Crashes when rendering in OSX 10.3.6
I'm using version Moho v5.0.6 and it crashes sometimes when I render. I ran Moho from a terminal to check what error I get, but all it says is 'Bus error'.
For me it stays in permanent "render..." without ever saying "done", and I can't close the render window or access any other part of the program, so I have to do a force quit. I emailed LM about this but I think this was just before the holidays kicked in, so I understand if it got lost in the shuffle.
-Keith
It doesn't throw any error. It just hangs, like there's some infinite loop it gets stuck in towards the end of the rendering process. I have to go back to the terminal window, hit control-C and it just goes back to a regular prompt.
Or is there something else that I'm supposed to do here? I'm new to using Mac OSX.
-Keith
- Lost Marble
- Lost Marble
Sorry, I just realized there are two different bugs under discussion in this thread. The first is where Moho would crash with a "Bus Error". We haven't been able to reproduce this here, and the 5.0.7 update does not address it.
The second problem is the Render window locking up, not finishing, and refusing to close. Moho does not actually crash in this case. This is the problem that 5.0.7 was intended to fix.
Oh, alright. Well, I've been running it in a terminal and it also output a segmentation fault.
It doesn't crash every time I render; sometimes, in the middle of a render, it stops and crashes. It's always during a render, but not always on the same layer when it crashes.
Is there a way to run Moho in something like verbose mode to get a more detailed error output?
- Lost Marble
It crashes every 5 +- 3 renders using cmd-R. I'm doing single frames for now; I don't yet have any animation to test it with.
I've been using the export command to save a jpeg and refreshing to view it for the past couple hours and it looks like it works fine. I also just found the preview command - perhaps that will work fine as well (I can test it on Tuesday).
Mac OS X crashes
Since downloading the 5.0.7 update, I haven't had any trouble with my renders. (Mac OS X 10.3.7 1Ghz Imac G4)
