Patch layer problem
Stekyta
Patch layer problem
Post by Stekyta »
Hello again guys!
Do anyone of you know why my patch layers don´t render? Im getting quite frustrated on this now.
GCharb
Post by GCharb »
Hello Stekyta
I made You a little patch layer file example where it works fine.
http://www.mediafire.com/?l94z6sx7t3aayhm
Can You post the file so We can have a look, maybe You did not assign the right layer to the patch, as it has to be assigned to the layer beneath the one on top.
Sometimes I get that they just vanish, then I redo them and they work.
Hope this helps!
neeters_guy
Re: Patch layer problem
Post by neeters_guy »
Stekyta wrote:Do anyone of you know why my patch layers don´t render? Im getting quite frustrated on this now.
Well, technically patch layers aren't supposed to render. What they do is mask out the outline of any layers between it and the target layer. Also, the area of masking is defined by a circle which can be manipulated with the layer tools.
Check that the layer you want to mask is between the patch and target, and check if the circle is in the right location.
Beyond that, we'd need more info I think.
