Is this a bug or something?
Kyuubified Hokage
Post by Kyuubified Hokage »
OK.So,I have Anime Studio Pro 5.5 and everything seems fine but (and thats a big but) for soe reason I can`t do anymore than 72 frames.I mark a further frame as an ending but it only goes as far as frame 72.(The ruler is colored blue only to frame 72)How can I (or can I) fix this?Please tell me. :cry:
The ruler is colored to blue where the Menu -> Project Settings -> Start / end Frame says. Just go there and change the end frame adn you can increase your animation length.
Alternatively you can ALT left - right click the ruler to define the initial and end frames.
Even you can read the built in help to realize about this and a lot of more things :wink:
Look heremeanwhile...
Kyuubified Hokage
I knew you were going to suggest the Help thing but what can I say.....my darn lazyness won`t let me read :roll: .
EDIT:Thanks for the help.Problem fixed.
also, you can put "0" value in the End Frame (file>project settings...). then your animation will last until the last keyframe you make.
i have set this way as custom.
