Can I shift all layers forward in time?
benderfax
Post by benderfax »
I created the "Great Expectations" entry in AS Contest 1, but I did not leave room at the "head" to insert my title sequence. I did not know how to sellect "all" my layers together to make room for my titles, so my title is one frame long.
Can I shift "all" layers forward in time as a group in Anime Studio plain or Pro?
Thanks!
Rasheed
Post by Rasheed »
I believe the menu Animation -> Rescale Keyframes... -> Rescale entire document will do the trick, if you set the frame range correctly.
benderfax
Shifting all layers in time.
Post by benderfax »
I tried "Rescale Keyframes" . I set the new start and end frames 100 frames later. It din not have the desired effect. It only effected the one layer highlighted in blue. I need to shift "everything" forward in time at once.
Did I miss something?
DK
Post by DK »
I think you might have to select "Entire Document" to rescale.
(don't know whether that will have the desired effect you want though.)
Personally, I would just just throw everything (all layers,groups etc) into one big group and move that layer forward.
D.K
I thought I posted a reply... hmmm... maybe I posted in the wrong thread..
Anyway...
From my extensive testing I've found that rescale key frames doesn't always work the way you expect.
To do what you need launch the scale key frame menu. Check scale the entire document FIRST, if you check it later it sets the scaled values back to default.
Leave the top part as is, start frame 1, end frame whatever the last key frame of the animation is. Remember! The end of the animation is the LAST KEYED ITEM not what you set the end of the animation to be in the time line (that gray bar).
On the new start, set it to how far forward you want to push the timeline and the new end frame is that value added to the current end frame.
So lets say you had a 100 frame animation and you want to push it ahead 20 frames.
Set the new start to 20 and the new end to 120.
This should work.
benderfax
Rescaling Keyframes.
Post by benderfax »
"Rescaling Keyframes" has not shifted my layers forward, but rather alter my animation in ways I am not looking for.
I plan to upgrade to AS Pro soon. Then I can put all the layers in a "group" layer and shift that, as was recommended here. Thank you!
I could always build a seperate animation for the titles and assemble the parts later in a video editing program.
Thank you for all the suggestions!
DK
Post by DK »
Hi Benderfax,
Holy Cow! I did'nt know that there were versions of AS that DIDN"T have group layers! Can anyone tell me what versions do and don't?
Thanks
D.K
benderfax
Group layers
Post by benderfax »
DK,
I have Anime Studio 5 (not-pro). One of the features it lacks is "group" layers.
Anime Studio Pro 5 has "group" layers, as well as several other useful features not in the (not-pro) version.
What I don't know is if a complex .anme file created in AS Pro with particles or 3D objects, etc. will open and play properly if opened in the (not-pro) version.
My guess is, no.
DK
Post by DK »
Thanks for the info Benderfax. I was totally unaware that there was such a difference in versions.
D.K
Anyway you can use always a bone layer as a group layer...
DK
Post by DK »
Hey!Great idea about bone layers as group layers Genete. I was more concerned about the labelling on my my content paradise products. Most of them are layer based. I will have to go back and make sure they are labelled correctly for AS Pro.
D.K
Rasheed
Post by Rasheed »
I know you cannot create group layers with the standard version of AS, but can you also not read group layers? That would break a lot of existing Moho and AS Pro documents...
DK
Post by DK »
Great. Thanks for the info Rasheed.
D.K
DK
Post by DK »
For those who are interested:
I got confirmation from Fahim today that AS standard version DOES read group layers but you cannot CREATE group layers within the program.
D.K
