exporting sounds...
sv3in
exporting sounds...
Post by sv3in »
Sorry, probably very newbie stuff this... But I'm trying to export a file from frame no 1200 to frame 1500...when i do this, i cant seem to export with sound...
Am i doing something wrong, or do you have to export from frame one..?
Sv3in
cribble
Post by cribble »
The sound only exports if from frame 1 and in quicktime... i think. correct me someone?
--Scott
cribble.net
The sound track always exports starting at the beginning. So if you go to frame 1200 and export the sound starts at THE BEGINNING of the sound file.
I don't usually have animations that I would need to go to frame 1200 to START my rendering. If the animation is already that long I would break it out into a new segment or project.
1200 frames at 24 fps is nearly a full minute of time. So if you start at that point your animation is more than a minute. that is an awfully big chunk for one animated shot.
I admit this sound track issue with AS is a pain in the arse but there's nothing else to do about it till they fix it.
cribble
Post by cribble »
-vern, i've had scene's over 3k frames sometimes. Because i'm hardcore!
--Scott
cribble.net
I think this is the umpteenth time that I said that you can make the soundtrack start at other any frame than frame 1!!!
viewtopic.php?p=45923#45923
viewtopic.php?p=41462#41462
viewtopic.php?p=38769#38769
Just put your project settings to be:
Start frame = 1200
End Frame = 1500
and your imported soundtrack would BEGIN at frame 1200!!!. :evil:
You can want to do this if you are dubbing parts of your animation and render them separately.
It is only insane if there are particles involved in the animation.
