Walking through a scene
rplate
Post by rplate »
I took a graphic picture of the main bridge of the enterprise and erased all the background and left only the forground. Saved it as a png file. Then I imported it into AS along with the original full image. I arranged my layers so that Larry was in between the two images. Because I used the same image they matched perfectly after I scaled the first one and positioned it. Then I simply type in the scale numbers, as well as the translate position numbers. I guess you could drag and tweak them to fit but the numbers work best.
Here's the flash test movie I created...
http://homepage.mac.com/rplate/Sites/LennySpaceGuy.swf
I wasn't worrying about a good animation I just wanted to test the walk through.
That's great idea combine "real" backgrounds (and foregronuds) to make animations. Apart of animation itself, next step could be refine color use to match the background and foreground pallete.
rplate
Post by rplate »
And here's the same file as a movie with sound.
Merry Christmas Everybody.
http://homepage.mac.com/rplate/Sites/LennySpaceGuy.mov
:D
