Angles, radians conversion question... Gente?
Genete I have a question once again about converting angles to radians etc.
In my aimer script I am using the code from the LM translate bone tool for frame 0. This will "flip" the angle when it hits 0 all the way around to 360. For the original purpose of this code this makes perfect sense. For my purposes this causes a problem.
Here is the code for that angle conversion based on translating the target bone:
                local angle = aimer.fAngle
                angle = angle + math.atan2(boneVec.y, boneVec.x)
What happens is that the angle of the aimer bone is fine. It flips from 0 to 360 and everything is just fine. But when I use a constraint the constrained bone flips all the around to the opposite side when it crosses that 0 angle point.
Is there any "magical" equations in your bag of tricks to convert that angle before applying it that wouldn't cause a constraint to act oddly?
There was some "extra" bit of code from the original LM bone translation tool that I removed for my script:
                while angle > 2 * math.pi do
                        angle = angle - 2 * math.pi
                end
                while angle < 0 do
                        angle = angle + 2 * math.pi
                end
Removing this code stopped the AIMER bone from "flipping" rotation... but it doesn't help with constraints.
I'm sorry but I cannot reproduce the problem. Or I can but don't understand it.
Please verify the problem in this anme file (it must be downloaded in a folder with aim_bone.lua file the last version you have in the first post)
http://www.darthfurby.com/genete/Scripting/test.anme
In this file the aim bone cross from 0 to 180 in two frames but as well as its length is so small we don't notice. The constrained bone is rotated suddenly from 0 to 180. But if I make a complete turn (from frames 54 to 86) then you can see a curious thing:
Aimer bone never reaches more than -180 or +180. It is due to its angle comes form atan2. atan2 always return a value between +pi -pi (-180, 180). The constrained bone follows the aimer bone with no jump when performing the 360 turn.
lua programming reference manual wrote: math.atan2 (y, x)
Returns the arc tangent of y/x (in radians), but uses the signs of both parameters to find the quadrant of the result. (It also handles correctly the case of x being zero.)
So I really don't understand you... Can you put an example, please. :roll:
Regarding the second portion of code.
2*math.pi = 360 degrees.
So this smart portion of code encloses the angle inside a 0-360 segment. As well as it is always removing 2*pi (360) it is like removing complete turns of rotation so a big positive or negative angle is converted to a 0 360 angle pointing to the same direction.
In that case the angle value comes from a previous calculation and a big +/- angle is calculated. To avoid infinite increment of that value it is reduced to its canonical situation (0-360).
Best
You are right. I can't replicate it either.
Apparently that code change DID fix it and I was using the wrong version of my script. :oops:
Originally the problem came from the - 2 * math.pi + 2 * math.pi bit that "reversed" the angle which is only needed on frame 0 when dragging the tip of a bone with the bone translate tool. That doesn't apply here.
Sorry for the confusion.
:evil:
:D :wink:
