Minor Time Format Problem
sherlock
Post by sherlock »
When you change your settings to use the SMPTE format in the Frame edit control above the timeline, the edit control is not wide enough to hold all of the decimals without keying left or right.
Truly, I would not mind having the frame number and SMPTE formats in separate edit controls accessible at the same time. I find I think of my soundtrack positions in terms of SMPTE, but the frame number is easier to recall when dealing with frames in Moho. And I hate trying to calculate FPS on the fly. 8)
Thanks for all of you hard work at Lost Marble. It is much appreciated!
Lost Marble
Post by Lost Marble »
After changing to SMPTE mode, either restart Moho, or close and re-open the timeline window to allow to text field to be re-sized.
sherlock
Post by sherlock »
Great. Thanks.
