change parameters for multiple bones
davoodice2
Post by davoodice2 »
Hi
for example I have some bones with different setting. some of theme have bone angle limit and some other have target bone. now when I select all bones and activate independent angle, all bones settings change and my target bones and angle limit will be set for all or deactivate for all.
normally it must changes current parameter.
SimplSam
Re: change parameters for multiple bones
Post by SimplSam »
Yes it would be better if you could change just the individual parameters without all/most settings being applied to all selected bones.
The select bone tool could be modded to only change the attributes that change, but I have no need for that myself.
Oh wow, yes I have dreamed of a way to do this but for the life of me couldn't figure out how to implement this. The logic hurts my head.
How would the tool "know" which parameter to change on which bone if they are all different?
An example:
You select 10 bones. They all have different angle targets to different bones so you don't want to change those because they are all different.
As an example, let's say you only want to change the angle limit for the selected bones and ignore all the other settings.
The logic is tricky. You would have to make a list of all the bones parameters ALL OF THE PARAMETERS and compare all of each bones parameters to each other to see what is different. Then make another list to compare any changes made in the bone edit window and only apply what changed to each bone leaving the other parameters the same... yikes... head is spinning again. :)
SimplSam
Post by SimplSam »
synthsin75 wrote: Wed Jul 07, 2021 6:51 pm The select bone tool could be modded to only change the attributes that change, but I have no need for that myself.
p.s. Quite embarrassing, but I actually forgot that this was scripted !!!! :oops:
heyvern wrote: Wed Jul 07, 2021 7:32 pm ...
The logic is tricky. You would have to make a list of all the bones parameters ALL OF THE PARAMETERS and compare all of each bones parameters ...
I don't think you need to do all that. At the moment the script uses a single change Message DLOG_CHANGE for all input property fields. Instead it could use individual Message & handler logic to set relevant properties.
One thing I am definitely going to change is the Wind enable switch (checkbox) - so that it can auto-enable Bone Dynamics - in a single click. I get irritated having to enable Dynamics and then enable Wind (Lazy me).
Oh wow, okay must look at that. So the bone dialog just sets everything to be updated and instead you could simply evaluate ONLY things THAT CHANGED. Cool beans, yes will look at that next chance I get.
p.s. I am just now getting the hang of the changes in the scripting interface since the last time I did any massive scripting. YIKES! OUCH! It HURTS! :D
Is there an updated reference? There use to be a text file with all the scripting references for the current version. It was a bare minimum, some sort of exported text didn't have explanations or anything just basic list of stuff. Couldn't find anything like that with 13.5.
SimplSam wrote: Wed Jul 07, 2021 8:15 pm One thing I am definitely going to change is the Wind enable switch (checkbox) - so that it can auto-enable Bone Dynamics - in a single click. I get irritated having to enable Dynamics and then enable Wind (Lazy me).
Great idea. I just did that myself. Have to disable wind before I can disable dynamics, but that's a much rarer task.
-- Provide Moho with the name of this script object
ScriptName = "LM_SelectBone"
LM_SelectBone = {}
LM_SelectBone.BASE_STR = 2285
function LM_SelectBone:Name()
	return "Select Bone"
end
function LM_SelectBone:Version()
	return "6.0"
end
function LM_SelectBone:Description()
	return MOHO.Localize("/Scripts/Tool/SelectBone/Description=Click to select a bone (hold <shift> or <ctrl/cmd> to select more than one bone)")
end
function LM_SelectBone:Creator()
	return "Lost Marble LLC, modded by J.Wesley Fowler (synthsin75)"
end
function LM_SelectBone:UILabel()
	return(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
end
function LM_SelectBone:LoadPrefs(prefs)
	self.lassoMode = prefs:GetBool("LM_SelectBone.lassoMode", false)
end
function LM_SelectBone:SavePrefs(prefs)
	prefs:SetBool("LM_SelectBone.lassoMode", self.lassoMode)
end
function LM_SelectBone:ResetPrefs()
	self.lassoMode = false
end
-- Recurring values
LM_SelectBone.selBoneID = -1
LM_SelectBone.selRect = LM.Rect:new_local()
LM_SelectBone.previousX = 0
LM_SelectBone.previousY = 0
LM_SelectBone.isMouseDragging = false
-- The guts of this script
function LM_SelectBone:ShouldUseParentSkeleton(moho)
	if (not moho.layer:IsBoneType()) then
		return true
	end
	return false
end
function LM_SelectBone:IsEnabled(moho)
	local skel = moho:Skeleton()
	if (skel == nil) then
		if (self:ShouldUseParentSkeleton(moho)) then
			skel = moho:ParentSkeleton()
		end
			return false
		end
	end
	return true
end
function LM_SelectBone:IsRelevant(moho)
