Anyone know why the mesh won't move with this code?
When I use this:
slv2.fPos = vec2
The bone in question (slv2) moves on screen just as it should, but the mesh bound to that bone doesn't move. vec2 is a position derived from another bone position and is added to this bone's (slv2) position.
If I add a key frame for slv2 then it does update the mesh properly.
I am trying to eliminate key frames where they aren't needed. I just want the slave bone to move without generating a key frame, like a constraint. I can't use a constraint because the target bone isn't really moving it is translated based on another bones rotation. This "target" bone does have a key frame.
Everything works as it should, the problem is that the mesh doesn't update. Is there a way to force the mesh to update?
Dagnabbit!!!!!!
moho:Skeleton():UpdateBoneMatrix()
Good grief. Everytime. Every single time this happens. I post a question and 5 seconds later (after hours of fiddling and searching) I find the simple answer.
