Genete! Bone "points" at another bone
Genete,
I think I remember you talking about working on something like this in another post. I was unable to track it down.
Anyway, I just figured it out. I have a script solution that makes a bone change scale and rotation to "follow" or "point" to another bones position. It works great. I will post it as soon as I "clean it up" a bit and make it more useful. Currently I have my test bones "hard coded".
I actually reverse engineered the code from the LM_translate_bone tool. I used the code from the part that works on frame 0 with bone length and converted it to scale for frames above 0.
Yeah! It was when I started to make the complex springy gizmo with variable length (I think...).
It would be so cool. With that you could create a full crankshaft mechanism or what ever other mechanism you can imagine...
There is an example of an embedded script bone that always points downwards made by LM in the first post of embedded script. May be it help you to polish the script.
Waiting for your script release.
Thanks!
Thanks!
Well here it is. I put the link and instructions in my script thread:
viewtopic.php?t=7842
It has trouble when you use the undo. Just go back to frame 0 to "reset".
It's really cool. You can move the pointer bone or even a parent bone and it stretches to stay attached to the target. Same for the target. It works with any number of parent bones in a chain.
This is the funnest script I've done and it's fairly simple code. I think it could be very useful for a lot of things. I plan to use it with your sort shape script Genete. I can use this to cut down on the number of teeth. Instead of individual teeth shapes each with a bone, I am going to "connect" them into one shape and use an aimer bone to follow the turning of the head to scale and rotate.
Cuts the number of shapes/bones down to 5 or 6 instead of 30!
Now my brain is spinning!
I think... uh... I am almost sure I can modify this script to create a better "bone lock" for walk cycles!
Actually it can be used as is really. Think about it. You can make the calf bone of a leg an "aimer" bone then it only rotates when you translate another bone. The calf will stay "locked" where ever you put it!!! Even if you move the hips or anything else!!!
Yeeeeehaaaaa!!!!
I want to see if a modification to limit scaling would be possible.
Yeeeeehaaaaa!!!!
Very strange. The file seems okay. I downloaded it a couple of times into different places and it works. Don't know what else to do.Genete wrote:Please check out the aim_bone.zip file. When I unzip it, it is empty.
I re-uploaded it any way just to be sure.
It could have been a "glitch" when you downloaded it.
This script has a ton of potential.
I'm playing around with all kinds of weird combinations of bones to create different types of "IK" for arms and legs.
For instance I have an arm bone where the forearm is "backwards". It goes from the hand to the elbow. The target for both the bicep and forearm are at the elbow. You can drag the forearm to rotate/scale it, or you can drag the elbow bone to rotate/scale both the bicep AND the forearm. This is like having the hand at the top of the IK chain. You can lock the hand in position but then also move it as needed. Very very coooollll!!!!
There are some glitches I need to work out in the code to make this work well. I'll keep on working on it.
This thing is amazing. It will make creating 3D body turns a piece of cake.
The weirdest thing ever. For some reason this stupid zip file won't extract on windows. I've done it a dozen times and just the folder won't zip correctly.
Try these links:
http://www.lowrestv.com/moho_stuff/scri ... _bone.anme
http://www.lowrestv.com/moho_stuff/scripts/aim_bone.lua
This one works now. I didn't zip it inside a folder. I don't know what the problem is with that folder.