		end
			return false
		end
	end
	return true
end
function LM_SelectBone:OnMouseDown(moho, mouseEvent)
	self.isMouseDragging = true
	self.selRect.left = -10
	self.selRect.top = -10
	self.selRect.right = -5
	self.selRect.bottom = -5
	-- Try to select a bone by clicking on it
	self:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey)
	-- If no bone was selected, start dragging out a marquee selection
	local lassoMode = false
	self.ctrlKeySelection = false
	if (self.lassoMode) then
		if (not(mouseEvent.ctrlKey)) then
			lassoMode = true
		else
			self.ctrlKeySelection = true
		end
	else
		if (mouseEvent.ctrlKey) then
			lassoMode = true
		end
	end
	mouseEvent.view:DrawMe()
	if (self.selBoneID == -1) then
		if (lassoMode) then
			self.lassoList = { { mouseEvent.startPt.x, mouseEvent.startPt.y } }
			self.previousX = mouseEvent.startPt.x
			self.previousY = mouseEvent.startPt.y
		else
			self.selRect.left = mouseEvent.startPt.x
			self.selRect.top = mouseEvent.startPt.y
			self.selRect.right = mouseEvent.pt.x
			self.selRect.bottom = mouseEvent.pt.y
			mouseEvent.view:Graphics():SelectionRect(self.selRect)
		end
	end
end
function LM_SelectBone:OnMouseMoved(moho, mouseEvent)
	--self:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey)
	if (self.selBoneID >= 0) then
		return
	end
		if (not(self.ctrlKeySelection)) then
			lassoMode = true
		end
	else
		if (self.ctrlKeySelection) then
			lassoMode = true
		end
	end
	if (lassoMode) then
		local g = mouseEvent.view:Graphics()
		g:SetSmoothing(true)
		g:Push()
		local m = g:CurrentTransform()
		m:Invert()
		g:ApplyMatrix(m)
		g:SetColor(MOHO.MohoGlobals.SelCol)
		g:MoveTo(self.previousX, self.previousY)
		g:LineTo(mouseEvent.pt.x, mouseEvent.pt.y)
		g:Pop()
		g:SetSmoothing(false)
		mouseEvent.view:RefreshView()
		table.insert(self.lassoList, { mouseEvent.pt.x, mouseEvent.pt.y })
		self.previousX = mouseEvent.pt.x
		self.previousY = mouseEvent.pt.y
	else
	end
end
function LM_SelectBone:OnMouseUp(moho, mouseEvent)
		return
	end
	self.isMouseDragging = false
			lassoMode = true
		end
	else
			lassoMode = true
		end
	end
	if (lassoMode) then
		-- draw the finalized lasso outline
		g:Push()
		m:Invert()
		g:ApplyMatrix(m)
		g:LineTo(mouseEvent.startPt.x, mouseEvent.startPt.y)
		g:Pop()
		LM.Snooze(100)
	end
	-- 1 - Draw the selection shape, either a lasso or a rectangle
	local end1 = LM.Vector2:new_local()
	local end2 = LM.Vector2:new_local()
	g:Clear(0, 0, 0, 0)
	g:Push()
	m:Invert()
	g:ApplyMatrix(m)
	g:SetColor(255, 255, 255, 255)
	g:BeginShape()
	if (lassoMode) then
		for i = 1, #self.lassoList - 1 do
			end1:Set(self.lassoList[i][1], self.lassoList[i][2])
			end2:Set(self.lassoList[i + 1][1], self.lassoList[i + 1][2])
			g:AddLine(end1, end2)
		end
		end1:Set(self.lassoList[#self.lassoList][1], self.lassoList[#self.lassoList][2])
		end2:Set(self.lassoList[1][1], self.lassoList[1][2])
	else
		end1:Set(mouseEvent.startPt.x, mouseEvent.startPt.y)
		end2:Set(mouseEvent.pt.x, mouseEvent.startPt.y)
		end1:Set(end2.x, end2.y)
		end2:Set(mouseEvent.pt.x, mouseEvent.pt.y)
		end2:Set(mouseEvent.startPt.x, mouseEvent.pt.y)
		end2:Set(mouseEvent.startPt.x, mouseEvent.startPt.y)
	end
	g:EndShape()
	g:Pop()
	-- test code to view the lasso's shape
	--mouseEvent.view:RefreshView()
	--LM.Snooze(1000)
	-- 2 - Do hit testing on the selection shape
	local v = LM.Vector2:new_local()
	local screenPt = LM.Point:new_local()
	local m = LM.Matrix:new_local()
	local parentSkeleton = false
	moho.layer:GetFullTransform(moho.frame, m, moho.document)
			parentSkeleton = true
			moho.layer:ControllingBoneLayer():GetFullTransform(moho.frame, m, moho.document)
		end
	end
	if (skel ~= nil) then
		for i = 0, skel:CountBones() - 1 do
			local bone = skel:Bone(i)
			if ((not bone.fHidden) and bone:IsGroupVisible()) then
				local boneMatrix = bone.fMovedMatrix
				if (moho.frame == 0) then
					boneMatrix = bone.fRestMatrix
				end
				for j = 0, 10 do
					v:Set(bone.fLength * j / 10.0, 0)
					boneMatrix:Transform(v)
					m:Transform(v)
					g:WorldToScreen(v, screenPt)
					if (g:IsFullWhite(screenPt)) then
						if (mouseEvent.shiftKey) then
							bone.fSelected = not bone.fSelected
						else
							bone.fSelected = true
						end
						break
					end
				end
			end
		end
	end
	self.lassoList = nil
	moho:UpdateSelectedChannels()
end
function LM_SelectBone:Select(moho, mousePt, mouseVec, mouseView, shiftSelect, ctrlSelect)
	self.selBoneID = -1
		end
			return
		end
	end
	local id = -1
	if (parentSkeleton) then
		id = mouseView:PickBone(mousePt, mouseVec, moho.layer:ControllingBoneLayer(), true)
	else
		id = mouseView:PickBone(mousePt, mouseVec, moho.layer, true)
	end
	self.selBoneID = id
	if (shiftSelect) then
		if (id >= 0) then
			skel:Bone(id).fSelected = true
		end
	elseif (ctrlSelect) then
		if (id >= 0) then
			skel:Bone(id).fSelected = not skel:Bone(id).fSelected
		end
	else
			skel:Bone(i).fSelected = (i == id)
		end
	end
	moho:UpdateBonePointSelection()
	mouseView:DrawMe()
