Sharing .moho files
jorgy
Sharing .moho files
Post by jorgy »
Would anybody like to share some of the .moho files from their entries?
Nolan Scott
Post by Nolan Scott »
Of course , you can download the file from my entry "Walk in the Park"
here:
http://homepage.mac.com/nolan.scott/
Cheers
Nolan
jorgy
Post by jorgy »
Thanks Nolan! What kind of hardware did you use while creating your animation? How long did it take to render? Just doing an ALT-R on my system for a single frame seems to take forever!
Thanks! There's tons of stuff there to dissect and see how you did things.
Nolan Scott
Using an iMac G4 with 700MH.
Yes, rendering was fairly slow. Everything in one file one couldn't
expect otherwise. I let the computer do an overnight shift.
Maybe you save the layers as separate .moho files -
that might help to reduce your render-time.
Cheers
Nolan
jorgy
Post by jorgy »
I understand about breaking down your amination into smaller chunks "time-wise". But I'm not sure about breaking it out into separate layers. Actually, I see how you could do that, but then how would you put it all back together again?
Nolan Scott
1. Make a copy of the file.
2. Open the copy - open the Group-Layer "Foreground".
Take out all the files - delete the empty "Foreground" Group-Layer.
Save the file.
3. Open a new Moho-window - go to File - Import - Moho Object -
Open that file you just saved.
Insert Object window should open now.
Choose your desired file and save it.
4. You can try to put it all together again - thats your creativity.
You still have the original file as reference.
Cheers
Nolan
jorgy
Post by jorgy »
But would I have to have another program besides moho to "composte" (not sure if that's the right word) it together into the scene? Using your example, I'd have a foreground, and maybe a background, and other "layers". How would they get "put back together"?
Thanks for your replies.
nobudget
Post by nobudget »
There are two basic methods of combining animations in Moho.
First is to import a group (for instance a character) from another Moho file to your current Moho file. For instance, you design three characters in three Moho files. In the fourth Moho file you import the three characters. So you are basically assembling buidling blocks of animation. Very useful to build libraries of characters and create scenes. They can be changed in the new file like any other Moho layer.
The second is more the compositing you'd do in video editors. Recently I created an animation with two characters talking. I designed and animated the heads in two different Moho projects and rendered them to Quicktime with Alpha channel (Millions+ setting). I imported those as Image Layers in a new scene that had the bodies of the characters. It looks a lot like the first method but you can't change the head animations anymore. That's a drawback but you also do not have to think about those prepared pieces of the animation so you can concentrate on the rest. And it saves time on rendering.
Hope that helps,
Reindert.
www.nobudgetvideo.com
LittleFenris
Post by LittleFenris »
[quote="Nolan Scott"]Of course , you can download the files from my entry "Walk in the Park"
here:
I downloaded that file from your site and Moho is giving me an error. It says: "Read error at line 51090. In code file D:\lm_tree\lib_moho\m_mesh.cpp, line 143."
Any ideas? I'd like to disect other peoples projects and see how they work.
Thanks
Nolan Scott
Hi LittleFenris,
Sorry to hear that.
I just downloaded the file myself and all worked well.
At the moment I have no idea what the problem is.
If I find something out I will let you know.
Cheers
Nolan
Lost Marble
Post by Lost Marble »
When I download the file, I get an error at line 66821. It seems that the Moho file is getting truncated during download. The web page says it should be 7.4MB, but my downloaded file is only 952KB. It got cut off - that's why Moho is unable to open it.
Nolan Scott
Sorry about all this - when I download with Speed Download 3
the filesize is 8.6 MB -after Stuffit works it way through the binhex.hqx file the size returns to 7.4 MB - and opens OK in Moho.
I put the file " walk in the park.moho" on a different page now -
Cheers
Nolan
