Hi, first of all congratulations on a great software!!
I'm very new with moho and animation overall. I want to use Moho with the Gimp and heard some of you on this board talk about using PNG files.
I want to try that out but every time I save a png file on the gimp and send it to mojo I get an error detail:
Bad file header : (the symbol of a square)PNG
Any help?
Thanks!!
bad file header: PNG
- Lost Marble
It sounds like you're using the File->Open menu command to open the PNG file. The Open menu command is used to open a Moho project file. The "bad header" message you're getting is because the PNG image is not a Moho file as expected.
To get a PNG image into Moho, use the File->Import->Image menu command instead.