end
function LM_SelectBone:OnKeyDown(moho, keyEvent)
		end
			return
		end
	end
	if (keyEvent.keyCode == LM.GUI.KEY_UP and not keyEvent.ctrlKey) then
			if (skel:Bone(i).fSelected) then
				local pID = skel:Bone(i).fParent
				if (pID >= 0) then
					skel:Bone(i).fSelected = false
					skel:Bone(pID).fSelected = true
				end
				break
			end
		end
		keyEvent.view:DrawMe()
	elseif (keyEvent.keyCode == LM.GUI.KEY_DOWN and not keyEvent.ctrlKey) then
				local childID = -1
				if (skel:CountBoneChildren(i) == 1) then
					childID = skel:GetFirstChildBone(i)
				end
				if (childID >= 0) then
					skel:Bone(childID).fSelected = true
				end
				break
			end
		end
	elseif ((keyEvent.keyCode == LM.GUI.KEY_DELETE) or (keyEvent.keyCode == LM.GUI.KEY_BACKSPACE)) then
		if (moho.layer:IsBoneType() and (moho.layerFrame == 0 or not moho:DisableDrawingTools())) then
			local boneLayer = moho:LayerAsGroup(moho.layer)
			moho.document:PrepUndo(moho.layer, false)
			moho.document:SetDirty()
			keepTrying = true
			while keepTrying do
				keepTrying = false
						for j = 0, boneLayer:CountLayers() - 1 do
							boneLayer:Layer(j):DeleteParentBone(i)
						end
						skel:DeleteBone(i)
						keepTrying = true
						break
					end
				end
			end
			moho:SetCurFrame(moho.frame) -- trigger an update of all the bones in case they're undergoing a preview with the manipulate bones tool or something
		end
	end
end
function LM_SelectBone:DrawMe(moho, view)
	if (self.isMouseDragging) then
		local g = view:Graphics()
				lassoMode = true
			end
		else
				lassoMode = true
			end
		end
		if (lassoMode and self.lassoList) then
			g:Push()
			m:Invert()
			g:ApplyMatrix(m)
			g:MoveTo(self.lassoList[1][1], self.lassoList[1][2])
			for i = 2, #self.lassoList do
				g:LineTo(self.lassoList[i][1], self.lassoList[i][2])
			end
			g:Pop()
		else
			g:SelectionRect(self.selRect)
		end
	end
end
-- Bone constraints dialog
local LM_SelectBoneDialog = {}
function LM_SelectBoneDialog:new()
	local d = LM.GUI.SimpleDialog(MOHO.Localize("/Scripts/Tool/SelectBone/BoneConstraints=Bone Constraints"), LM_SelectBoneDialog)
	local l = d:GetLayout()
	l:PushV(LM.GUI.ALIGN_LEFT, 0)
	d.angleConstraints = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/AngleConstraints=Angle constraints:"), LM_SelectBone.DLOG_CHANGE)
	l:AddChild(d.angleConstraints, LM.GUI.ALIGN_LEFT)
	l:PushH()
		l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/MinMaxDegrees=Min/max (degrees)")))
		d.minAngle = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
		d.minAngle:SetWheelInc(5)
		l:AddChild(d.minAngle)
		d.maxAngle = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
		d.maxAngle:SetWheelInc(5)
		l:AddChild(d.maxAngle)
	l:Pop()
	if (MOHO.IsMohoPro()) then
		l:AddPadding()
		d.fixedAngle = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/IndependentAngle=Independent angle"), LM_SelectBone.DLOG_CHANGE)
		l:AddChild(d.fixedAngle, LM.GUI.ALIGN_LEFT)
		l:AddPadding()
		l:PushH(LM.GUI.ALIGN_LEFT)
			l:PushV(LM.GUI.ALIGN_LEFT)
				d.squashScaling = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/SquashAndStretchScaling=Squash and stretch scaling"), LM_SelectBone.DLOG_CHANGE)
				l:AddChild(d.squashScaling, LM.GUI.ALIGN_LEFT)
				l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/MaximumIKStretching=Maximum IK stretching")), LM.GUI.ALIGN_LEFT)
			l:Pop()
				d.maxStretchScaling = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
				d.maxStretchScaling:SetWheelInc(0.1)
				l:AddChild(d.maxStretchScaling, LM.GUI.ALIGN_LEFT)
				d.maxAutoScaling = LM.GUI.TextControl(0, "0000.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
				d.maxAutoScaling:SetWheelInc(0.1)
				l:AddChild(d.maxAutoScaling, LM.GUI.ALIGN_LEFT)
			l:Pop()
		l:Pop()
		l:AddPadding()
		d.arcSolver = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ArcIKSolver=Arc IK solver"), LM_SelectBone.DLOG_CHANGE)
		l:AddChild(d.arcSolver, LM.GUI.ALIGN_LEFT)
		d.ignoredByIK = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/IgnoredByInverseKinematics=Ignored by inverse kinematics"), LM_SelectBone.DLOG_CHANGE)
		l:AddChild(d.ignoredByIK, LM.GUI.ALIGN_LEFT)
		l:AddPadding()
		l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/Target=Target:")), LM.GUI.ALIGN_LEFT)
		l:PushH()
			d.targetMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
			d.targetPopup = LM.GUI.PopupMenu(128, true)
			d.targetPopup:SetMenu(d.targetMenu)
			l:AddChild(d.targetPopup)
		l:Pop()
	end
	l:AddPadding()
	l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/AngleControlBone=Angle control bone:")), LM.GUI.ALIGN_LEFT)
	l:PushH()
		d.acMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
		d.acPopup = LM.GUI.PopupMenu(128, true)
		d.acPopup:SetMenu(d.acMenu)
		l:AddChild(d.acPopup)
		d.angleControl = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
		l:AddChild(d.angleControl)
	l:Pop()
	l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/PositionControlBone=Position control bone:")), LM.GUI.ALIGN_LEFT)
