How to avoid bone vibration?
Vector bone animation is rendering fine but png images imported from photoshop using the AS script are vibrating like a tuning fork when still ( not animating or moving).
Any tips on how to stop them from vibrating?
I searched but couldn't find anything in the forums.
Help if possible.
Help if possible.
Re: How to avoid bone vibration?
Bump
Guys any help here? I am stuck with my work.
Yes, bone locking is a possible culprit. Anotehr one s not exactly matching keys: you think they are identical when in fact they're not. Try copying to make sure bones really stand still between movements.
Nope.
Do I need to lock it for the whole time frame or only when not moving the bones?
I try copy the keyframes or press reset all the bones.slowtiger wrote:Yes, bone locking is a possible culprit. Anotehr one s not exactly matching keys: you think they are identical when in fact they're not. Try copying to make sure bones really stand still between movements.
Haven't learned locking yet, will give it a try.
are you sure the keyframes aren't set to noisy?
If so, change them to smooth.
Do they always vibrate or in some circumstances?
I've encountered this on some rare occasions and then it was usually due to some complex character setup with many folders nested in each others with motion in different directions.
Can you share your anme-file and image sources?
yes it is kind of exactly what is happening, one photoshop file with different layers plus eyes and mouths separate added from anime studio are all in one group and I am moving the whole group in and out of the scene.rylleman wrote:Do they always vibrate or in some circumstances?
This is exactly what I am facing, have you sorted out this problem in your files?rylleman wrote:Do they always vibrate or in some circumstances?
On these occasions I've done a little rerigging and redistribution of layers. No universal cure, sorry.
Thanks for your help.
I realize this is not happening with vector images created by character wizard. Also I did not used smooth key frames, they were linear and did not used lock bones as well.
So lets see me try with vector graphics and then see how it goes.
