM_SelectBone.SELECTCONTROL + 1000) then
local ctrlID = -1
ctrlID = self.targetMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
if (ctrlID ~= self.skel:BoneID(bone) and ctrlID ~= bone.fTargetBone:GetValue(self.layerFrame)) then
bone.fTargetBone:SetValue(self.layerFrame, ctrlID)
MOHO.NewKeyframe(CHANNEL_BONE_TARGET)
MOHO.NewKeyframe(CHANNEL_BONE_SEL_TARGET)
end
end
ctrlID = self.acMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
if (ctrlID ~= self.skel:BoneID(bone)) then
bone.fAngleControlParent = ctrlID
end
ctrlID = self.pcMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
bone.fPosControlParent = ctrlID
end
ctrlID = self.scMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
bone.fScaleControlParent = ctrlID
end
self.angleControl:Enable(bone.fAngleControlParent >= 0)
self.posControlX:Enable(bone.fPosControlParent >= 0)
self.posControlY:Enable(bone.fPosControlParent >= 0)
self.scaleControl:Enable(bone.fScaleControlParent >= 0)
end
end
MOHO.Redraw()
end
end
-- Tool options - create and respond to tool's UI
LM_SelectBone.CHANGE = MOHO.MSG_BASE
LM_SelectBone.DLOG_BEGIN = MOHO.MSG_BASE + 1
LM_SelectBone.DLOG_CHANGE = MOHO.MSG_BASE + 2
LM_SelectBone.LOCK = MOHO.MSG_BASE + 3
LM_SelectBone.LASSO = MOHO.MSG_BASE + 4
LM_SelectBone.LABEL = MOHO.MSG_BASE + 5
LM_SelectBone.SHY = MOHO.MSG_BASE + 6
LM_SelectBone.COL_PLAIN = MOHO.MSG_BASE + 7
LM_SelectBone.COL_RED = MOHO.MSG_BASE + 8
LM_SelectBone.COL_ORANGE = MOHO.MSG_BASE + 9
LM_SelectBone.COL_YELLOW = MOHO.MSG_BASE + 10
LM_SelectBone.COL_GREEN = MOHO.MSG_BASE + 11
LM_SelectBone.COL_BLUE = MOHO.MSG_BASE + 12
LM_SelectBone.COL_PURPLE = MOHO.MSG_BASE + 13
LM_SelectBone.COL_TAN = MOHO.MSG_BASE + 14
LM_SelectBone.COL_PINK = MOHO.MSG_BASE + 15
LM_SelectBone.COL_TURQUOISE = MOHO.MSG_BASE + 16
LM_SelectBone.COL_CADETBLUE = MOHO.MSG_BASE + 17
LM_SelectBone.COL_CORAL = MOHO.MSG_BASE + 18
LM_SelectBone.FLIP_H = MOHO.MSG_BASE + 19
LM_SelectBone.FLIP_V = MOHO.MSG_BASE + 20
LM_SelectBone.DUMMY = MOHO.MSG_BASE + 21
LM_SelectBone.SELECTITEM = MOHO.MSG_BASE + 22
LM_SelectBone.SELECTCONTROL = MOHO.MSG_BASE + 300
function LM_SelectBone:DoLayout(moho, layout)
self.menu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
self.dlog = LM_SelectBoneDialog:new()
self.popup = LM.GUI.PopupDialog(MOHO.Localize("/Scripts/Tool/SelectBone/ConeConstraints=Bone Constraints"), true, self.DLOG_BEGIN)
self.popup:SetDialog(self.dlog)
layout:AddChild(self.popup)
self.popup = LM.GUI.PopupMenu(120, false)
self.popup:SetMenu(self.menu)
self.boneName = LM.GUI.TextControl(0, "Room For a Long Name", self.CHANGE, LM.GUI.FIELD_TEXT)
self.boneName:SetValue("")
layout:AddChild(self.boneName)
self.lockBone = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/LockBone=Lock bone"), self.LOCK)
layout:AddChild(self.lockBone)
self.lassoCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/LassoMode=Lasso mode"), self.LASSO)
layout:AddChild(self.lassoCheck)
layout:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/Color=Color:")))
self.colorMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/BoneColor=BoneColor"))
self.colorMenu:AddItem(MOHO.Localize("/Scripts/Tool/SelectBone/Purple=Purple"), 0, self.COL_PURPLE)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Blue=Blue"), 0, self.COL_BLUE)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Green=Green"), 0, self.COL_GREEN)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Yellow=Yellow"), 0, self.COL_YELLOW)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Orange=Orange"), 0, self.COL_ORANGE)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Red=Red"), 0, self.COL_RED)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Tan=Tan"), 0, self.COL_TAN)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Pink=Pink"), 0, self.COL_PINK)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Turquoise=Turquoise"), 0, self.COL_TURQUOISE)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/CadetBlue=Cadet Blue"), 0, self.COL_CADETBLUE)
self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Coral=Coral"), 0, self.COL_CORAL)
self.colorMenu:InsertItem(0, "", 0, 0)
self.colorMenu:InsertItem(0, MOHO.Localize("/Scripts/Tool/SelectBone/Plain=Plain"), 0, self.COL_PLAIN)
self.colorPopup = LM.GUI.PopupMenu(120, true)
self.colorPopup:SetMenu(self.colorMenu)
layout:AddChild(self.colorPopup)
self.labelCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ShowLabel=Show label"), self.LABEL)
layout:AddChild(self.labelCheck)
self.shyCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ShyBone=Shy bone"), self.SHY)
layout:AddChild(self.shyCheck)
else
self.labelCheck = nil
self.shyCheck = nil
end
layout:AddChild(LM.GUI.ImageButton("ScriptResources/flip_bone_h", MOHO.Localize("/Scripts/Tool/SelectBone/EndFlip=End Flip"), false, self.FLIP_H, true))
