可爱的羊---
可爱的羊---
Re: 可爱的羊---
Beautiful animation cycle, Sang! And the design from Bergeres guerrieres is also stunning.
Re: 可爱的羊---
lwaxana wrote:Beautiful animation cycle, Sang! And the design from Bergeres guerrieres is also stunning.
- hayasidist
Re: 可爱的羊---
Neat -- is that done with smart mesh? (and I assume you needed to make separate layers from the original?)
那很好! - 你使用“智能网格”吗? (我假设你不得不分开的层从原来?)
and I can't make a good translation of the text (is it shi yang???) before ".. to Jonathan Garnier" ! Please educate me!!
Re: 可爱的羊---
hayasidist wrote:Neat -- is that done with smart mesh? (and I assume you needed to make separate layers from the original?)
- hayasidist
Re: 可爱的羊---
哦!
你的名字!! 現在很明顯,你告訴我! 我們太習慣於使用我們的用戶名! 我不驚訝,我不能翻譯它! 多麼笨拙的我! 謝謝。
Re: 可爱的羊---
hayasidist wrote:哦!你的名字!! 現在很明顯,你告訴我! 我們太習慣於使用我們的用戶名! 我不驚訝,我不能翻譯它! 多麼笨拙的我! 謝謝。
- hayasidist
Re: 可爱的羊---
谢谢你的明智的话!
Re: 可爱的羊---
Re: 可爱的羊---
- hayasidist
Re: 可爱的羊---
yes - I agree. I liked the simplicity and effectiveness of the stroke you showed on the train. perhaps two stroke shapes using the same set of points?sang820 wrote:
我今天努力为线条添加了些“厚度”,然而还原度不是很好---我会再尝试其他方式,来还原羊身上那些可爱的云朵。
是的 我同意。 我喜歡你在火車上顯示的筆劃的簡單性和有效性。 也許兩個筆劃形狀使用相同的一組點?
Re: 可爱的羊---
hayasidist wrote:yes - I agree. I liked the simplicity and effectiveness of the stroke you showed on the train. perhaps two stroke shapes using the same set of points?sang820 wrote:
- hayasidist
Re: 可爱的羊---
我將等待!sang820 wrote: 我会尝试新的方式---过两天会有结果
Re: 可爱的羊---