	l:PushH()
		d.pcMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
		d.pcPopup = LM.GUI.PopupMenu(128, true)
		d.pcPopup:SetMenu(d.pcMenu)
		l:AddChild(d.pcPopup)
		d.posControlX = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
		l:AddChild(d.posControlX)
		d.posControlY = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
		l:AddChild(d.posControlY)
	l:Pop()
	l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/ScaleControlBone=Scale control bone:")), LM.GUI.ALIGN_LEFT)
	l:PushH()
		d.scMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
		d.scPopup = LM.GUI.PopupMenu(128, true)
		d.scPopup:SetMenu(d.scMenu)
		l:AddChild(d.scPopup)
		d.scaleControl = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_FLOAT)
		l:AddChild(d.scaleControl)
	l:Pop()
	d.boneDynamics = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/BoneDynamics=Bone dynamics:"), LM_SelectBone.DLOG_CHANGE)
	l:AddChild(d.boneDynamics, LM.GUI.ALIGN_LEFT)
	l:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/TorqueSpringDampingForce=Torque force / Spring force / Damping force")), LM.GUI.ALIGN_LEFT)
	l:PushH()
		d.torque = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
		d.torque:SetWheelInc(0.1)
		l:AddChild(d.torque)
		d.spring = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
		d.spring:SetWheelInc(0.1)
		l:AddChild(d.spring)
		d.damping = LM.GUI.TextControl(0, "00.0000", LM_SelectBone.DLOG_CHANGE, LM.GUI.FIELD_UFLOAT)
		d.damping:SetWheelInc(0.1)
		l:AddChild(d.damping)
		d.windDynamics = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/Wind=Wind"), LM_SelectBone.DLOG_CHANGE)
		l:AddChild(d.windDynamics)
	l:Pop()
	l:PushH(LM.GUI.ALIGN_RIGHT, 0)
		l:AddChild(LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectBone/Close=Close"), LM.GUI.MSG_CANCEL))
	l:Pop()
	l:Pop()
	return d
end
function LM_SelectBoneDialog:UpdateWidgets(moho)
	if (self.document and self.layer and self.skel and self.bone) then
		self.angleConstraints:Enable(true)
			self.targetPopup:Enable(true)
		end
		self.acPopup:Enable(true)
		self.pcPopup:Enable(true)
		self.scPopup:Enable(true)
		self.boneDynamics:Enable(true)
		self.angleConstraints:SetValue(self.bone.fConstraints)
		self.minAngle:SetValue(math.deg(self.bone.fMinConstraint))
		self.maxAngle:SetValue(math.deg(self.bone.fMaxConstraint))
		self.minAngle:Enable(self.bone.fConstraints)
		self.maxAngle:Enable(self.bone.fConstraints)
		local id = self.skel:BoneID(self.bone)
			self.fixedAngle:Enable(true)
			self.fixedAngle:SetValue(self.bone.fFixedAngle)
			self.squashScaling:Enable(true)
			self.squashScaling:SetValue(self.bone.fScalingMode == 2)
			self.maxStretchScaling:Enable(self.bone.fScalingMode == 2)
			self.maxStretchScaling:SetValue(self.bone.fSquashStretchScaling)
			self.maxAutoScaling:Enable(true)
			self.maxAutoScaling:SetValue(self.bone.fMaxAutoScaling)
			self.arcSolver:Enable(true)
			self.arcSolver:SetValue(self.bone:IsArcSolverEnabled())
			self.ignoredByIK:Enable(true)
			self.ignoredByIK:SetValue(self.bone.fIgnoredByIK)
			MOHO.BuildBoneChoiceMenu(self.targetMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
			if (self.skel:TargetOfBone(id, self.layerFrame) < 0) then
				self.targetMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
			else
				self.targetMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.skel:TargetOfBone(id, self.layerFrame), true)
			end
			self.targetPopup:Redraw()
		end
		MOHO.BuildBoneChoiceMenu(self.acMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
		if (self.bone.fAngleControlParent < 0) then
			self.acMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
		else
			self.acMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fAngleControlParent, true)
		end
		self.acPopup:Redraw()
		MOHO.BuildBoneChoiceMenu(self.pcMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
		if (self.bone.fPosControlParent < 0) then
			self.pcMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
		else
			self.pcMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fPosControlParent, true)
		end
		self.pcPopup:Redraw()
		MOHO.BuildBoneChoiceMenu(self.scMenu, self.skel, LM_SelectBone.SELECTCONTROL, id)
		if (self.bone.fScaleControlParent < 0) then
			self.scMenu:SetChecked(LM_SelectBone.SELECTCONTROL, true)
		else
			self.scMenu:SetChecked(LM_SelectBone.SELECTCONTROL + 1 + self.bone.fScaleControlParent, true)
		end
		self.scPopup:Redraw()
		self.angleControl:Enable(self.bone.fAngleControlParent >= 0)
		self.posControlX:Enable(self.bone.fPosControlParent >= 0)
		self.posControlY:Enable(self.bone.fPosControlParent >= 0)
		self.scaleControl:Enable(self.bone.fScaleControlParent >= 0)
		self.angleControl:SetValue(self.bone.fAngleControlScale)
		self.posControlX:SetValue(self.bone.fPosControlScale.x)
		self.posControlY:SetValue(self.bone.fPosControlScale.y)
		self.scaleControl:SetValue(self.bone.fScaleControlScale)
		self.boneDynamics:SetValue(self.bone.fBoneDynamics.value)
		self.windDynamics:SetValue(self.bone.fWindDynamics)
