Warping images for patterned clothes (and poss. texture too)
Neil
Post by Neil »
Okay, first I drew this pattern in Paintshop Pro:
Then I imported it into ASP and added bones, allowing it to be warped:
Image Image
Then, using masking, I applied it to a character's clothing:
From there I just had to warp the image to fit her movements - you can see the result here:
http://www.youtube.com/watch?v=ejRZf0NNudY (3 seconds in)
It's not perfect (the pattern slips off-centre a couple of times), but it'd be interesting to see how else this trick could be used.
Cool tip.
The most interesting thing is how to setup the bones to make a good warp of the texture to achieve easily the desired movements.
Can you show us the bone linking and its strength for this particular case?
Neil
Post by Neil »
To be honest, I hardly ever use bones and the structure is pretty rudimentary. But here you go:
The two bones on top, pointing left and right, are connected to the upper middle bone; the bones down the sides are connected to the ones on top. Strength-wise, I think I used the default settings. That's pretty much it...
p6r
Post by p6r »
A great tip !
Thanks a lot Neil...
6R
nice tip.
ey! i love how your girl turn the body! can you show us something. maybe an anme, maybe an screenshot... please :)
Neil
Post by Neil »
The girl was done entirely with point animation, so there's nothing really fancy involved in the turn.. was there anything about in particular you wanted to know about?
