Old film effect
- Lost Marble
Old film effect
Here's a trick to create an old film effect. First, the example - here's a little "before animation":
http://www.lostmarble.com/misc/flexi_run.mov
And here it is after applying the film effect:
http://www.lostmarble.com/misc/flexi_run_old.mov
To use this effect, first download the following Moho file:
http://www.lostmarble.com/misc/old_film_effect.moho
In Moho, open the file that you want to apply the effect to. Next, select the File->Import->Moho Object menu command, and choose the "old_film_effect.moho" file that you downloaded above. There will a single group layer imported from the effect file - make sure it is positioned above all the other layers in your scene.
That's it - the effect will not be visible in editing mode, but when you render the scene you'll see it. If you open the group layer, you'll see that the effect is separated into three components that can be turned on/off or tweaked independently to customize the effect.
- Banterfield
This is really great! The arsenal of effects continues to grow.
Looking at the file it quickly became clear to me that I don't understand everything that is going on.
Looking under layer settings I noticed that the blending mode is set to "Multiply". Looking in the tutorials I didn't see a description of what each of the options beneath this list menu meant. Is there a resource out there (or in the tutorials - I tried to find it, honest) that I could look at so that I could get a better knowledge of these different blending modes and how to use them?
Kind regards,
Kind regards,
Dave
- Lost Marble
Here's a description of Photoshop blending modes. Moho doesn't offer all of these, but the ones that Moho does have work the same way as described:
http://www.pegtop.net/delphi/blendmodes/
If you can't find a Moho specific explanation for them, I'm pretty sure Moho's blending modes work visually and mathematically the same way that they do in other programs (After Effects, Photoshop, Shake, etc.). So, you could probably look for them under those headings.
"Creating Motion Graphics with After Effects" has a particularly good chapter on blending modes, what they do and how they do it. I'm sure there are similar discussions on the same topic for other apps.
Sorry I don't have specific links for you, but there are a zillion (give or take 10) photoshop tutorials. I'm sure that there's one out there somewhere that goes over thisse modes.
There's a number of links on modes on this page, hopefully that will get you started:
http://graphicssoft.about.com/od/photos ... alslayers/
Modes are awesome (especially when you start getting into compositing shadows and such). You can also really "sweeten" your image with soft blurs, opacity and modes.
Good luck!
________
Girlfriend pic
Good luck!
________
Girlfriend pic
- Banterfield
- Squeakydave
- Squeakydave
Hi.
I dig this effect, but is it possible to get rid of it once its been applied to a piece, when simply Undoing is no longer an option? Namely the 'camera' effects it does. I'm assuming it's using the 'hand held camera' script, but I can't see any keyframes in the timeline that might be affecting the moho camera.
Thanks for the great support, and community assistance!
"I'm assuming it's using the 'hand held camera' script, but I can't see any keyframes in the timeline that might be affecting the moho camera."
I had the same question once, Lost Marble gave me this answer:
"All the camera shake script does is set the interpolation mode for camera moves to "Noisy". You could easily do this yourself by selecting all the camera keyframes and setting them to Noisy. (Or remove the effect by setting sthe keyframes to Smooth.)"
So right-click the first keyframe of the camera movements (and others if required) and set to smooth. Easy to miss...
Reindert.
www.nobudgetvideo.com
Reindert.
