Papagayo .dat files greyed out
Discuss Papagayo issues here
VidE
Post by VidE »
I'm exporting .dat files out of papagayo, but when I look for them through the layer/switch tab, the file is greyed out; ASPro doesn't see it as a proper file for import. I'm on an Intel Macbook, any weird things I should know about?
I think maybe I remember hearing something about some file formats on the mac not being recognized by AS.
Just guessing. I don't know of a workaround either unfortunately.
VidE
Post by VidE »
Thanks, I'll check Papagayo, see what's up.
VidE
Post by VidE »
Heyvern, I'm not sure if you are running on a Mac so...
If anyone out there is running AS Pro 5 with Papagayo or Yolo on an Intel Mac, OSX 10.4+, and you're able to use the .dat files please let me know. Not being able to use Papagayo is a big setback to a project that has aabout a 2 week deadline, so if there is a workaround or I need to install an eralier version or something, please let me know.
Thanks.
No problems here.
Running Mac and AS Pro and I am able to load .dat files.
Are you sure they have the extension when you save them out of Papagayo? I seem to recall that sometimes on the Mac I could save a .dat file without the extension.
EDIT:
OOOPS! I am not using an Intel Mac so that might mean something... I don't know. I am still using Panther on an old G4.
VidE
Post by VidE »
FrozenDelight had the solution in another post. Add the .dat extension to the file Papagayo exports. Tried it and it works. Anyway, thanks again.