		self.torque:SetValue(self.bone.fTorqueForce)
		self.spring:SetValue(self.bone.fSpringForce)
		self.damping:SetValue(self.bone.fDampingForce)
--[syn]		self.windDynamics:Enable(self.bone.fBoneDynamics.value)
--[[syn]]	self.windDynamics:Enable(true)
		self.torque:Enable(self.bone.fBoneDynamics.value)
		self.spring:Enable(self.bone.fBoneDynamics.value)
		self.damping:Enable(self.bone.fBoneDynamics.value)
	else
		self.angleConstraints:Enable(false)
		self.minAngle:Enable(false)
		self.maxAngle:Enable(false)
			self.fixedAngle:Enable(false)
			self.squashScaling:Enable(false)
			self.maxStretchScaling:Enable(false)
			self.maxAutoScaling:Enable(false)
			self.arcSolver:Enable(false)
			self.ignoredByIK:Enable(false)
			self.targetPopup:Enable(false)
		end
		self.acPopup:Enable(false)
		self.angleControl:Enable(false)
		self.pcPopup:Enable(false)
		self.posControlX:Enable(false)
		self.posControlY:Enable(false)
		self.scPopup:Enable(false)
		self.scaleControl:Enable(false)
		self.boneDynamics:Enable(false)
		self.windDynamics:Enable(false)
		self.torque:Enable(false)
		self.spring:Enable(false)
		self.damping:Enable(false)
	end
end
function LM_SelectBoneDialog:OnOK()
	self:HandleMessage(LM_SelectBone.DLOG_CHANGE) -- send this final message in case the user is in the middle of editing some value
end
function LM_SelectBoneDialog:HandleMessage(msg)
	if (not (self.document and self.layer and self.skel and self.bone)) then
		return
	end
	if (msg == LM_SelectBone.DLOG_CHANGE) then
		self.document:PrepUndo(self.layer, true)
		self.document:SetDirty()
		for i = 0, self.skel:CountBones() - 1 do
			local bone = self.skel:Bone(i)
			if (bone.fSelected) then
				bone.fConstraints = self.angleConstraints:Value()
				bone.fMinConstraint = math.rad(self.minAngle:FloatValue())
				bone.fMaxConstraint = math.rad(self.maxAngle:FloatValue())
				if (self.minAngle:IsEnabled() ~= bone.fConstraints) then
					self.minAngle:Enable(bone.fConstraints)
					self.maxAngle:Enable(bone.fConstraints)
				end
					bone.fFixedAngle = self.fixedAngle:Value()
					if (self.squashScaling:Value()) then
						bone.fScalingMode = 2
					else
						bone.fScalingMode = 0
					end
					bone.fSquashStretchScaling = self.maxStretchScaling:FloatValue()
					if (bone.fSquashStretchScaling < 0.01) then
						bone.fSquashStretchScaling = 0.01
						self.maxStretchScaling:SetValue(bone.fSquashStretchScaling)
					end
					if (bone.fSquashStretchScaling > 100.0) then
						bone.fSquashStretchScaling = 100.0
					end
					bone.fMaxAutoScaling = self.maxAutoScaling:FloatValue()
					if (bone.fMaxAutoScaling < 0.999999) then
						bone.fMaxAutoScaling = 1.0
						self.maxAutoScaling:SetValue(bone.fMaxAutoScaling)
					end
					bone:EnableArcSolver(self.arcSolver:Value())
					bone.fIgnoredByIK = self.ignoredByIK:Value()
				end
				bone.fAngleControlScale = self.angleControl:FloatValue()
				bone.fPosControlScale.x = self.posControlX:FloatValue()
				bone.fPosControlScale.y = self.posControlY:FloatValue()
				bone.fScaleControlScale = self.scaleControl:FloatValue()
--syn\/
				if (self.windDynamics:Value()) then
					self.boneDynamics:SetValue(true)
				end
--syn/\
				if (bone.fBoneDynamics.value ~= self.boneDynamics:Value()) then
					bone.fBoneDynamics.value = self.boneDynamics:Value()
					bone.fBoneDynamics:StoreValue()
					self.layer:UpdateCurFrame(true)
					MOHO.NewKeyframe(CHANNEL_BONE_DYNAMICS)
					MOHO.NewKeyframe(CHANNEL_BONE_SEL_DYNAMICS)
				end
				if (bone.fWindDynamics ~= self.windDynamics:Value()) then
					bone.fWindDynamics = self.windDynamics:Value()
					local updateDynamicsValues = false
					if (bone.fWindDynamics) then
						if (math.abs(bone.fTorqueForce - 2.0) < 0.001 and math.abs(bone.fSpringForce - 2.0) < 0.001 and math.abs(bone.fDampingForce - 1.0) < 0.001) then
							updateDynamicsValues = true
							bone.fTorqueForce = 0.0
							bone.fSpringForce = 1.0
							bone.fDampingForce = 1.0
						end
					else
						if (math.abs(bone.fTorqueForce - 0.0) < 0.001 and math.abs(bone.fSpringForce - 1.0) < 0.001 and math.abs(bone.fDampingForce - 1.0) < 0.001) then
							bone.fTorqueForce = 2.0
							bone.fSpringForce = 2.0
						end
					end
					if (updateDynamicsValues) then
						self.torque:SetValue(bone.fTorqueForce)
						self.spring:SetValue(bone.fSpringForce)
						self.damping:SetValue(bone.fDampingForce)
					end
				else
					bone.fTorqueForce = self.torque:FloatValue()
					bone.fSpringForce = self.spring:FloatValue()
					bone.fDampingForce = self.damping:FloatValue()
				end
				if (self.torque:IsEnabled() ~= bone.fBoneDynamics.value) then
--[syn]					self.windDynamics:Enable(bone.fBoneDynamics.value)
					self.torque:Enable(bone.fBoneDynamics.value)
					self.spring:Enable(bone.fBoneDynamics.value)
					self.damping:Enable(bone.fBoneDynamics.value)
				end
			end
		end
		self.layer:UpdateCurFrame()
		MOHO.Redraw()
	elseif (msg >= LM_SelectBone.SELECTCONTROL and msg <= LM_SelectBone.SELECTCONTROL + 1000) then
				local ctrlID = -1
