About Undo and Dragging Numeric Text Fiel
Locked
Rai López
Post by Rai López »
If you drag with the right mouse button in any numeric text field and change the value, you must press TWO times "Ctrl+Z" to undo the change... this seems be a bug, but as well as that if you drag and make a "big" change (without release the mouse buttton), you must Undo several times to undo the change and probably you can't undo because you has not enough "Undos" I don't know if this is a bug, but I think that it'll be more practique if a change make without release right button could be undo with a single Undo action... BYE!
Locked