layout:AddChild(LM.GUI.ImageButton("ScriptResources/flip_bone_v", MOHO.Localize("/Scripts/Tool/SelectBone/SideFlip=Side Flip"), false, self.FLIP_V, true))
end
end
function LM_SelectBone:UpdateWidgets(moho)
end
return
end
end
local selID = skel:SelectedBoneID()
MOHO.BuildBoneMenu(self.menu, skel, self.SELECTITEM, self.DUMMY)
if (selID >= 0) then
local bone = skel:Bone(selID)
self.boneName:SetValue(bone:Name())
self.popup:Enable(true)
self.dlog.bone = bone
self.lockBone:Enable(bone.fParent >= 0)
self.lockBone:SetValue(bone.fIKLock.value)
if (self.labelCheck ~= nil) then
self.labelCheck:Enable(true)
end
if (self.shyCheck ~= nil) then
self.shyCheck:Enable(true)
end
else
self.popup:Enable(false)
self.dlog.bone = nil
self.lockBone:Enable(false)
self.lockBone:SetValue(false)
self.labelCheck:Enable(false)
end
self.shyCheck:Enable(false)
end
end
self.lassoCheck:SetValue(self.lassoMode)
self.colorMenu:UncheckAll()
self.colorMenu:SetChecked(self.COL_PLAIN, true)
self.labelCheck:SetValue(false)
end
self.shyCheck:SetValue(false)
end
local tags = bone:Tags()
if (tags == 0) then
else
end
if (tags == 1) then
self.colorMenu:SetChecked(self.COL_RED, true)
elseif (tags == 2) then
self.colorMenu:SetChecked(self.COL_ORANGE, true)
elseif (tags == 3) then
self.colorMenu:SetChecked(self.COL_YELLOW, true)
elseif (tags == 4) then
self.colorMenu:SetChecked(self.COL_GREEN, true)
elseif (tags == 5) then
self.colorMenu:SetChecked(self.COL_BLUE, true)
elseif (tags == 6) then
self.colorMenu:SetChecked(self.COL_PURPLE, true)
elseif (tags == 7) then
self.colorMenu:SetChecked(self.COL_TAN, true)
elseif (tags == 8) then
self.colorMenu:SetChecked(self.COL_PINK, true)
elseif (tags == 9) then
self.colorMenu:SetChecked(self.COL_TURQUOISE, true)
elseif (tags == 10) then
self.colorMenu:SetChecked(self.COL_CADETBLUE, true)
elseif (tags == 11) then
self.colorMenu:SetChecked(self.COL_CORAL, true)
end
if (bone:IsLabelShowing()) then
self.labelCheck:SetValue(true)
end
end
if (bone.fShy) then
self.shyCheck:SetValue(true)
end
end
break
end
end
self.colorPopup:Enable(skel:SelectedBoneID() >= 0)
self.colorPopup:Redraw()
self.dlog.document = moho.document
self.dlog.layer = moho.layer
self.dlog.layerFrame = moho.layerFrame
self.dlog.skel = skel
self.dlog:UpdateWidgets(moho)
end
function LM_SelectBone:HandleMessage(moho, view, msg)
local layer = moho.layer
end
return
end
layer = moho.layer:ControllingBoneLayer()
end
if (msg == self.CHANGE) then
if (skel:SelectedBoneID() >= 0) then
moho.document:PrepUndo(layer, true)
bone:SetName(self.boneName:Value())
skel:MakeBoneNameUnique(i)
end
end
moho:UpdateUI()
end
elseif (msg == self.LOCK) then
local lockChange = false
if (bone.fSelected and bone.fParent >= 0) then
if (self.lockBone:Value()) then
skel:LockBone(i, moho.layerFrame)
else
skel:UnlockBone(i, moho.layerFrame)
end
lockChange = true
end
end
moho.layer:UpdateCurFrame(true)
if (lockChange) then
moho:NewKeyframe(CHANNEL_BONE)
moho:NewKeyframe(CHANNEL_BONE_LOCK)
end
end
elseif (msg == self.LASSO) then
self.lassoMode = self.lassoCheck:Value()
elseif (msg >= self.COL_PLAIN and msg <= self.COL_CORAL) then
local tag = 0
if (msg == self.COL_RED) then
tag = 1
elseif (msg == self.COL_ORANGE) then
tag = 2
elseif (msg == self.COL_YELLOW) then
tag = 3
elseif (msg == self.COL_GREEN) then
tag = 4
elseif (msg == self.COL_BLUE) then
tag = 5
elseif (msg == self.COL_PURPLE) then
tag = 6
elseif (msg == self.COL_TAN) then
tag = 7
elseif (msg == self.COL_PINK) then
tag = 8
elseif (msg == self.COL_TURQUOISE) then
tag = 9
elseif (msg == self.COL_CADETBLUE) then
tag = 10
elseif (msg == self.COL_CORAL) then
tag = 11
end
local selBoneCount = 0
selBoneCount = selBoneCount + 1
end
end
if (selBoneCount > 0) then
bone:SetTags(tag)
end
end
end
moho:UpdateUI()
elseif (msg == self.LABEL) then
if (self.labelCheck:Value()) then
-- if bone labels are not showing, then turn them on now
layer:SetQualityFlags(MOHO.setbit(layer:QualityFlags(), MOHO.LDQ_LABELS))
view:SetQualityFlags(MOHO.setbit(view:QualityFlags(), MOHO.LDQ_LABELS))
end
bone:ShowLabel(self.labelCheck:Value())
end
end
end
end
elseif (msg == self.SHY) then
bone.fShy = self.shyCheck:Value()
bone.fHidden = bone.fShy
end
end
end
end
elseif (msg == self.FLIP_H) then
LM_TransformBone:FlipBones(moho, skel, true)
elseif (msg == self.FLIP_V) then
LM_TransformBone:FlipBones(moho, skel, false)
elseif (msg == self.DLOG_BEGIN) then
self.dlog.layer = layer
self.dlog.bone = skel:Bone(skel:SelectedBoneID())
else
end
elseif (msg == self.DLOG_CHANGE) then
-- Nothing really happens here - it is a message that came from the popup dialog.
-- However, the important thing is that this message then flows back into the Moho app, forcing a redraw.
elseif (msg >= self.SELECTITEM and msg < self.SELECTCONTROL) then
skel:Bone(i).fSelected = (i == msg - self.SELECTITEM)
end
moho:UpdateUI()
end
end
Most up to date is in my signature.
