Halloween animation!
I know this is quite a simple animation, but I like how it turned out.
http://www.vimeo.com/27726486
I came up with all the motions on my own based on the feel of the song and what I know about do-wop music!
Since there were no actual movements other than the AS stuff, I think a photo of the 3 pumpkins would have been better. At least for rendering times. If you wanted to record the pumpkins like you did you could of moved them a few degrees left and right for a few frames and moved them back for some profile fx. But as it is, its very entertaining and I liked it.
I think sbtamu was suggesting instead of using a video of static pumpkins you could have used a single image and wiggled it in ASP.Dadoo wrote:Actually, the projection is SUPPOSED to be used with real or artificial pumpkins as seen in the video. This is the same way Disney does the singing Jack-o-Lanterns in the Haunted Mansion during Halloween.
Pretty sure they are using AS for the animation as well.
The video footage didn't have any movement other than camera and the same could have been achieved with a single image with much quicker render times that is all.
Oh I liked it too
--Sven
What *if* the Hokey cokey *is* what its all about?
I see what you're saying, and it's a good idea. BUT, the effect wouldn't have looked as good without using an actual projector on the pumpkins. There is a certain glare and coloring that can only be achieved by projecting the animation. I also shot this live because I wanted the client to see EXACTLY how the effect worked. Hope that makes sense.
