need help quick :( (exporting not workin)
got a 3 second animation im trying to export but the export fails every time NO idea why...i need to get this out
il pay some1 like 20 bucks if they can take a look and tell me why!
Re: need help quick :( (exporting not workin)
Try rendering to images first, it might be a codec issue. If that doesn't work, you could try rendering 2-4 layers at a time and then composite.
can u explain this in other words?dkwroot wrote:Try rendering to images first, it might be a codec issue. If that doesn't work, you could try rendering 2-4 layers at a time and then composite.
rendering 2-4 layers at a time then a composite??
my scene has 6 fully rigged characters (yes i know, a lot) i could be super wrong but are u saying theres a way to do them separate and then add them together?
thanks for the response sorry for not being smart
Yes, render the characters separately and then combine them into a final render. Try rendering just two characters at a time to a png sequence and see if it works.
dkwroot wrote:Yes, render the characters separately and then combine them into a final render. Try rendering just two characters at a time to a png sequence and see if it works.
with 2 its no problem at all
when i to 4, 5 thats when i have issues im gonna do some researching on what ur saying about the combining that sounds like itll work if i can figure it thank, thanks for the time man
hey man im at my wits end i got a project i NEED to drop
can i pay u to help me? i need 6 characters together in 1 seen (dancing) very short cuts
it crashes as soon as i have 5
dont even think their support can help me been days
i can render as images no problem but as soon as i have 6 rendered characters which i need for my scene
it crashes even if i make it half a second long with NO movement
Workaround: render characters 1 - 3 as video on transparency, then render chars 4 - 6 the same way. Create new project, import both videos, render.
slowtiger wrote:Workaround: render characters 1 - 3 as video on transparency, then render chars 4 - 6 the same way. Create new project, import both videos, render.
i like me some work arounds
sorry how do u render character as video on transpency?
i cant even get 2 rigged character at same time now....wtf....
i will give someone 50 bucks to solve this for me. i have an animation less than a second i cant even export..im so passed my deadline
their support cant figure it out.... i feel either im doing something clearly stupid or this program is a rip off
Are you using Pro?
If so, you can use ASP's Layer Comps to output your passes for compositing. This is what I typically do in my personal projects and at the animation studio where I work.
Layer Comps can be accessed from the right-most button at the top of the Layers panel. After setting up your Layer Comps (i.e., Char, Sky, BG, MG, FG, Particles, etc.,) use Batch Export and go to the Render Layer Comp drop down. From there, you can render each Layer Comp individually or select All to render all of the Layer Comps as separate passes.
Rendering directly to a single movie file can be resource heavy, especially with complex scenes, because it has to keep all that data in RAM during the process. It's generally a lot faster and more reliable to render separate layers as image sequences with embedded alpha channels.
When I have all my layers ready, I'll composite the layers in Fusion or After Effects for final output to editorial. If it's an especially gnarly comp, I might even render a 'flattened' frames version first and then compile those frames to a final movie file.
And even if you're not rendering from ASP for compositing, rendering to an image sequence is still far less taxing on computer.
G.
G.
If you want to PM me a link to the file, I'll take a look.
Greenlaw wrote:Are you using Pro?
G.
thanks man would u mind if i pm u to ask stupid questions about parts i dont understand or clarification?
synthsin75 wrote:If you want to PM me a link to the file, I'll take a look.
thanks! before i waste ur time do u think the other guy is right and it just cant handle that many chars?
drops as soon as i put more than 4 even if no actions or animation cant export 4
very much appreciated guys. smith micro support stopped trying to help
You can ask here. That way, others who may have the same questions can also learn, and experienced users can jump in and add their thoughts.
G.
G.
