Using Papagayo with Flash?
Discuss Papagayo issues here
jhbmw007
Post by jhbmw007 »
I remember seeing somewhere on the forum where someone figured out how to do this. Anyone know how? Or does anyone know of a lipsync plugin for Flash that is similar?
In the past I have adapted a text-to-speech program called Vocalise TTS:
http://www.digitalcuriosity.com/VocaliseTTS/
You can build your own character faces and mouth phonemes, and then type in the text you want and the program will build the sequence of mouth positions for you. It's a bit rough and ready, but it's a damn sight faster than doing it by hand, and you can always tweak it a bit afterwards. Very easy to use - it's a Flash plug-in. Costs about 30 dollars if I remember correctly.
They also do a plug-in which will accept a wav file as input and build the mouth positions from that -- sounds like more what you want? They do trial versions so you can try before you buy...
J
J. Baker
Post by J. Baker »
Go to my website and try my lypsync program. It's not the best but it works. http://www.flashpulse.com
