Illustrator to Moho Problems
Qbee
Post by Qbee »
I have this moon that I made in illustrator but it won't show the way it was in Illustrator in Moho. I tested the file out with flash and it works fine? What am I doing wrong?
Note: I use the mesh feature in Illustrator. Is that the problem?
WillBellJr
Post by WillBellJr »
I don't believe Moho supports all of Illustrator's vector features and attributes.
If you saved it as a bitmap then you'd get what you saw in AI but I'd imagine AI's gradient meshes are very proprietary and not easy to support especially if Moho doesn't provide gradients meshes either.
-Will
Lost Marble
Post by Lost Marble »
Moho can't import gradients from Illustrator files.
This is a really simple drawing - why not draw it in Moho:
http://www.lostmarble.com/misc/moon.moho
By the way, if those are craters on the surface of the moon, shouldn't their shading be the other way around?
Qbee
Post by Qbee »
Yeah. Thanks.
