viewtopic.php?t=3014
To obtain strange behaviors of the line width interpolation values just do the following:
Create a shape.
Go to frame 30 (or similar)
Using the line width tool increase its default value to 20 for example.
Then go to frame 0 apply the "Reset Line width" And it will restore its original width at frame 0. But if you go to graph mode its current value is -1 and the value at frame 30 is 0.08 .... what????? Why it doesn't reflect the current width in the custom numeric input? what means those values?
Also when you create an automatic shape (a circle for example) there are created a keyframe at frame 0 for line width for each point of the shape (selected point).
But if you modify the line width at other frame bigger than 0 the keyframe at that frame disappear for the modified point.
Line width need improvement.