- davoodice2
THAT WORKED.BIG THANKS.synthsin75 wrote: ↑Wed Jul 07, 2021 10:03 pmGreat idea. I just did that myself. Have to disable wind before I can disable dynamics, but that's a much rarer task.Code: Select all
-- ************************************************** -- Provide Moho with the name of this script object -- ************************************************** ScriptName = "LM_SelectBone" -- ************************************************** -- General information about this script -- ************************************************** LM_SelectBone = {} LM_SelectBone.BASE_STR = 2285 function LM_SelectBone:Name() return "Select Bone" end function LM_SelectBone:Version() return "6.0" end function LM_SelectBone:Description() return MOHO.Localize("/Scripts/Tool/SelectBone/Description=Click to select a bone (hold <shift> or <ctrl/cmd> to select more than one bone)") end function LM_SelectBone:Creator() return "Lost Marble LLC, modded by J.Wesley Fowler (synthsin75)" end function LM_SelectBone:UILabel() return(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone")) end function LM_SelectBone:LoadPrefs(prefs) self.lassoMode = prefs:GetBool("LM_SelectBone.lassoMode", false) end function LM_SelectBone:SavePrefs(prefs) prefs:SetBool("LM_SelectBone.lassoMode", self.lassoMode) end function LM_SelectBone:ResetPrefs() self.lassoMode = false end -- ************************************************** -- Recurring values -- ************************************************** LM_SelectBone.selBoneID = -1 LM_SelectBone.selRect = LM.Rect:new_local() LM_SelectBone.previousX = 0 LM_SelectBone.previousY = 0 LM_SelectBone.isMouseDragging = false -- ************************************************** -- The guts of this script -- ************************************************** function LM_SelectBone:ShouldUseParentSkeleton(moho) if (not moho.layer:IsBoneType()) then return true end return false end function LM_SelectBone:IsEnabled(moho) local skel = moho:Skeleton() if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() end if (skel == nil) then return false end end return true end function LM_SelectBone:IsRelevant(moho) local skel = moho:Skeleton() if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() end if (skel == nil) then return false end end return true end function LM_SelectBone:OnMouseDown(moho, mouseEvent) self.isMouseDragging = true self.selRect.left = -10 self.selRect.top = -10 self.selRect.right = -5 self.selRect.bottom = -5 -- Try to select a bone by clicking on it self:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey) -- If no bone was selected, start dragging out a marquee selection local lassoMode = false self.ctrlKeySelection = false if (self.lassoMode) then if (not(mouseEvent.ctrlKey)) then lassoMode = true else self.ctrlKeySelection = true end else if (mouseEvent.ctrlKey) then lassoMode = true self.ctrlKeySelection = true end end mouseEvent.view:DrawMe() if (self.selBoneID == -1) then if (lassoMode) then self.lassoList = { { mouseEvent.startPt.x, mouseEvent.startPt.y } } self.previousX = mouseEvent.startPt.x self.previousY = mouseEvent.startPt.y else self.selRect.left = mouseEvent.startPt.x self.selRect.top = mouseEvent.startPt.y self.selRect.right = mouseEvent.pt.x self.selRect.bottom = mouseEvent.pt.y mouseEvent.view:Graphics():SelectionRect(self.selRect) end end end function LM_SelectBone:OnMouseMoved(moho, mouseEvent) --self:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey) if (self.selBoneID >= 0) then return end local lassoMode = false if (self.lassoMode) then if (not(self.ctrlKeySelection)) then lassoMode = true end else if (self.ctrlKeySelection) then lassoMode = true end end if (lassoMode) then local g = mouseEvent.view:Graphics() g:SetSmoothing(true) g:Push() local m = g:CurrentTransform() m:Invert() g:ApplyMatrix(m) g:SetColor(MOHO.MohoGlobals.SelCol) g:MoveTo(self.previousX, self.previousY) g:LineTo(mouseEvent.pt.x, mouseEvent.pt.y) g:Pop() g:SetSmoothing(false) mouseEvent.view:RefreshView() table.insert(self.lassoList, { mouseEvent.pt.x, mouseEvent.pt.y }) self.previousX = mouseEvent.pt.x self.previousY = mouseEvent.pt.y else mouseEvent.view:Graphics():SelectionRect(self.selRect) self.selRect.right = mouseEvent.pt.x self.selRect.bottom = mouseEvent.pt.y mouseEvent.view:Graphics():SelectionRect(self.selRect) mouseEvent.view:RefreshView() end mouseEvent.view:DrawMe() end function LM_SelectBone:OnMouseUp(moho, mouseEvent) if (self.selBoneID >= 0) then return end self.isMouseDragging = false local lassoMode = false if (self.lassoMode) then if (not(self.ctrlKeySelection)) then lassoMode = true end else if (self.ctrlKeySelection) then lassoMode = true end end if (lassoMode) then -- draw the finalized lasso outline local g = mouseEvent.view:Graphics() g:SetSmoothing(true) g:Push() local m = g:CurrentTransform() m:Invert() g:ApplyMatrix(m) g:SetColor(MOHO.MohoGlobals.SelCol) g:MoveTo(self.previousX, self.previousY) g:LineTo(mouseEvent.startPt.x, mouseEvent.startPt.y) g:Pop() g:SetSmoothing(false) mouseEvent.view:RefreshView() LM.Snooze(100) end -- 1 - Draw the selection shape, either a lasso or a rectangle local end1 = LM.Vector2:new_local() local end2 = LM.Vector2:new_local() local g = mouseEvent.view:Graphics() g:Clear(0, 0, 0, 0) g:Push() local m = g:CurrentTransform() m:Invert() g:ApplyMatrix(m) g:SetColor(255, 255, 255, 255) g:BeginShape() if (lassoMode) then for i = 1, #self.lassoList - 1 do end1:Set(self.lassoList[i][1], self.lassoList[i][2]) end2:Set(self.lassoList[i + 1][1], self.lassoList[i + 1][2]) g:AddLine(end1, end2) end end1:Set(self.lassoList[#self.lassoList][1], self.lassoList[#self.lassoList][2]) end2:Set(self.lassoList[1][1], self.lassoList[1][2]) g:AddLine(end1, end2) else end1:Set(mouseEvent.startPt.x, mouseEvent.startPt.y) end2:Set(mouseEvent.pt.x, mouseEvent.startPt.y) g:AddLine(end1, end2) end1:Set(end2.x, end2.y) end2:Set(mouseEvent.pt.x, mouseEvent.pt.y) g:AddLine(end1, end2) end1:Set(end2.x, end2.y) end2:Set(mouseEvent.startPt.x, mouseEvent.pt.y) g:AddLine(end1, end2) end1:Set(end2.x, end2.y) end2:Set(mouseEvent.startPt.x, mouseEvent.startPt.y) g:AddLine(end1, end2) end