Export wireframe
grosbouff
Export wireframe
Post by grosbouff »
Hi, is there a way to export just the wireframe animation to make a "making of" of the animation ?
Wireframe does not exists for export options in AS. They are only a way to see all the drawings to make them visible in editing mode. If you refer to export construction curves they are only the skeleton for shapes (fill + outline) and are not rendered. In fact points and construction lines are not rendered and have no dimensions. (You zoom in or out and its size is the same)
You can check some options (uncheck antialiased edges, apply shapes and layer effects and check render at half dimensions and frame rate and reduced particles) in export window to make it faster and show it as the "making off".
If you want to strictly export the construction curves ...Perhaps some script guru could help you?
Google for some screen capture apps. I's sure some of these can capture screen animation in real time. That would surely be the most painless way (I can think of some painful ones...)
jahnocli wrote:Google for some screen capture apps.
is the "google" word a verb now?... ay, the english....
grosbouff
Post by grosbouff »
jahnocli wrote:Google for some screen capture apps. I's sure some of these can capture screen animation in real time. That would surely be the most painless way (I can think of some painful ones...)
I've tryed camstudio (open source) but it's not realtime :(
Rasheed
Post by Rasheed »
selgin wrote:is the "google" word a verb now?... ay, the english....
Yep -- verbs can become nouns, nouns can become verbs...and if we can't invent it, we steal it from somebody else!!
Touched
Post by Touched »
If your computer is too slow to both play the motion *and* record the capture file, there's also this method -- my computer's TV out is connected to my DVD recorder. I can record anything playing on my screen to DVD, then I can rip the DVD to a video file.
rplate
Re: Export wireframe
Post by rplate »
grosbouff wrote:Hi, is there a way to export just the wireframe animation to make a "making of" of the animation ?
I did this wireframe capture with SnapZ Pro on a Mac.
http://homepage.mac.com/rplate/Sites/wi ... apture.mov
rplate
wireframe
Post by rplate »
Here's another way to do that. Take a movie of whatever you are doing. The LCD screens allow that without flipping. Then import into a movie edit program. (iMovie) for me here. Then export into whatever format is appropriate for your media.
I think this is how Artfx does his site for showing his draw lessons.
Take a look here and see what I did. In this example I am tracing over an image I imported into Tracing Image.
http://homepage.mac.com/rplate/Sites/wireframe.mov
Rasheed
Post by Rasheed »
I don't use Snapz Pro X, because it messes with the kernel and I got kernel panics all over the place. Since I deinstalled it, I haven't a kernel panic (knock on wood). Better use IShowU if you have Mac OS X 10.4 or better. It seems pro video users prefer that over Snapz Pro X.
Touched
Post by Touched »
rplate, by "flipping", do you mean the flickering that you get if you try to shoot a CRT monitor with a video camera? You can eliminate that flicker by temporarily setting the monitor's refresh rate to 60Hz, the same refresh rate as the camera (for NTSC video, anyway). It'll be noticeably flickery to the naked eye on the monitor, but on camera it should be rock solid. Then just change it back after you're done. LCD, as you said, doesn't have this refresh rate problem.
rplate
Post by rplate »
Rasheed wrote:I don't use Snapz Pro X, because it messes with the kernel and I got kernel panics all over the place. Since I deinstalled it, I haven't a kernel panic (knock on wood). Better use IShowU if you have Mac OS X 10.4 or better. It seems pro video users prefer that over Snapz Pro X.
I've never heard of IShowU and went and tried the trail download. As you can see it puts a watermark on top of the display. I was impressed so far. Thanks for the tip.
Here's what I did with it. Touched it up and compressed the file for streaming in FinalCut Express
click here to see my test.
This is not an add for the software it's just a show and tell of what Rasheed uses. Thanks Rasheed. See above for the link.
Whoa! I tested the link and I'll be back after I fix it. Way to big!
I came back and it's a better stream now.
IsraelRN
Nice feature request
Post by IsraelRN »
I think that even if it's something you can find workarounds for, it's a nice feature request...
Not only for 'Making of' videos but also because Wireframe and Bones should be faster to render, and if you're working with several animators or with a animation director, would be nice to render all in wireframe for previewing all the parts together and see if there's something to fix or change.
Regards,
Israel RN
