group keyframes of diferents layers
Runus68
Post by Runus68 »
Hello any one kwon if it's some way to group key frames of diferent layers, to move them at the same time...
We have some characters and they have 12 layers more or less and is relly tired to move the key frames in any layer. the idela will be to select the layers in wich we want to move te key frames ...
Sorry for my english and really thanks to all....
Pd: if you are in Barcelona o near to, don't doubt to contact as we wil need anime animators.
Hola,
me temo que para lo que pides no hay ningún script hecho aún. No se si el "Rescale keyframes" del menú "Animation" te vale. De todas formas ¿cómo vas a seleccionar las capas sobre las que quieres mover las keyframes? De momento, que yo sepa, no se puede seleccionar más de una capa al mismo tiempo. Con lo que, hagas lo que hagas o es a la capa seleccionada o a todas las capas...
Suerte.
Sorry for speaking in spanish guys... but this man need some help.
Touched
Post by Touched »
I think you would be served well by Crashcore's "Shift Layer Keyframes" menu script.
"This script will shift any range or all the generic layer keyframes in either the currently selected layer or for the complete document. A positive number shifts right, a negative number shifts left. "
Located here:
http://www.lostmarble.com/forum/viewtopic.php?t=2448
Runus68
Post by Runus68 »
thanks again "gracias Genete" thanks touched.I will try in inglish even if i'm not that good ....
that scrips of cc don't work that goood if it's full of key frames and layers...
so the shift layer key frames never been really usefull for us.
touched my hole team really give you thanks for the tool ... the delete key frame tool is really useful for us ...
is really good to see how gentle and kind is people around here ...
thanks again..
Touched
Post by Touched »
I'm afraid I don't know a good solution to this particular problem if the Crashcore scripts didn't work. Hopefully someone else here can help!
(And you're welcome for the other script. :) )