g:EndShape() g:Pop() -- test code to view the lasso's shape --mouseEvent.view:RefreshView() --LM.Snooze(1000) -- 2 - Do hit testing on the selection shape local v = LM.Vector2:new_local() local screenPt = LM.Point:new_local() local m = LM.Matrix:new_local() local parentSkeleton = false local skel = moho:Skeleton() moho.layer:GetFullTransform(moho.frame, m, moho.document) if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() parentSkeleton = true moho.layer:ControllingBoneLayer():GetFullTransform(moho.frame, m, moho.document) end end if (skel ~= nil) then for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if ((not bone.fHidden) and bone:IsGroupVisible()) then local boneMatrix = bone.fMovedMatrix if (moho.frame == 0) then boneMatrix = bone.fRestMatrix end for j = 0, 10 do v:Set(bone.fLength * j / 10.0, 0) boneMatrix:Transform(v) m:Transform(v) g:WorldToScreen(v, screenPt) if (g:IsFullWhite(screenPt)) then if (mouseEvent.shiftKey) then bone.fSelected = not bone.fSelected else bone.fSelected = true end break end end end end end self.lassoList = nil mouseEvent.view:DrawMe() moho:UpdateSelectedChannels() end function LM_SelectBone:Select(moho, mousePt, mouseVec, mouseView, shiftSelect, ctrlSelect) self.selBoneID = -1 local parentSkeleton = false local skel = moho:Skeleton() if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() parentSkeleton = true end if (skel == nil) then return end end local id = -1 if (parentSkeleton) then id = mouseView:PickBone(mousePt, mouseVec, moho.layer:ControllingBoneLayer(), true) else id = mouseView:PickBone(mousePt, mouseVec, moho.layer, true) end self.selBoneID = id if (shiftSelect) then if (id >= 0) then skel:Bone(id).fSelected = true end elseif (ctrlSelect) then if (id >= 0) then skel:Bone(id).fSelected = not skel:Bone(id).fSelected end else for i = 0, skel:CountBones() - 1 do skel:Bone(i).fSelected = (i == id) end end moho:UpdateBonePointSelection() mouseView:DrawMe() moho:UpdateSelectedChannels() end function LM_SelectBone:OnKeyDown(moho, keyEvent) local skel = moho:Skeleton() if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() end if (skel == nil) then return end end if (keyEvent.keyCode == LM.GUI.KEY_UP and not keyEvent.ctrlKey) then for i = 0, skel:CountBones() - 1 do if (skel:Bone(i).fSelected) then local pID = skel:Bone(i).fParent if (pID >= 0) then skel:Bone(i).fSelected = false skel:Bone(pID).fSelected = true end break end end moho:UpdateBonePointSelection() keyEvent.view:DrawMe() moho:UpdateSelectedChannels() elseif (keyEvent.keyCode == LM.GUI.KEY_DOWN and not keyEvent.ctrlKey) then for i = 0, skel:CountBones() - 1 do if (skel:Bone(i).fSelected) then local childID = -1 if (skel:CountBoneChildren(i) == 1) then childID = skel:GetFirstChildBone(i) end if (childID >= 0) then skel:Bone(i).fSelected = false skel:Bone(childID).fSelected = true end break end end moho:UpdateBonePointSelection() keyEvent.view:DrawMe() moho:UpdateSelectedChannels() elseif ((keyEvent.keyCode == LM.GUI.KEY_DELETE) or (keyEvent.keyCode == LM.GUI.KEY_BACKSPACE)) then if (moho.layer:IsBoneType() and (moho.layerFrame == 0 or not moho:DisableDrawingTools())) then local boneLayer = moho:LayerAsGroup(moho.layer) moho.document:PrepUndo(moho.layer, false) moho.document:SetDirty() keepTrying = true while keepTrying do keepTrying = false for i = 0, skel:CountBones() - 1 do if (skel:Bone(i).fSelected) then for j = 0, boneLayer:CountLayers() - 1 do boneLayer:Layer(j):DeleteParentBone(i) end skel:DeleteBone(i) keepTrying = true break end end end moho:SetCurFrame(moho.frame) -- trigger an update of all the bones in case they're undergoing a preview with the manipulate bones tool or something keyEvent.view:DrawMe() end end end function LM_SelectBone:DrawMe(moho, view) if (self.isMouseDragging) then local g = view:Graphics() local lassoMode = false if (self.lassoMode) then if (not(self.ctrlKeySelection)) then lassoMode = true end else if (self.ctrlKeySelection) then lassoMode = true end end if (lassoMode and self.lassoList) then g:SetSmoothing(true) g:Push() local m = g:CurrentTransform() m:Invert() g:ApplyMatrix(m) g:SetColor(MOHO.MohoGlobals.SelCol) g:MoveTo(self.lassoList[1][1], self.lassoList[1][2]) for i = 2, #self.lassoList do g:LineTo(self.lassoList[i][1], self.lassoList[i][2]) end g:Pop() g:SetSmoothing(false) else g:SelectionRect(self.selRect) end end end -- ************************************************** -- Bone constraints dialog -- ************************************************** local LM_SelectBoneDialog = {} function LM_SelectBoneDialog:new() local d = LM.GUI.SimpleDialog(MOHO.Localize("/Scripts/Tool/SelectBone/BoneConstraints=Bone Constraints"), LM_SelectBoneDialog) local l = d:GetLayout() l:PushV(LM.GUI.ALIGN_LEFT, 0) d.angleConstraints = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/AngleConstraints=Angle constraints:"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.angleConstraints, LM.GUI.ALIGN_LEFT) l:PushH() l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/MinMaxDegrees=Min/max (degrees)"))) d.minAngle = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT) d.minAngle:SetWheelInc(5) l:AddChild(d.minAngle) d.maxAngle = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT) d.maxAngle:SetWheelInc(5) l:AddChild(d.maxAngle) l:Pop() if (MOHO.IsMohoPro()) then l:AddPadding() d.fixedAngle = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/IndependentAngle=Independent angle"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.fixedAngle, LM.GUI.ALIGN_LEFT) l:AddPadding() l:PushH(LM.GUI.ALIGN_LEFT) l:PushV(LM.GUI.ALIGN_LEFT) d.squashScaling = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/SquashAndStretchScaling=Squash and stretch scaling"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.squashScaling, LM.GUI.ALIGN_LEFT) l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/MaximumIKStretching=Maximum