Can't See Point Keyframes in Graph Mode in Moho 5.0.4
I can't see the keyframes of "Selected Point Motion" (neither for "Selected Point Curvature") in Graph Mode, I've done double click in their icons (until they are framed) I've searched them and I've pressed Auto Zoom too, but nothing... I think that is important to can see the graphic movement when you are working with Points in movement... I don't know if this happened too in other Moho versions. CIAO!
- Lost Marble
johnlumgair
Same problem
I've recently upgraded to version 5 (which is a great improvement) however i can't get the key frames to show up in the graph mode. As far as i can see I only have once channel selected. I've also experienced problems with the Auto zoom (or hitting the end key) but I can live with that. I'm using a G4 mac using os X10.3.7
thanks
John
thanks
John
johnlumgair
useful graph answer
I posted on the old yahoo forum and got the following answer it worked - (thanks Myles!
i've recently upgraded to moho 5 (which is a vast improvement)
Yes, version 5 has some great new features.
The forum has also upgraded!
Most of the Moho community are now over at the newer Lost Marble
forum, http://www.lostmarble.com/forum
You''l probably get more and faster responses there.
This list is being maintained for a while for existing information and
to catch people who've missed the move - and for those who prefer and
email list to the web.
> floating. for some reason I
> seem to be unable to be able to edit the graph as the key frames
> don't appear on it
> (although the graph shape does.)
Some possibilities:
In order to get access to the keyframe markers in graph mode, you nned
to have the right objects selected.
So, let's say you want to see keyframe markers for a bone.
1. Make sure the appropriate bone layer is selected in the Layers
hierarchy panel.
2. Make sure the appropriate bone is seected in the main workspace.
3. Make sure the correct channel is selected in the timeline (it
should have a thin black rectangle around the icon on the left-hand
edge)
A coloured background to the icon indicates the channel is visible.
A thin black rectangle around the icon (and a coloured background)
indicates it is the active selected channel.
> Another minor problem is that the end key seems to have no effects
> to |i have to manually
> scale it which is annoying
Related to the previous problem - once you can see keyframe markers
for a particular object and channel, it will then autoscale for that
object and channel (which may not be the correct scale for other
non-selected channels showing in the timeline).
Regards, Myles.
> don't appear on it
Some possibilities:
hierarchy panel.
edge)
Regards, Myles.
