Quicktime render problem
slice11217
Post by slice11217 »
Just so everyone knows, I did a search to see if anyone's run into this before me...
I'm working on a G4 Mac, running system 10.3, and using AnimeStudio. My project is 1440 X 1080 at 30fps. In the project, there is a character that is part vector, part image.
Here's the problem: when I render out to Quicktime (animation compressor, millions of colors+) and then import the movie into After Effects what I get is the image layers look fine but the vector levels all look to be at about 10% opacity.
I ran a few tests to see if I was crazy or not. First I rendered out with the image layers turned off and got the same result for the vector levels. I checked the alpha of the shapes (all 100%/255). I rendered out at millions of colors (no +) and the vectors are at full opacity but of course, I have no alpha and unfortunately I need an alpha.
My workaround for the moment is to render out as .PNG files. This seems to take a little longer and isn't quite as portable as a .mov, but I got the result I needed.
I'm going to see if I can sneak a render from one of the computers I have at work (G5s running latest OS), but I'd really like to have this resolved on my home computer since that's where I use AS the most.
Thanks
Slice
slice11217
Update:
I tried the same file on my computers at work (Intel Mac) and I had the same problem.
Touched
Post by Touched »
I haven't had that problem, but I've been using the PNG compressor for Quicktime, not the Animation compressor. Have you tried that?
slice11217
Touched wrote:I haven't had that problem, but I've been using the PNG compressor for Quicktime, not the Animation compressor. Have you tried that?
I haven't tried that. I normally use Animation Compressor, and have for a long time. Usually it works -this is the first time I've ever had any problem with it.
I'll run a test and see what happens
slice11217
[img]
Just tried it. Got the same result.[/img]
Touched
Post by Touched »
Unfortunately that was my only guess. Hopefully someone else can help!
Did you try checking "Do not premultiply alpha channel" in the export settings?
This is just a guess.
slice11217
heyvern wrote:Did you try checking "Do not premultiply alpha channel" in the export settings?
No, but I'll try that also!
Thanks
slice11217
You guys so totally ROCK!! Thanks!
Now here's my next question:
How can legally make 3 million dollars in the next 6 days and pay little to no tax on it?
...come on, I know you can do it....
