cartoon network animation
Hi there,
does anyone know if the foster mansion for imaginary friends from Cartoon network, is done in Anime Studio?
I want to do an animation like that and it would be great to know that they use this software.
thanks
Leus
thanks
Leus
ha do ken
- Víctor Paredes
read the greykid post:
http://www.lostmarble.com/forum/viewtop ... ght=foster
absolutely.nanus00 wrote:do you think it would be easier to do that kind of animation with Anime studio than with flash?
Rasheed wrote:So why don't they, if it takes less work and time?selgin wrote:absolutely.nanus00 wrote:do you think it would be easier to do that kind of animation with Anime studio than with flash?
Moho/AS is newer and less known. Those of us completely brainwashed by the Moho/AS subconscious manipulation module won't switch to Flash. I would assume Flash has a similar plugin or feature and it's been around longer.
Hmmm. Depends what you want to do. Flash has much better drawing tools (in my opinion!), much superior sound manipulation, and a more intuitive (for me) use of symbols for re-use of content.
If you do a lot of character-based animation, though, AS is much quicker in the long run. It takes time to set up and rig the characters, but once you've done that, the animation part is a lot quicker and more flexible. AS also has things like a pseudo-3D space to put work in, particles and so on.
Why not get both, and combine their good bits?
I keep reading such things about the AS setup process, and I admit I am totally new to Anime Studio (last night) but from what I have messed with so far I don't see it being a lot of time and setup for a charcter.jahnocli wrote:If you do a lot of character-based animation, though, AS is much quicker in the long run. It takes time to set up and rig the characters, but once you've done that, the animation part is a lot quicker and more flexible. AS also has things like a pseudo-3D space to put work in, particles and so on.
Maybe my 3D background comes into play (been modeling and rigging 3D characters for ages it seems) , I don't know, but it seems the bone rigging and even switch layers are very intuitive and easy.
Of course I may change my mind the more I do.
Terrence Walker
Studio ArtFX
LEARN HOW TO Make YOur Own Animated Film!
Get Video Training to Show You How!
Terrence Walker
Studio ArtFX
Thunderone
Flash has quite good project management tools, especially the library which makes it easier to sort and reuse material. It's not as good as a full blown animation production system like Animo, but it does the job.
A studio which built up a library of characters, props, and movements for a series will definitely not throw away this treasure.
slowtiger wrote:A studio which built up a library of characters, props, and movements for a series will definitely not throw away this treasure.
