modifing a range of keyframes
Gnaws
Post by Gnaws »
Is there any way to globally modify a range of keyframes? As in, is there a way to change all items that are keyframed at keyframe 99 thru keyframe 120?
In this example that I've posted, I'd like to speed up the mouth transition. But this involves several keyframed (mouth) layers. I was wondering if there was somewhere in the app I could move everything from frame 6 - 18 *forward* or *backwords* a specified amount of frames?
Here's my example:
http://www.geocities.com/gnawsleglock/testGuy.html
Thanks,
-gnaws
at menu.
Animation>rescale keyframe
i recommend first use animation>copy current frame and copy the entire document to the current frame (this will create keyframmes in all the animation channels). and make the same with the last frame.
for example, you want to rescale since frame 10 to frame 20. you want this be now since frame 10 to frame 40.
so you first create keyframes in frame 10 and then in frame 20. after that, you select rescale keyframe and select
rescale entire document
Start frame: 10 End Frame: 20
New start frame: 10 New end frame: 40
sorry, it's difficult to me explain you in english. i hope help.
Gnaws
Post by Gnaws »
Sorry for the late reply, Selgin.
I'll give this a try and let you know.
-gnaws
Gnaws
Post by Gnaws »
Hi Selgin - you're absolutely correct. I used Animation > Rescale Keyframes.... and it worked beautifully.
But I don't really follow how "Copy Current Frame..." would've helped.
Sorry again for being such a noob. :oops:
Gnaws wrote:But I don't really follow how "Copy Current Frame..." would've helped.
sorry, this was a too specific tip for too specific situations… and i wrote this horribly. don't worry.
i'm happy i have helped you.
Gnaws wrote:would've helped.
wow. that "would've" is soo weird for me...
you are pushing my english understanding to the extreme.
Two more English expressions for you to look up:
"Exhibition pronounced success"
and
"That pie is a trifle tart"
just kidding... :)