					ctrlID = self.targetMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
					if (ctrlID ~= self.skel:BoneID(bone) and ctrlID ~= bone.fTargetBone:GetValue(self.layerFrame)) then
						bone.fTargetBone:SetValue(self.layerFrame, ctrlID)
						MOHO.NewKeyframe(CHANNEL_BONE_TARGET)
						MOHO.NewKeyframe(CHANNEL_BONE_SEL_TARGET)
					end
				end
				ctrlID = self.acMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
				if (ctrlID ~= self.skel:BoneID(bone)) then
					bone.fAngleControlParent = ctrlID
				end
				ctrlID = self.pcMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
					bone.fPosControlParent = ctrlID
				end
				ctrlID = self.scMenu:FirstCheckedMsg() - (LM_SelectBone.SELECTCONTROL + 1)
					bone.fScaleControlParent = ctrlID
				end
				self.angleControl:Enable(bone.fAngleControlParent >= 0)
				self.posControlX:Enable(bone.fPosControlParent >= 0)
				self.posControlY:Enable(bone.fPosControlParent >= 0)
				self.scaleControl:Enable(bone.fScaleControlParent >= 0)
			end
		end
		MOHO.Redraw()
	end
end
-- Tool options - create and respond to tool's UI
LM_SelectBone.CHANGE = MOHO.MSG_BASE
LM_SelectBone.DLOG_BEGIN = MOHO.MSG_BASE + 1
LM_SelectBone.DLOG_CHANGE = MOHO.MSG_BASE + 2
LM_SelectBone.LOCK = MOHO.MSG_BASE + 3
LM_SelectBone.LASSO = MOHO.MSG_BASE + 4
LM_SelectBone.LABEL = MOHO.MSG_BASE + 5
LM_SelectBone.SHY = MOHO.MSG_BASE + 6
LM_SelectBone.COL_PLAIN = MOHO.MSG_BASE + 7
LM_SelectBone.COL_RED = MOHO.MSG_BASE + 8
LM_SelectBone.COL_ORANGE = MOHO.MSG_BASE + 9
LM_SelectBone.COL_YELLOW = MOHO.MSG_BASE + 10
LM_SelectBone.COL_GREEN = MOHO.MSG_BASE + 11
LM_SelectBone.COL_BLUE = MOHO.MSG_BASE + 12
LM_SelectBone.COL_PURPLE = MOHO.MSG_BASE + 13
LM_SelectBone.COL_TAN = MOHO.MSG_BASE + 14
LM_SelectBone.COL_PINK = MOHO.MSG_BASE + 15
LM_SelectBone.COL_TURQUOISE = MOHO.MSG_BASE + 16
LM_SelectBone.COL_CADETBLUE = MOHO.MSG_BASE + 17
LM_SelectBone.COL_CORAL = MOHO.MSG_BASE + 18
LM_SelectBone.FLIP_H = MOHO.MSG_BASE + 19
LM_SelectBone.FLIP_V = MOHO.MSG_BASE + 20
LM_SelectBone.DUMMY = MOHO.MSG_BASE + 21
LM_SelectBone.SELECTITEM = MOHO.MSG_BASE + 22
LM_SelectBone.SELECTCONTROL = MOHO.MSG_BASE + 300
function LM_SelectBone:DoLayout(moho, layout)
	self.menu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/SelectBone=Select Bone"))
	self.dlog = LM_SelectBoneDialog:new()
	self.popup = LM.GUI.PopupDialog(MOHO.Localize("/Scripts/Tool/SelectBone/ConeConstraints=Bone Constraints"), true, self.DLOG_BEGIN)
	self.popup:SetDialog(self.dlog)
	layout:AddChild(self.popup)
	self.popup = LM.GUI.PopupMenu(120, false)
	self.popup:SetMenu(self.menu)
	self.boneName = LM.GUI.TextControl(0, "Room For a Long Name", self.CHANGE, LM.GUI.FIELD_TEXT)
	self.boneName:SetValue("")
	layout:AddChild(self.boneName)
	self.lockBone = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/LockBone=Lock bone"), self.LOCK)
	layout:AddChild(self.lockBone)
	self.lassoCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/LassoMode=Lasso mode"), self.LASSO)
	layout:AddChild(self.lassoCheck)
	layout:AddChild(LM.GUI.StaticText(MOHO.Localize("/Scripts/Tool/SelectBone/Color=Color:")))
	self.colorMenu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectBone/BoneColor=BoneColor"))
	self.colorMenu:AddItem(MOHO.Localize("/Scripts/Tool/SelectBone/Purple=Purple"), 0, self.COL_PURPLE)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Blue=Blue"), 0, self.COL_BLUE)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Green=Green"), 0, self.COL_GREEN)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Yellow=Yellow"), 0, self.COL_YELLOW)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Orange=Orange"), 0, self.COL_ORANGE)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Red=Red"), 0, self.COL_RED)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Tan=Tan"), 0, self.COL_TAN)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Pink=Pink"), 0, self.COL_PINK)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Turquoise=Turquoise"), 0, self.COL_TURQUOISE)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/CadetBlue=Cadet Blue"), 0, self.COL_CADETBLUE)
	self.colorMenu:AddItemAlphabetically(MOHO.Localize("/Scripts/Tool/SelectBone/Coral=Coral"), 0, self.COL_CORAL)
	self.colorMenu:InsertItem(0, "", 0, 0)
	self.colorMenu:InsertItem(0, MOHO.Localize("/Scripts/Tool/SelectBone/Plain=Plain"), 0, self.COL_PLAIN)
	self.colorPopup = LM.GUI.PopupMenu(120, true)
	self.colorPopup:SetMenu(self.colorMenu)
	layout:AddChild(self.colorPopup)
		self.labelCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ShowLabel=Show label"), self.LABEL)
		layout:AddChild(self.labelCheck)
		self.shyCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectBone/ShyBone=Shy bone"), self.SHY)
		layout:AddChild(self.shyCheck)
	else
		self.labelCheck = nil
		self.shyCheck = nil
	end
		layout:AddChild(LM.GUI.ImageButton("ScriptResources/flip_bone_h", MOHO.Localize("/Scripts/Tool/SelectBone/EndFlip=End Flip"), false, self.FLIP_H, true))
