how can i seperate one shape into two?
lloydH
Post by lloydH »
1.
for example, a water drip outgrows another drip and falls to the ground.
2.
by contraries, how to combine two shape into one?
such as two water drip stick into one unit shape.
an animator
myles
Re: how can i seperate one shape into two?
Post by myles »
lloydH wrote:how can i seperate one shape into two?
Use 2 layers. The first layer has one object, with a partial drip. The second layer has two objects, with a separate drip.
Switch between them using layer visibility keyframes, switch layers, or some other technique.
Example, using layer visibility: http://www-personal.monash.edu.au/~myle ... visi01.swf
Moho file: http://www-personal.monash.edu.au/~myle ... isi01.moho
lloydH wrote:by contraries, how to combine two shape into one?
Same technique.
Regards, Myles.
-- Groucho Marx
lloydH
Post by lloydH »
thank you so much myles and your moho file !
an animator