IK stretching")), LM.GUI.ALIGN_LEFT) l:Pop() l:PushV(LM.GUI.ALIGN_LEFT) d.maxStretchScaling = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT) d.maxStretchScaling:SetWheelInc(0.1) l:AddChild(d.maxStretchScaling, LM.GUI.ALIGN_LEFT) d.maxAutoScaling = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT) d.maxAutoScaling:SetWheelInc(0.1) l:AddChild(d.maxAutoScaling, LM.GUI.ALIGN_LEFT) l:Pop() l:Pop() l:AddPadding() d.arcSolver = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ArcIKSolver=Arc IK solver"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.arcSolver, LM.GUI.ALIGN_LEFT) d.ignoredByIK = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/IgnoredByInverseKinematics=Ignored by inverse kinematics"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.ignoredByIK, LM.GUI.ALIGN_LEFT) l:AddPadding() l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/Target=Target:")), LM.GUI.ALIGN_LEFT) l:PushH() d.targetMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone")) d.targetPopup = LM.GUI.PopupMenu(128, true) d.targetPopup:SetMenu(d.targetMenu) l:AddChild(d.targetPopup) l:Pop() end l:AddPadding() l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/AngleControlBone=Angle control bone:")), LM.GUI.ALIGN_LEFT) l:PushH() d.acMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone")) d.acPopup = LM.GUI.PopupMenu(128, true) d.acPopup:SetMenu(d.acMenu) l:AddChild(d.acPopup) d.angleControl = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT) l:AddChild(d.angleControl) l:Pop() l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/PositionControlBone=Position control bone:")), LM.GUI.ALIGN_LEFT) l:PushH() d.pcMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone")) d.pcPopup = LM.GUI.PopupMenu(128, true) d.pcPopup:SetMenu(d.pcMenu) l:AddChild(d.pcPopup) d.posControlX = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT) l:AddChild(d.posControlX) d.posControlY = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT) l:AddChild(d.posControlY) l:Pop() l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/ScaleControlBone=Scale control bone:")), LM.GUI.ALIGN_LEFT) l:PushH() d.scMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone")) d.scPopup = LM.GUI.PopupMenu(128, true) d.scPopup:SetMenu(d.scMenu) l:AddChild(d.scPopup) d.scaleControl = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT) l:AddChild(d.scaleControl) l:Pop() d.boneDynamics = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/BoneDynamics=Bone dynamics:"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.boneDynamics, LM.GUI.ALIGN_LEFT) l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/TorqueSpringDampingForce=Torque force / Spring force / Damping force")), LM.GUI.ALIGN_LEFT) l:PushH() d.torque = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT) d.torque:SetWheelInc(0.1) l:AddChild(d.torque) d.spring = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT) d.spring:SetWheelInc(0.1) l:AddChild(d.spring) d.damping = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT) d.damping:SetWheelInc(0.1) l:AddChild(d.damping) d.windDynamics = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/Wind=Wind"), LM_SelectBone.DLOG_CHANGE) l:AddChild(d.windDynamics) l:Pop() l:PushH(LM.GUI.ALIGN_RIGHT, 0) l:AddChild(LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectBone/Close=Close"), LM.GUI.MSG_CANCEL)) l:Pop() l:Pop() return d end function LM_SelectBoneDialog:UpdateWidgets(moho) if (self.document and self.layer and self.skel and self.bone) then self.angleConstraints:Enable(true) if (MOHO.IsMohoPro()) then self.targetPopup:Enable(true) end self.acPopup:Enable(true) self.pcPopup:Enable(true) self.scPopup:Enable(true) self.boneDynamics:Enable(true) self.angleConstraints:SetValue(self.bone.fConstraints) self.minAngle:SetValue(math.deg(self.bone.fMinConstraint)) self.maxAngle:SetValue(math.deg(self.bone.fMaxConstraint)) self.minAngle:Enable(self.bone.fConstraints) self.maxAngle:Enable(self.bone.fConstraints) local id = self.skel:BoneID(self.bone) if (MOHO.IsMohoPro()) then self.fixedAngle:Enable(true) self.fixedAngle:SetValue(self.bone.fFixedAngle) self.squashScaling:Enable(true) self.squashScaling:SetValue(self.bone.fScalingMode == 2) self.maxStretchScaling:Enable(self.bone.fScalingMode == 2) self.maxStretchScaling:SetValue(self.bone.fSquashStretchScaling) self.maxAutoScaling:Enable(true) self.maxAutoScaling:SetValue(self.bone.fMaxAutoScaling) self.arcSolver:Enable(true) self.arcSolver:SetValue(self.bone:IsArcSolverEnabled()) self.ignoredByIK:Enable(true) self.ignoredByIK:SetValue(self.bone.fIgnoredByIK) MOHO.BuildBoneChoiceMenu(self.targetMenu, self.skel, LM_SelectBone.SELECTCONTROL, id) if (self.skel:TargetOfBone(id, self.layerFrame) < 0) then self.targetMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true) else self.targetMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.skel:TargetOfBone(id, self.layerFrame), true) end self.targetPopup:Redraw() end MOHO.BuildBoneChoiceMenu(self.acMenu, self.skel, LM_SelectBone.SELECTCONTROL, id) if (self.bone.fAngleControlParent < 0) then self.acMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true) else self.acMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fAngleControlParent, true) end self.acPopup:Redraw() MOHO.BuildBoneChoiceMenu(self.pcMenu, self.skel, LM_SelectBone.SELECTCONTROL, id) if (self.bone.fPosControlParent < 0) then self.pcMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true) else self.pcMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fPosControlParent, true) end self.pcPopup:Redraw() MOHO.BuildBoneChoiceMenu(self.scMenu, self.skel, LM_SelectBone.SELECTCONTROL, id) if (self.bone.fScaleControlParent < 0) then self.scMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true) else self.scMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fScaleControlParent, true) end self.scPopup:Redraw() self.angleControl:Enable(self.bone.fAngleControlParent >= 0) self.posControlX:Enable(self.bone.fPosControlParent >= 