		layout:AddChild(LM.GUI.ImageButton("ScriptResources/flip_bone_v", MOHO.Localize("/Scripts/Tool/SelectBone/SideFlip=Side Flip"), false, self.FLIP_V, true))
	end
end
function LM_SelectBone:UpdateWidgets(moho)
		end
			return
		end
	end
	local selID = skel:SelectedBoneID()
	MOHO.BuildBoneMenu(self.menu, skel, self.SELECTITEM, self.DUMMY)
	if (selID >= 0) then
		local bone = skel:Bone(selID)
		self.boneName:SetValue(bone:Name())
		self.popup:Enable(true)
		self.dlog.bone = bone
		self.lockBone:Enable(bone.fParent >= 0)
		self.lockBone:SetValue(bone.fIKLock.value)
		if (self.labelCheck ~= nil) then
			self.labelCheck:Enable(true)
		end
		if (self.shyCheck ~= nil) then
			self.shyCheck:Enable(true)
		end
	else
		self.popup:Enable(false)
		self.dlog.bone = nil
		self.lockBone:Enable(false)
		self.lockBone:SetValue(false)
			self.labelCheck:Enable(false)
		end
			self.shyCheck:Enable(false)
		end
	end
	self.lassoCheck:SetValue(self.lassoMode)
	self.colorMenu:UncheckAll()
	self.colorMenu:SetChecked(self.COL_PLAIN, true)
		self.labelCheck:SetValue(false)
	end
		self.shyCheck:SetValue(false)
	end
			local tags = bone:Tags()
			if (tags == 0) then
			else
			end
			if (tags == 1) then
				self.colorMenu:SetChecked(self.COL_RED, true)
			elseif (tags == 2) then
				self.colorMenu:SetChecked(self.COL_ORANGE, true)
			elseif (tags == 3) then
				self.colorMenu:SetChecked(self.COL_YELLOW, true)
			elseif (tags == 4) then
				self.colorMenu:SetChecked(self.COL_GREEN, true)
			elseif (tags == 5) then
				self.colorMenu:SetChecked(self.COL_BLUE, true)
			elseif (tags == 6) then
				self.colorMenu:SetChecked(self.COL_PURPLE, true)
			elseif (tags == 7) then
				self.colorMenu:SetChecked(self.COL_TAN, true)
			elseif (tags == 8) then
				self.colorMenu:SetChecked(self.COL_PINK, true)
			elseif (tags == 9) then
				self.colorMenu:SetChecked(self.COL_TURQUOISE, true)
			elseif (tags == 10) then
				self.colorMenu:SetChecked(self.COL_CADETBLUE, true)
			elseif (tags == 11) then
				self.colorMenu:SetChecked(self.COL_CORAL, true)
			end
				if (bone:IsLabelShowing()) then
					self.labelCheck:SetValue(true)
				end
			end
				if (bone.fShy) then
					self.shyCheck:SetValue(true)
				end
			end
			break
		end
	end
	self.colorPopup:Enable(skel:SelectedBoneID() >= 0)
	self.colorPopup:Redraw()
	self.dlog.document = moho.document
	self.dlog.layer = moho.layer
	self.dlog.layerFrame = moho.layerFrame
	self.dlog.skel = skel
	self.dlog:UpdateWidgets(moho)
end
function LM_SelectBone:HandleMessage(moho, view, msg)
	local layer = moho.layer
		end
			return
		end
		layer = moho.layer:ControllingBoneLayer()
	end
	if (msg == self.CHANGE) then
		if (skel:SelectedBoneID() >= 0) then
			moho.document:PrepUndo(layer, true)
					bone:SetName(self.boneName:Value())
					skel:MakeBoneNameUnique(i)
				end
			end
			moho:UpdateUI()
		end
	elseif (msg == self.LOCK) then
			local lockChange = false
				if (bone.fSelected and bone.fParent >= 0) then
					if (self.lockBone:Value()) then
						skel:LockBone(i, moho.layerFrame)
					else
						skel:UnlockBone(i, moho.layerFrame)
					end
					lockChange = true
				end
			end
			moho.layer:UpdateCurFrame(true)
			if (lockChange) then
				moho:NewKeyframe(CHANNEL_BONE)
				moho:NewKeyframe(CHANNEL_BONE_LOCK)
			end
		end
	elseif (msg == self.LASSO) then
		self.lassoMode = self.lassoCheck:Value()
	elseif (msg >= self.COL_PLAIN and msg <= self.COL_CORAL) then
		local tag = 0
		if (msg == self.COL_RED) then
			tag = 1
		elseif (msg == self.COL_ORANGE) then
			tag = 2
		elseif (msg == self.COL_YELLOW) then
			tag = 3
		elseif (msg == self.COL_GREEN) then
			tag = 4
		elseif (msg == self.COL_BLUE) then
			tag = 5
		elseif (msg == self.COL_PURPLE) then
			tag = 6
		elseif (msg == self.COL_TAN) then
			tag = 7
		elseif (msg == self.COL_PINK) then
			tag = 8
		elseif (msg == self.COL_TURQUOISE) then
			tag = 9
		elseif (msg == self.COL_CADETBLUE) then
			tag = 10
		elseif (msg == self.COL_CORAL) then
			tag = 11
		end
		local selBoneCount = 0
				selBoneCount = selBoneCount + 1
			end
		end
		if (selBoneCount > 0) then
					bone:SetTags(tag)
				end
			end
		end
		moho:UpdateUI()
	elseif (msg == self.LABEL) then
				if (self.labelCheck:Value()) then
					-- if bone labels are not showing, then turn them on now
					layer:SetQualityFlags(MOHO.setbit(layer:QualityFlags(), MOHO.LDQ_LABELS))
					view:SetQualityFlags(MOHO.setbit(view:QualityFlags(), MOHO.LDQ_LABELS))
				end
						bone:ShowLabel(self.labelCheck:Value())
					end
				end
			end
		end
	elseif (msg == self.SHY) then
						bone.fShy = self.shyCheck:Value()
						bone.fHidden = bone.fShy
					end
				end
			end
		end
	elseif (msg == self.FLIP_H) then
		LM_TransformBone:FlipBones(moho, skel, true)
	elseif (msg == self.FLIP_V) then
		LM_TransformBone:FlipBones(moho, skel, false)
	elseif (msg == self.DLOG_BEGIN) then
		self.dlog.layer = layer
			self.dlog.bone = skel:Bone(skel:SelectedBoneID())
		else
		end
	elseif (msg == self.DLOG_CHANGE) then
		-- Nothing really happens here - it is a message that came from the popup dialog.
