GreyKid Pictures ...
I have reviewed one of the Greykid Pictures shorts (Les Profs). Due to bandwith problems I have seen the animation as slow frame rate. I have realize that:
1) They use Motion Blur for everything that moves relative to the camera. You cannot perceive normally because it is only by one frame or two, but there it is. Motion blur affects only to the layer where the effect is applied. So they apply motion blur to the part of the body that is moving in relation to the rest of the body. For example the arms. Altough the whole body is moving they don't apply motion blur to it. Only to the portions of the body that have a relative high speed respect to the resto of the body. That gives a very "film look" to thier animations. In a real film the camera tracks the person movement (the whole body is sharp) and depending on the light conditions and the operture and depth of field of the camera could appear blur into the moving part of the body (the limbs). (Experts correct me please.)
2) They don't use switch layers for lip movements. (or they use interpolation) I'm thinking they use a combination of Switch layer with bone motion and point motion. Very interesting.
3) They use shadows in the animation (for example the red face of the gim prof) with the same thechnique as sang820 uses with his pretty girls. It means that AS is prepared and valid for non anime drawings (Les profs is the best example of non anime) where the shadows are flat. (correctme if I'm missunderstanding anime style)
They are great!
They are great!
LittleFenris
Re: GreyKid Pictures ...
AS can do any style you would like it to...this is why I'm so confused (and iritated) that they decided to call it Anime Studio instead of leaving it Moho or calling it something a bit more generic.Genete wrote:It means that AS is prepared and valid for non anime drawings (Les profs is the best example of non anime) where the shadows are flat. (correctme if I'm missunderstanding anime style)
The ONLY reason they called it Anime Studio is because of the huge jump in popularity of anime style cartoons around the world. If this had been 5+ years ago they wouldn't have named it the same because anime was nowhere near as popular with the masses then.
I understand they are trying to cash in on the anime craze, but to me it limits the customer base buy pigeon-holing the program into soundling like all it can do is anime.
GreyKid has a few examples of non-anime styles that are more than feature film quality and show AS and ASP are capable of doing much more than just anime.
Genete, can you post a few examples of what you're describing? Are they using AS motion blur render setting or faking the blur with PNGs?Genete wrote:They use Motion Blur for everything that moves relative to the camera. You cannot perceive normally because it is only by one frame or two, but there it is.
Really I don't know how they do it. It seems that they use blur for only a frame for certain layers, but more a look to the screen captures more I think they make a blur in a video editor with motion detection...Gnaws wrote:Genete, can you post a few examples of what you're describing? Are they using AS motion blur render setting or faking the blur with PNGs?Genete wrote:They use Motion Blur for everything that moves relative to the camera. You cannot perceive normally because it is only by one frame or two, but there it is.
Look the images...
HERE THE CORNER OF THE COFFE MACHINE INDICATES A USE OF ANIME STUDIO BLUR LAYER OPTION.
HERE IT SEEMS THE SAME BUT I'M NOT SURE
LOOK HERE HOW THE LEFT LEG IS SHARP BECAUSE IT IS ON THE FLOOR. THE REST OF THE BODY IS IN MOTION IN RELATION TO THE CAMERA SO IT IS BLURRED
Maybe Greykid Pictures could put some light on this...
Thismay be the plug-in you're looking for. AS motion-blur isn't really a motion-blur, it's what After Effects would call motion-trailing.
- Squeakydave
Yep.
Check here:
http://www.revisionfx.com/products/rsmb/gallery/
There's even an example of Mike's Lenny. Lol.
Check here:
- Squeakydave
- BunyanFilms
- Víctor Paredes
Nah. I don't think so. You mean they cut between scenes and applied affects and comped in Anime Studio? I find that hard to believe. Thet'd be awesome if they did, though. My guess is they used a 3rd party comping program like After Effects or Combustion to add effects and put it together.
We'll never know until Greykid lets us know.
