render preview not showing correctly
object22
Post by object22 »
I am rendering at 1920x1080 but the render preview screen is cutting off the top of the image. if i save the file and view it they are saving correctly its just within Moho's preview window that the top is missing. Any ideas? :?
nobudget
Post by nobudget »
Just tried it myself and you're right, only the available screen space is used for the preview. I've wondered before why you can export half-size but not do that in the preview rendering (as far as I know), that would help, setting the size lower in the project window will do the trick but might not render everything the way you want. Basically the window should either resize or have a scroll bar.
REALTIME UPDATE: You can drag with your mouse on the rendered preview to see the rest of the frame! Does that solve your problem?
Good luck,
Reindert.
www.nobudgetvideo.com
object22
Post by object22 »
got it! thanks a lot, that did let me see the rest of the area. its odd that it does that since there is plenty of screen space available, maybe they can fix that in an update.
Thanks again! :)