0) self.posControlY:Enable(self.bone.fPosControlParent >= 0) self.scaleControl:Enable(self.bone.fScaleControlParent >= 0) self.angleControl:SetValue(self.bone.fAngleControlScale) self.posControlX:SetValue(self.bone.fPosControlScale.x) self.posControlY:SetValue(self.bone.fPosControlScale.y) self.scaleControl:SetValue(self.bone.fScaleControlScale) self.boneDynamics:SetValue(self.bone.fBoneDynamics.value) self.windDynamics:SetValue(self.bone.fWindDynamics) self.torque:SetValue(self.bone.fTorqueForce) self.spring:SetValue(self.bone.fSpringForce) self.damping:SetValue(self.bone.fDampingForce) --[syn] self.windDynamics:Enable(self.bone.fBoneDynamics.value) --[[syn]] self.windDynamics:Enable(true) self.torque:Enable(self.bone.fBoneDynamics.value) self.spring:Enable(self.bone.fBoneDynamics.value) self.damping:Enable(self.bone.fBoneDynamics.value) else self.angleConstraints:Enable(false) self.minAngle:Enable(false) self.maxAngle:Enable(false) if (MOHO.IsMohoPro()) then self.fixedAngle:Enable(false) self.squashScaling:Enable(false) self.maxStretchScaling:Enable(false) self.maxAutoScaling:Enable(false) self.arcSolver:Enable(false) self.ignoredByIK:Enable(false) self.targetPopup:Enable(false) end self.acPopup:Enable(false) self.angleControl:Enable(false) self.pcPopup:Enable(false) self.posControlX:Enable(false) self.posControlY:Enable(false) self.scPopup:Enable(false) self.scaleControl:Enable(false) self.boneDynamics:Enable(false) self.windDynamics:Enable(false) self.torque:Enable(false) self.spring:Enable(false) self.damping:Enable(false) end end function LM_SelectBoneDialog:OnOK() self:HandleMessage(LM_SelectBone.DLOG_CHANGE) -- send this final message in case the user is in the middle of editing some value end function LM_SelectBoneDialog:HandleMessage(msg) if (not (self.document and self.layer and self.skel and self.bone)) then return end if (msg == LM_SelectBone.DLOG_CHANGE) then self.document:PrepUndo(self.layer, true) self.document:SetDirty() for i = 0, self.skel:CountBones() - 1 do local bone = self.skel:Bone(i) if (bone.fSelected) then bone.fConstraints = self.angleConstraints:Value() bone.fMinConstraint = math.rad(self.minAngle:FloatValue()) bone.fMaxConstraint = math.rad(self.maxAngle:FloatValue()) if (self.minAngle:IsEnabled() ~= bone.fConstraints) then self.minAngle:Enable(bone.fConstraints) self.maxAngle:Enable(bone.fConstraints) end if (MOHO.IsMohoPro()) then bone.fFixedAngle = self.fixedAngle:Value() if (self.squashScaling:Value()) then bone.fScalingMode = 2 else bone.fScalingMode = 0 end bone.fSquashStretchScaling = self.maxStretchScaling:FloatValue() if (bone.fSquashStretchScaling < 0.01) then bone.fSquashStretchScaling = 0.01 self.maxStretchScaling:SetValue(bone.fSquashStretchScaling) end if (bone.fSquashStretchScaling > 100.0) then bone.fSquashStretchScaling = 100.0 self.maxStretchScaling:SetValue(bone.fSquashStretchScaling) end self.maxStretchScaling:Enable(self.bone.fScalingMode == 2) bone.fMaxAutoScaling = self.maxAutoScaling:FloatValue() if (bone.fMaxAutoScaling < 0.999999) then bone.fMaxAutoScaling = 1.0 self.maxAutoScaling:SetValue(bone.fMaxAutoScaling) end bone:EnableArcSolver(self.arcSolver:Value()) bone.fIgnoredByIK = self.ignoredByIK:Value() end bone.fAngleControlScale = self.angleControl:FloatValue() bone.fPosControlScale.x = self.posControlX:FloatValue() bone.fPosControlScale.y = self.posControlY:FloatValue() bone.fScaleControlScale = self.scaleControl:FloatValue() --syn\/ if (self.windDynamics:Value()) then self.boneDynamics:SetValue(true) end --syn/\ if (bone.fBoneDynamics.value ~= self.boneDynamics:Value()) then bone.fBoneDynamics.value = self.boneDynamics:Value() bone.fBoneDynamics:StoreValue() self.layer:UpdateCurFrame(true) MOHO.NewKeyframe(CHANNEL_BONE_DYNAMICS) MOHO.NewKeyframe(CHANNEL_BONE_SEL_DYNAMICS) end if (bone.fWindDynamics ~= self.windDynamics:Value()) then bone.fWindDynamics = self.windDynamics:Value() local updateDynamicsValues = false if (bone.fWindDynamics) then if (math.abs(bone.fTorqueForce - 2.0) < 0.001 and math.abs(bone.fSpringForce - 2.0) < 0.001 and math.abs(bone.fDampingForce - 1.0) < 0.001) then updateDynamicsValues = true bone.fTorqueForce = 0.0 bone.fSpringForce = 1.0 bone.fDampingForce = 1.0 end else if (math.abs(bone.fTorqueForce - 0.0) < 0.001 and math.abs(bone.fSpringForce - 1.0) < 0.001 and math.abs(bone.fDampingForce - 1.0) < 0.001) then updateDynamicsValues = true bone.fTorqueForce = 2.0 bone.fSpringForce = 2.0 bone.fDampingForce = 1.0 end end if (updateDynamicsValues) then self.torque:SetValue(bone.fTorqueForce) self.spring:SetValue(bone.fSpringForce) self.damping:SetValue(bone.fDampingForce) end else bone.fTorqueForce = self.torque:FloatValue() bone.fSpringForce = self.spring:FloatValue() bone.fDampingForce = self.damping:FloatValue() end if (self.torque:IsEnabled() ~= bone.fBoneDynamics.value) then --[syn] self.windDynamics:Enable(bone.fBoneDynamics.value) self.torque:Enable(bone.fBoneDynamics.value) self.spring:Enable(bone.fBoneDynamics.value) self.damping:Enable(bone.fBoneDynamics.value) end end end self.layer:UpdateCurFrame() MOHO.Redraw() elseif (msg >= LM_SelectBone.SELECTCONTROL and msg <= LM_SelectBone.SELECTCONTROL + 1000) then self.document:PrepUndo(self.layer, true) self.document:SetDirty() for i = 0, self.skel:CountBones() - 1 do local bone = self.skel:Bone(i) if (bone.fSelected) then local ctrlID = -1 if (MOHO.IsMohoPro()) then ctrlID = self.targetMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1) if (ctrlID ~= self.skel:BoneID(bone) and ctrlID ~= bone.fTargetBone:GetValue(self.layerFrame)) then bone.fTargetBone:SetValue(self.layerFrame, ctrlID) MOHO.NewKeyframe(CHANNEL_BONE_TARGET) MOHO.NewKeyframe(CHANNEL_BONE_SEL_TARGET) end end ctrlID = self.acMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1) if (ctrlID ~= self.skel:BoneID(bone)) then bone.fAngleControlParent = ctrlID end ctrlID = self.pcMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1) if (ctrlID ~= self.skel:BoneID(bone)) then bone.fPosControlParent = ctrlID end