		-- However, the important thing is that this message then flows back into the Moho app, forcing a redraw.
	elseif (msg >= self.SELECTITEM and msg < self.SELECTCONTROL) then
			skel:Bone(i).fSelected = (i == msg - self.SELECTITEM)
		end
		moho:UpdateUI()
	end
end
heyvern wrote: Wed Jul 07, 2021 9:35 pm Is there an updated reference?
Most up to date is in my signature.
davoodice2
synthsin75 wrote: Wed Jul 07, 2021 10:03 pm
LM_SelectBone = {}
end
	return "6.0"
end
end
end
end
end
end
end
-- Recurring values
		return true
	end
	return false
end
		end
			return false
		end
	end
	return true
end
		end
			return false
		end
	end
	return true
end
			lassoMode = true
		else
		end
	else
			lassoMode = true
		end
	end
		if (lassoMode) then
		else
		end
	end
end
		return
	end
			lassoMode = true
		end
	else
			lassoMode = true
		end
	end
	if (lassoMode) then
		g:Push()
		m:Invert()
		g:ApplyMatrix(m)
		g:Pop()
	else
	end
end
		return
	end
			lassoMode = true
		end
	else
			lassoMode = true
		end
	end
	if (lassoMode) then
		g:Push()
		m:Invert()
		g:ApplyMatrix(m)
		g:Pop()
		LM.Snooze(100)
	end
	g:Clear(0, 0, 0, 0)
	g:Push()
	m:Invert()
	g:ApplyMatrix(m)
	g:BeginShape()
	if (lassoMode) then
		end
	else
	end
	g:EndShape()
	g:Pop()
	--LM.Snooze(1000)
		end
	end
				end
				for j = 0, 10 do
					m:Transform(v)
						else
						end
						break
					end
				end
			end
		end
	end
end
	self.selBoneID = -1
		end
			return
		end
	end
	local id = -1
	else
	end
	self.selBoneID = id
		if (id >= 0) then
		end
		if (id >= 0) then
		end
	else
		end
	end
	mouseView:DrawMe()
end
		end
			return
		end
	end
				if (pID >= 0) then
				end
				break
			end
		end
				local childID = -1
				end
				end
				break
			end
		end
			keepTrying = true
			while keepTrying do
				keepTrying = false
						end
						skel:DeleteBone(i)
						keepTrying = true
						break
					end
				end
			end
		end
	end
end
				lassoMode = true
			end
		else
				lassoMode = true
			end
		end
			g:Push()
			m:Invert()
			g:ApplyMatrix(m)
			end
			g:Pop()
		else
		end
	end
end
	l:PushH()
	l:Pop()
		l:AddPadding()
		l:AddPadding()
			l:Pop()
			l:Pop()
		l:Pop()
		l:AddPadding()
		l:AddPadding()
		l:PushH()
		l:Pop()
	end
	l:AddPadding()
	l:PushH()
	l:Pop()
	l:PushH()
	l:Pop()
	l:PushH()
	l:Pop()
	l:PushH()
	l:Pop()
	l:Pop()
	l:Pop()
	return d
end
		end
			else
			end
		end
		else
		end
		else
		end
		else
		end
	else
		end
	end
end
end
		return
	end
				end
					else
					end
					end
					end
					end
				end
--syn\/
				end
--syn/\
				end
						end
					else
						end
					end
					end
				else
				end
				end
			end
		end
		MOHO.Redraw()
				local ctrlID = -1
					end
				end
				end
				end
				end
			end
		end
		MOHO.Redraw()
	end
end
	else
		self.shyCheck = nil
	end
	end
end
		end
			return
		end
	end
		end
		end
	else
		end
		end
	end
	end
	end
			if (tags == 0) then
			else
			end
			if (tags == 1) then
			end
				end
			end
				if (bone.fShy) then
				end
			end
			break
		end
	end
end
		end
			return
		end
	end
				end
			end
			moho:UpdateUI()
		end
					else
					end
					lockChange = true
				end
			end
			end
		end
		local tag = 0
			tag = 1
			tag = 2
			tag = 3
			tag = 4
			tag = 5
			tag = 6
			tag = 7
			tag = 8
			tag = 9
			tag = 10
			tag = 11
		end
			end
		end
					bone:SetTags(tag)
				end
			end
		end
		moho:UpdateUI()
				end
					end
				end
			end
		end
					end
				end
			end
		end
		else
		end
		end
		moho:UpdateUI()
	end
end
THAT WORKED.BIG THANKS.
davoodice2
UPDATE:
mod bone select tool works at frame 0 only.
when press close button in bone select options box, moho makes change to all bone settings. i want just close window. :( :(
That mod was only to allow enabling wind directly, not changing individual settings of multiple selected bones.
Sorry if that confused you.
Like I said earlier, since I have no need for that myself, I'd have to charge to write it.
davoodice2
synthsin75 wrote: Wed Jul 14, 2021 2:30 pm That mod was only to allow enabling wind directly, not changing individual settings of multiple selected bones.
Thnks.if you wish please write a new tool in your free time if its possible.
davoodice2 wrote: Wed Jul 14, 2021 11:30 pm
No, I just said I don't need such a tool. Why on earth would I waste my free time writing it?
