Outline width
Phil_L
Outline width
Post by Phil_L »
Hello everyone,
I'm a newbie to Moho -- it's the greatest animation tool I have found.
When building my characters, it appears that the outline is a little thinker than I care for. I usually have it set for 1. Is there a way to get a value less than 1? I.E. 0.5 or 0.75, etc.
All the best,
Phil
Lost Marble
Post by Lost Marble »
1 is the smallest value for line width you can use. However, if you turn off "Scale compensation" in the Layer Settings dialog for the vector layer in question, Moho will use a different algorithm to draw lines, resulting in a slightly thinner line.
You might also consider using a shade of gray, instead of black, to make a line appear thinner.
AcouSvnt
Post by AcouSvnt »
I noticed the line also looks thinner if you draw the object larger and then scale the layer smaller.
-Keith
Phil_L
Post by Phil_L »
I will try all of your suggestions. Thanks for the help.
