Two chracters talking not playing right.
Phatthumb
Post by Phatthumb »
Maybe its my computer, but I'm working on a toon were two toons are talking to each other and after I animate it it doesn't play back right. It doesn't play each frame. This is just in AS. So I was wondering if I render it will it play all the frames? I've made other cartoons and this it the first time this has happened.
Phatthumb
myles
Post by myles »
Under the Animation menu you'll probably find Allow Frame Skipping is ticked. It skips drawing some frames so playback can keep up with the soundtrack.
If you untick that option you'll probably see all frames at the expense of the soundtrack skipping, stuttering, or slowing down.
Yes, it only happens in live playback, not in rendered files which will play all frames. Live playback in AS redraws each frame, which is considerably slower than playing back a rendered animation.
Regards, Myles.
-- Groucho Marx
Uhm, why didn't you render the scene and check the frame count?
Phatthumb
thank you
Post by Phatthumb »
LOL, thank you every much. I rendered it and it was all good. Sorry about the silly question Slowtiger. I was animating all day and then it wouldn't playback right. It was long day. LOL, thanks again.
Phatthumb
De nada. I find myself, overworked as I am, quite often in self-built traps like this.