http://www.lowrestv.com/moho_stuff/scripts/aim_bone.zip
And here is the code if they don't work:
Try these links:
function LayerScript(moho)
local layer = moho.layer
if ( not layer:IsBoneType() ) then
return
end
local skel = moho:Skeleton()
local boneCount = skel:CountBones()
if ( boneCount == 0) then
return
end
if (moho.frame == 0) then
aimGrps = {} -- list of bone pairs for "pointing"
for b = 0, boneCount - 1 do
local bone = skel:Bone(b)
local boneName = skel:Bone(b):Name()
local Baimer = string.find(boneName, '.aim') -- bone that points to the target
local Btarget = string.find(boneName, '.trg') -- target of the pointer bone
if ( Baimer or Btarget ) then
local name = string.sub(boneName, 1, -5)
if (aimGrps[name] == nil) then
aimGrps[name] = {}
end
if (Baimer) then
aimGrps[name].Bp = bone
end
if (Btarget) then
aimGrps[name].Bt = bone
end
end
end
end
if (moho.frame > 0) then
if (aimGrps ~= nil) then
for b in aimGrps do
local aimer = aimGrps[b].Bp
local target = aimGrps[b].Bt
local inverseAIM = LM.Matrix:new_local()
local offset = LM.Vector2:new_local()
offset.x = target.fPos.x
offset.y = target.fPos.y
local TRGBoneP = skel:Bone(target.fParent)
if ( TRGBoneP ~= nil) then
TRGBoneP.fMovedMatrix:Transform(offset)
end
local boneVec = LM.Vector2:new_local()
local Bonelength = aimer.fLength
boneVec = boneVec + offset
inverseAIM:Set(aimer.fMovedMatrix)
inverseAIM:Invert()
inverseAIM:Transform(boneVec)
inverseAIM:Transform(offset)
local dL = boneVec:Mag()
local bscale = offset:Mag() / Bonelength
local angle = aimer.fAngle
angle = angle + math.atan2(boneVec.y, boneVec.x)
while angle > 2 * math.pi do
angle = angle - 2 * math.pi
end
while angle < 0 do
angle = angle + 2 * math.pi
end
aimer.fScale = bscale
aimer.fAngle = angle
end
moho:Skeleton():UpdateBoneMatrix()
end
end
end
- Víctor Paredes
vern, i''m looking your script and i see it have a lot of potencial. but, however, my brain and my english knowledge are limited.
can you post more anme examples explaing the different uses?
that would be great.
thanks again. even if i don't understand much, my limited brain tell me it's a great script.
ANOTHER PRETTY SIMPLE BUT STRONG POWERFUL SCRIPT!!!!
It is a great script Vern! Congratulations!
Regarding to the aim_bone.zip, now it works. It was weird.
Selgin, I have problems understanding Vern but believe him, It would be amazing!!!!
Imagine this:
1) Create a 3D skeleton (only the extreme edges of the skeleton and the joint, not the complete surface of a 3D object) using the 3D stuff of the other threads
2) For each pt bone link at its origin a .trg bone
3) Add a .aim bone from the parent pt bone to the current pt bone. You have a "3D" bone!. Draw the limb around this .aim bone and it would squash and stretch according to the 3D limb position.
What I don't understand yet is the stuff about walk cycles...
Vern! put examples please!
Imagine this:
Working on it!
here is an arm I whipped up:
http://www.lowrestv.com/moho_stuff/scripts/aim_arm.mov
http://www.lowrestv.com/moho_stuff/scripts/aim_arm.zip
Look at the bone parenting. The forearm bone is "flipped" starting at the hand and ending at the elbow. The forearm is NOT a child of the bicep. Both arm bones are aiming at two bones at the elbow and parented to a "root" bone or shoulder.
So you can rotate the forearm by dragging it. This moves only the forearm. If you drag the elbow bone indicated it rotates both the bicep and the forearm.
Rotating/translating the root or shoulder bone moves the whole arm.
This could lead to some very interesting bone setups. You don't need to parent a bone to have it "linked".
I have to say this is a LOT of FUN to animate the arm!!!!
I use to do the same thing but had to scale/rotate all those bones individually.
There are some funny strange problems I have to figure out before this will work the way I want to use it. It has to do I am pretty sure with how the script is applying the parent bone matrices. For some reason constraints don't behave properly using aimer bones as the target.
When the parenting or hierarchy of bones is "unusual" or complex the mesh isn't updated with the bone movement.
I will keep working on it. I'm so close.
- Víctor Paredes
