Moho 13.5 -- SVG import fails when using General Import
SimplSam
Post by SimplSam »
If you Drag-and-Drop a SVG file to the workspace or use General Import (as I normally do) for a SVG file - it results in a 'broken image'. i.e. Moho appears to try and treat the imported SVG as a Bitmap.
However - if you use the File > Import > Vector File > SVG File it works as normal.
p.s. I have also reported this to LM Moho Support
nina_paley
Re: 13.5 -- SVG import fails when using General Import
Post by nina_paley »
I am having this problem also. Thanks for the workaround!
AHMED003ADALAT
Post by AHMED003ADALAT »
a friend of have this issue in all pictures format ... when he tries to import any photo this {?} appears :? :|
AHMED003ADALAT wrote: Wed May 05, 2021 10:45 pm a friend of have this issue in all pictures format ... when he tries to import any photo this {?} appears :? :|
That's due to non-English characters in the file name or path.
AHMED003ADALAT
synthsin75 wrote: Thu May 06, 2021 12:14 am
i asked him about that but told me they are all english ..... it's not just him many people reported same bug though in 13.5 :? :|
AHMED003ADALAT wrote: Thu May 06, 2021 5:21 am
synthsin75 wrote: Thu May 06, 2021 12:14 am That's due to non-English characters in the file name or path.
It's either in the file name of somewhere in the path to the file.
Yes, definitely check the entire path, not just the filename. That was the case with some international users who have posted about this.
Apparently, 13.0 was more forgiving about what's allowed. If so, hopefully, Mike will enable the allowance in the next Moho release.
In the meantime, I would avoid using any non-english characters in a path and file name. FWIW, most places I've worked at do not allow it because it can cause problems for a lot of software, especially on networks with mixed operating systems. Some places don't even allow spaces in paths and names, preferring _ instead or using camelCase. (It's what I usually do, even when working on personal projects.)
opeth
Post by opeth »
Now we use 13 and 13.5 together. It's almost like no problem. But we create new file paths only from English characters.
Moho 14.2 MacBook Pro 16'2 M1 Max 32gb.
AHMED003ADALAT
Re: Moho 13.5 -- SVG import fails when using General Import
yeah guys it was language issue in file path .... change it to english and u re all good 8) :wink:
