I have a big problem with the png transparency with AS but not in Moho :
So, what has changed in AS ??????????????
When I import a png picture (exported with the same parameters from AS and from Moho) in my creation program (MMF 2) I have a perfect transparency (= no bad pixels around the outlines) if the picture comes from Moho... and a not perfect transparency (= bad pixels around the outlines) if it comes from AS !?!
With a black or a white background it's the same thing !!!
The best : if I create the file in AS, export the picture in png format and import it in MMF 2 => BAD !
If I only change the extension of the file (.anme -> .moho) and I open the file with Moho... then export... The transparency is perfect in MMF 2 !!!
So something has changed in AS !?! But what ?
Could you "repair" that ???
6R
Different transparencies in AS or in Moho
@ Genete :
You just have to draw a circle with an outline (4, for example) into AS and into Moho... then create a png picture with "export animation" (from frame 1 to 1)...
Then import the picture into MMF 2 if you have it and you will see the big difference of quality around the shape...
To make games I need perfect transparency around the characters or others...
Moho allows that !
AS doesn't allow that !!!
Thanks
6R
Moho allows that !
Thanks
6R
LittleFenris
I have followed your steps and dont see any difference in the render quality of Moho and AS. I am talking about AS Pro. Perhaps AS lite have some problems that I cannot reproduce.
Here are the files produced by Moho and As opened with Gimp and watched at 800% of zoom. I dont see any difference. Both renders are from the same moho/anme file.
I dont have MMF 2 so I cannot duplicate the error. Sorry.
Best
Best
@ Genete :
Very strange...
Maybe the Gimp doesn't work like MMF 2 with the import of png files !?!
Thnaks to have tried to solve my problem...
@ LittleFenris :
Yes I have made more than 200 (educational or not) games on this website... (http://p6r.free.fr
If you want to test my most appreciated program (an educational version or a normal version) you can go here : http://p6r.free.fr/yannland.htm ! Its' a platform game with more than 40 levels...
To play, no problem (with french) : Only click on the green arrow for the first time... Then start and jump with Shift and move with the arrows !
Every 4 levels you can note a key at the top of the screen to tape on the introduction level to begin (almost) where you stopped the last time you played...
Where are your programs ???
@jhbmw007 :
Maybe...
As you say : It doesn't explain why it only happens in AS !?!
6R
Very strange...
@ LittleFenris :
@jhbmw007 :
Maybe...
6R