ctrlID = self.scMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1) if (ctrlID ~= self.skel:BoneID(bone)) then bone.fScaleControlParent = ctrlID end self.angleControl:Enable(bone.fAngleControlParent >= 0) self.posControlX:Enable(bone.fPosControlParent >= 0) self.posControlY:Enable(bone.fPosControlParent >= 0) self.scaleControl:Enable(bone.fScaleControlParent >= 0) end end self.layer:UpdateCurFrame() MOHO.Redraw() end end -- ************************************************** -- Tool options - create and respond to tool's UI -- ************************************************** LM_SelectBone.CHANGE = MOHO.MSG_BASE LM_SelectBone.DLOG_BEGIN = MOHO.MSG_BASE + 1 LM_SelectBone.DLOG_CHANGE = MOHO.MSG_BASE + 2 LM_SelectBone.LOCK = MOHO.MSG_BASE + 3 LM_SelectBone.LASSO = MOHO.MSG_BASE + 4 LM_SelectBone.LABEL = MOHO.MSG_BASE + 5 LM_SelectBone.SHY = MOHO.MSG_BASE + 6 LM_SelectBone.COL_PLAIN = MOHO.MSG_BASE + 7 LM_SelectBone.COL_RED = MOHO.MSG_BASE + 8 LM_SelectBone.COL_ORANGE = MOHO.MSG_BASE + 9 LM_SelectBone.COL_YELLOW = MOHO.MSG_BASE + 10 LM_SelectBone.COL_GREEN = MOHO.MSG_BASE + 11 LM_SelectBone.COL_BLUE = MOHO.MSG_BASE + 12 LM_SelectBone.COL_PURPLE = MOHO.MSG_BASE + 13 LM_SelectBone.COL_TAN = MOHO.MSG_BASE + 14 LM_SelectBone.COL_PINK = MOHO.MSG_BASE + 15 LM_SelectBone.COL_TURQUOISE = MOHO.MSG_BASE + 16 LM_SelectBone.COL_CADETBLUE = MOHO.MSG_BASE + 17 LM_SelectBone.COL_CORAL = MOHO.MSG_BASE + 18 LM_SelectBone.FLIP_H = MOHO.MSG_BASE + 19 LM_SelectBone.FLIP_V = MOHO.MSG_BASE + 20 LM_SelectBone.DUMMY = MOHO.MSG_BASE + 21 LM_SelectBone.SELECTITEM = MOHO.MSG_BASE + 22 LM_SelectBone.SELECTCONTROL = MOHO.MSG_BASE + 300 function LM_SelectBone:DoLayout(moho, layout) self.menu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone")) self.dlog = LM_SelectBoneDialog:new() self.popup = LM.GUI.PopupDialog(MOHO.Localize("/Scripts/Tool/SelectBone/ConeConstraints=Bone Constraints"), true, self.DLOG_BEGIN) self.popup:SetDialog(self.dlog) layout:AddChild(self.popup) self.popup = LM.GUI.PopupMenu(120, false) self.popup:SetMenu(self.menu) layout:AddChild(self.popup) self.boneName = LM.GUI.TextControl(0, "Room For a Long Name", self.CHANGE, LM.GUI.FIELD_TEXT) self.boneName:SetValue("") layout:AddChild(self.boneName) self.lockBone = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/LockBone=Lock bone"), self.LOCK) layout:AddChild(self.lockBone) self.lassoCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/LassoMode=Lasso mode"), self.LASSO) layout:AddChild(self.lassoCheck) layout:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/Color=Color:"))) self.colorMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/BoneColor=BoneColor")) self.colorMenu:AddItem(MOHO.Localize("/Scripts/Tool/SelectBone/Purple=Purple"), 0, self.COL_PURPLE) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Blue=Blue"), 0, self.COL_BLUE) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Green=Green"), 0, self.COL_GREEN) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Yellow=Yellow"), 0, self.COL_YELLOW) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Orange=Orange"), 0, self.COL_ORANGE) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Red=Red"), 0, self.COL_RED) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Tan=Tan"), 0, self.COL_TAN) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Pink=Pink"), 0, self.COL_PINK) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Turquoise=Turquoise"), 0, self.COL_TURQUOISE) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/CadetBlue=Cadet Blue"), 0, self.COL_CADETBLUE) self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Coral=Coral"), 0, self.COL_CORAL) self.colorMenu:InsertItem(0, "", 0, 0) self.colorMenu:InsertItem(0, MOHO.Localize("/Scripts/Tool/SelectBone/Plain=Plain"), 0, self.COL_PLAIN) self.colorPopup = LM.GUI.PopupMenu(120, true) self.colorPopup:SetMenu(self.colorMenu) layout:AddChild(self.colorPopup) if (MOHO.IsMohoPro()) then self.labelCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ShowLabel=Show label"), self.LABEL) layout:AddChild(self.labelCheck) self.shyCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ShyBone=Shy bone"), self.SHY) layout:AddChild(self.shyCheck) else self.labelCheck = nil self.shyCheck = nil end if (MOHO.IsMohoPro()) then layout:AddChild(LM.GUI.ImageButton("ScriptResources/flip_bone_h", MOHO.Localize("/Scripts/Tool/SelectBone/EndFlip=End Flip"), false, self.FLIP_H, true)) layout:AddChild(LM.GUI.ImageButton("ScriptResources/flip_bone_v", MOHO.Localize("/Scripts/Tool/SelectBone/SideFlip=Side Flip"), false, self.FLIP_V, true)) end end function LM_SelectBone:UpdateWidgets(moho) local skel = moho:Skeleton() if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() end if (skel == nil) then return end end local selID = skel:SelectedBoneID() MOHO.BuildBoneMenu(self.menu, skel, self.SELECTITEM, self.DUMMY) if (selID >= 0) then local bone = skel:Bone(selID) self.boneName:SetValue(bone:Name()) self.popup:Enable(true) self.dlog.bone = bone self.lockBone:Enable(bone.fParent >= 0) self.lockBone:SetValue(bone.fIKLock.value) if (self.labelCheck ~= nil) then self.labelCheck:Enable(true) end if (self.shyCheck ~= nil) then self.shyCheck:Enable(true) end else self.boneName:SetValue("") self.popup:Enable(false) self.dlog.bone = nil self.lockBone:Enable(false) self.lockBone:SetValue(false) if (self.labelCheck ~= nil) then self.labelCheck:Enable(false) end if (self.shyCheck ~= nil) then self.shyCheck:Enable(false) end end self.lassoCheck:SetValue(self.lassoMode) self.colorMenu:UncheckAll() self.colorMenu:SetChecked(self.COL_PLAIN, true) if (self.labelCheck ~= nil) then self.labelCheck:SetValue(false) end if (self.shyCheck ~= nil) then self.shyCheck:SetValue(false) end for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected) then local tags = bone:Tags() if (tags == 0) then else self.colorMenu:UncheckAll() end if (tags == 1) then self.colorMenu:SetChecked(self.COL_RED, true) elseif (tags == 2) then self.colorMenu:SetChecked(self.COL_ORANGE, true) elseif (tags == 3) then self.colorMenu:SetChecked(self.COL_YELLOW, true) elseif (tags == 4) then self.colorMenu:SetChecked(self.COL_GREEN, true) elseif (tags == 5) then self.colorMenu:SetChecked(self.COL_BLUE, true) elseif (tags == 6) then self.colorMenu:SetChecked(self.COL_PURPLE, true) elseif (tags == 7) then self.colorMenu:SetChecked(self.COL_TAN, true) elseif (tags == 8) then self.colorMenu:SetChecked(self.COL_PINK, true) elseif (tags == 9) then self.colorMenu:SetChecked(self.COL_TURQUOISE, true) elseif (tags == 10) then self.colorMenu:SetChecked(self.COL_CADETBLUE, true) elseif (tags == 11) then self.colorMenu:SetChecked(self.COL_CORAL, true) end if (self.labelCheck ~= nil) then if (bone:IsLabelShowing()) then self.labelCheck:SetValue(true) end end if (self.shyCheck ~= nil) then if (bone.fShy) then self.shyCheck:SetValue(true) end end break end end self.colorPopup:Enable(skel:SelectedBoneID() >= 0) self.colorPopup:Redraw() self.dlog.document = moho.document self.dlog.layer = moho.layer self.dlog.layerFrame = moho.layerFrame self.dlog.skel = skel self.dlog:UpdateWidgets(moho) end function LM_SelectBone:HandleMessage(moho, view, msg) local skel = moho:Skeleton() local layer = moho.layer if (skel == nil) then if (self:ShouldUseParentSkeleton(moho)) then skel = moho:ParentSkeleton() end if (skel == nil) then return end layer = moho.layer:ControllingBoneLayer() end if (msg == self.CHANGE) then if (skel:SelectedBoneID() >= 0) then moho.document:PrepUndo(layer, true) moho.document:SetDirty() for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected) then bone:SetName(self.boneName:Value()) skel:MakeBoneNameUnique(i) end end moho:UpdateUI() end elseif (msg == self.LOCK) then if (skel:SelectedBoneID() >= 0) then local lockChange = false moho.document:PrepUndo(layer, true) moho.document:SetDirty() for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected and bone.fParent >= 0) then if (self.lockBone:Value()) then skel:LockBone(i, moho.layerFrame) else skel:UnlockBone(i, moho.layerFrame) end lockChange = true end end moho.layer:UpdateCurFrame(true) if (lockChange) then moho:NewKeyframe(CHANNEL_BONE) moho:NewKeyframe(CHANNEL_BONE_LOCK) end end elseif (msg == self.LASSO) then self.lassoMode = self.lassoCheck:Value() elseif (msg >= self.COL_PLAIN and msg <= self.COL_CORAL) then local tag = 0 if (msg == self.COL_RED) then tag = 1 elseif (msg == self.COL_ORANGE) then tag = 2 elseif (msg == self.COL_YELLOW) then tag = 3 elseif (msg == self.COL_GREEN) then tag = 4 elseif (msg == self.COL_BLUE) then tag = 5 elseif (msg == self.COL_PURPLE) then tag = 6 elseif (msg == self.COL_TAN) then tag = 7 elseif (msg == self.COL_PINK) then tag = 8 elseif (msg == self.COL_TURQUOISE) then tag = 9 elseif (msg == self.COL_CADETBLUE) then tag = 10 elseif (msg == self.COL_CORAL) then tag = 11 end local selBoneCount = 0 for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected) then selBoneCount = selBoneCount + 1 end end if (selBoneCount > 0) then moho.document:PrepUndo(layer, true) moho.document:SetDirty() for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected) then bone:SetTags(tag) end end moho.layer:UpdateCurFrame(true) end moho:UpdateUI() elseif (msg == self.LABEL) then if (self.labelCheck ~= nil) then if (skel:SelectedBoneID() >= 0) then moho.document:PrepUndo(layer, true) moho.document:SetDirty() if (self.labelCheck:Value()) then -- if bone labels are not showing, then turn them on now layer:SetQualityFlags(MOHO.setbit(layer:QualityFlags(), MOHO.LDQ_LABELS)) view:SetQualityFlags(MOHO.setbit(view:QualityFlags(), MOHO.LDQ_LABELS)) end for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected) then bone:ShowLabel(self.labelCheck:Value()) end end end end elseif (msg == self.SHY) then if (self.shyCheck ~= nil) then if (skel:SelectedBoneID() >= 0) then moho.document:PrepUndo(layer, true) moho.document:SetDirty() for i = 0, skel:CountBones() - 1 do local bone = skel:Bone(i) if (bone.fSelected) then bone.fShy = self.shyCheck:Value() bone.fHidden = bone.fShy end end end end elseif (msg == self.FLIP_H) then LM_TransformBone:FlipBones(moho, skel, true) elseif (msg == self.FLIP_V) then LM_TransformBone:FlipBones(moho, skel, false) elseif (msg == self.DLOG_BEGIN) then self.dlog.document = moho.document self.dlog.layer = layer self.dlog.layerFrame = moho.layerFrame self.dlog.skel = skel if (skel:SelectedBoneID() >= 0) then self.dlog.bone = skel:Bone(skel:SelectedBoneID()) else self.dlog.bone = nil end elseif (msg == self.DLOG_CHANGE) then -- Nothing really happens here - it is a message that came from the popup dialog. -- However, the important thing is that this message then flows back into the Moho app, forcing a redraw. elseif (msg >= self.SELECTITEM and msg < self.SELECTCONTROL) then for i = 0, skel:CountBones() - 1 do skel:Bone(i).fSelected = (i == msg - self.SELECTITEM) end moho:UpdateBonePointSelection() moho:UpdateUI() end endMost up to date is in my signature.
- davoodice2
Re: change parameters for multiple bones
UPDATE:
mod bone select tool works at frame 0 only.
when press close button in bone select options box, moho makes change to all bone settings. i want just close window.
That mod was only to allow enabling wind directly, not changing individual settings of multiple selected bones.
Sorry if that confused you.
Like I said earlier, since I have no need for that myself, I'd have to charge to write it.
- davoodice2
Thnks.if you wish please write a new tool in your free time if its possible.synthsin75 wrote: ↑Wed Jul 14, 2021 2:30 pm That mod was only to allow enabling wind directly, not changing individual settings of multiple selected bones.
No, I just said I don't need such a tool. Why on earth would I waste my free time writing it?davoodice2 wrote: ↑Wed Jul 14, 2021 11:30 pmThnks.if you wish please write a new tool in your free time if its possible.synthsin75 wrote: ↑Wed Jul 14, 2021 2:30 pm That mod was only to allow enabling wind directly, not changing individual settings of multiple selected bones.
